dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
  • larrysito111
    • Feb 2023
    • 41
    • uk
    got here a liquid damaged alienware
    the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
    so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
    so with the usb-c external monitor is getting to bios and OS
    otherwise not
    so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
    but still not the internal monitor
    (tested 3V and 5V going to the lcd LVDS)
    can someone advice me as it is i think an o-led display how to check if it is just the lcd now to replace
    thank you all
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3616
    • slovakia
    where is lcd pins measurements? or u think we have crystall ball?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3616
      • slovakia
      • mon2
        A1466 Macbook Air (Liquid damage repair)
        by mon2
        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
        Macbook AIR Model A1466 Diagnostic 09-01-2021
        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
        Problems & Resolutions
        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
        09-01-2021, 09:31 AM
      • rilley
        MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
        by rilley
        I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
        I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
        My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
        And the resistor L4004 is literally burned.
        From what I see from the schematics, it does not affect any other rails, only the connection to the display...
        07-10-2024, 01:57 AM
      • Jenzo
        MacBook A1989 overheating after liquid damage
        by Jenzo
        Hey everyone,
        Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
        I can't figure out how...
        05-13-2023, 07:58 AM
      • mitchw
        MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
        by mitchw
        Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
        It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
        I quickly took it apart and washed the liquid residue off the mainboard.
        The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
        The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
        Now the laptop...
        07-16-2025, 07:55 AM
      • grimacelord
        Lenovo IdeaPad 5 ITL05 | LA-K321P | Liquid Damage & No Charging
        by grimacelord
        I have an LA-K321P board here that came to me for no power. Upon visual inspection of the board, I found some liquid damage around PQB13 area. Replaced PQB1, PQB2, and PQB13. Laptop will power on if the battery has a charge, but the computer will not charge the battery. USB Type C meter shows 20V being negotiated, but virtually zero amp draw (0.0100 at most that appears for a brief second about once every 5 seconds or so). Looking through thermal camera, UT1 (SN2001024YBGR) is getting hot. I have schematic, but no board view. Was hoping someone could help me get this charging...
        01-06-2025, 09:23 AM
