Lenovo ideapad 5 windows 11 update disable charging circuit?
  • bogart219
    • May 2009
    • 200
    • usa
    #161
    Originally posted by m1ch43lzm
    That's bad if the resistance measurement is correct
    Click image for larger version Name:	gate source.jpg Views:	0 Size:	200.0 KB ID:	3665844
    PQ6204 is the high side MOSFET, if it's shorted S-G hopefully the RT6585 detected the fault, that's why the 3.3V and 5V supplies don't work
    You can remove PQ6204 and measure it outside the board to confirm, set the hot air to 450-460 C
    With the MOSFET removed measure again S-G pads on the board, resistance should be higher
    If the MOSFET is shorted S-G outside the board, it's definitely faulty
    Always measure resistance without power applied, don't connect the battery/charger until the MOSFET is replaced with an appropriate one
    Charger won't work anyway as the TPS65994 is missing from the board
    Dammit, I measured S TO G AGAIN ON 6204 and got 1.7 meg. (I tripled checked this time). My bad. Thanks for the hot air setting too btw.
    • m1ch43lzm
      • Mar 2019
      • 1075
      • Peru
      #162
      I can't think of anything else that could cause the 3.3V and 5V supplies to not start, but the LDO outputs work
      Maybe an out of spec resistor in that area, compare with the schematics, page 60 and the boardview
      With power removed (no battery, no charger) measure resistance across PR6204 and PR6205, should be 2.2 ohms (meter may read a little higher due to probes resistance, note the value of the probes touching together)
      PR6201: 15K
      PR6202: 5.1k
      With only battery connected, only if the MOSFETs and RT6585C IC are in place
      If both enable signals 3VALW_EN and 5VALW_EN are present (3.3v) and the outputs at the inductors are not shorted to GND, it should work, supplying the 3.3V and 5V at the inductors PL6201 and PL6202
      • bogart219
        • May 2009
        • 200
        • usa
        #163
        PR6201: 15K
        PR6202: 5.1k
        Those four resistors all checked out good. The only thing off the board now is the TPS chip and a cap PC5302. With the battery plugged in testing to ground those two solder pads you highlighted in the picture, the meter just kept flashing from 1.5 to 2.5 volts, back and forth.
        • m1ch43lzm
          • Mar 2019
          • 1075
          • Peru
          #164
          That could be the cause of everything right now, those should be stable 3.3v
          Measure resistance of RE4535 (it's smaller than a flea, near one BIOS chip UB2, your board has 2) and RE4539 (near the EC UE1, its a chip branded "Lenovo" IT8227VG), those are pullups for the 3.3V and 5V enable signals, both should measure 100K, why did the Lenovo engineers place them in completely different locations...
          If the resistors are OK, maybe the issue is the EC, if it has black glue on the corners don't attempt to remove it, that glue that Lenovo likes is very difficult to remove, you may damage the pads on the board; also it's a BGA chip that would need to be reballed
          Also the EC as far as I know needs to be programmed after replacement, and the programmer for those is very expensive
          • bogart219
            • May 2009
            • 200
            • usa
            #165
            Both of those resistors checked out good. Yeah, I can't mess with that EC chip. It seems this flashing started after something I did but what? The question is is this flashing the result of a component touching a ground where it shouldn't (that would be a short right)? Or is a component getting power from two sources at once? I will examine the areas I screwed with again to see if I can find anything fishy. Thanks again my man, I'm finding out how difficult it can be to diagnose a motherboard problem when its sitting in front of you, let alone trying to find a problem posting back and forth with a noob such as myself!!!!!!!
            • bogart219
              • May 2009
              • 200
              • usa
              #166
              Mich, I'm just spit balling here and tell me what you think of this: I asked this above, The question is is this flashing the result of a component touching a ground where it shouldn't (that would be a short right)? Or is a component getting power from two sources at once? Now if the flashing is from a short to ground, you would think something would heat up wouldn't you? I just checked the board with the charger and battery plugged in with my thermal camera and the only thing I seen light up a little was the BQ chip and that was only at 80c. Now would it be feasible to try some voltage injection? I got a voltage injection tool a few days ago. at this point do you think that would tell us anything?
              • m1ch43lzm
                • Mar 2019
                • 1075
                • Peru
                #167
                Charger connected won't do anything right now, as we don't have the TPS65994
                only 80C on the BQ?, that's burning hot if you touch it with your fingers
                The BQ is supposed to connect the battery to the main rail, labeled 20VB+ on the schematics, turning on PQ5305
                I totally forgot that PQ5305 has an internal diode from D -|>|- S, so the battery power goes first through the internal diode of PQ5305 to the main rail, that also goes to pin 22 of the BQ
                Then the BQ is supposed to turn on PQ5305
                SInce PQ5305 is a P channel MOSFET, a faulty/shorted BQ could also turn on this MOSFET
                Disconnect all power, measure resistance from G of PQ5305 (located close to the battery connector) to GND
                Also measure resistance from S-D, S-G, D-G
                On the BQ (always with power disconnected, no battery, nothing)
                Measure resistance to GND at pins 12 and 13 (CHARGE_SDA, CHARGE_SCL)
                Measure resistance to GND at pin 8, a suitable test point is at PC5319/PR5318 at the side closest to the BQ
                The flashing you see on the enable lines, could be that the 3VL is unstable; or the EC doesn't like something, as it has connections to the BQ25710 and the TPS65994, so the EC keeps restarting over and over, it could be pulses ef 3.3V on the enable signals but you can't measure that with a multimeter, you need an osciloscope if you want to check this "flashing"
                • bogart219
                  • May 2009
                  • 200
                  • usa
                  #168
                  Correction, That temp on the BQ chip was 80 degrees F, not C. I forgot I changed that on my thermal camera, I got C on my mind from the Atten and my soldering equipment.
                  PQ5305 : FROM G TO GND. - .9 MEG BQ CHIP, 12 TO GND. - .6 MEG 13 TO GND. - .6 MEG PIN 8 TO GND. - 136K
                  S-D - 1 MEG
                  S-G - 2 OHMS
                  D-G - 10 MEG
                  Don't understand when you said this " a suitable test point is at PC5319/PR5318 at the side closest to the BQ ". I was able to test pin 8 on the BQ ok.
                  I have a scope that I bought 5 years ago but never used it
                  • bogart219
                    • May 2009
                    • 200
                    • usa
                    #169
                    Mich, do these two caps look like they they could be shorted? Maybe one or the other or both, I believe they are connected to each other. I tested them to gnd. with my meter in the diode mode and both beeped on both ends of the cap.
                    They are PC3005 AND PC3018 LOCATED NEAR PU3001. What say you?
                    • bogart219
                      • May 2009
                      • 200
                      • usa
                      #170
                      It probably doesn't make a difference but just to be sure: OK?
                      • m1ch43lzm
                        • Mar 2019
                        • 1075
                        • Peru
                        #171
                        Click image for larger version  Name:	image.jpg Views:	0 Size:	5.18 MB ID:	3668555
                        It depends on the reading on your meter; around 100 ohms, maybe a bit less, may be a bit higher is completely normal, as it's the 1.2V power supply for the RAM
                        Usually low voltage and high current supplies have low resistance to GND, how low, it depends; for example on a good working CPU the reading may be around 5-10 ohms, maybe a little less depending on CPU type
                        Measure again in resistance mode
                        Yes, both are in parallel. The reading should be the same at PJ3002 or PL3001​
                        Click image for larger version  Name:	Mos TI.jpg Views:	0 Size:	111.0 KB ID:	3668798​
                        Click image for larger version  Name:	Mos Anon.jpg Views:	0 Size:	106.7 KB ID:	3668799​
                        Those are slightly bigger in size (3.3mm*3.3mm) than the originals (3mm*3mm), which ones you received?
                        https://www.digikey.com/en/products/...6LDK-7/6010148
                        This one is the exact same size (3mm*3mm), has similar specs to the original (Id 46.2A, 7.5mOhm Rds(on))
                        • bogart219
                          • May 2009
                          • 200
                          • usa
                          #172
                          I'm confused now. I measured the original mosfet that I took off the board with a dial caliper and it measured 3.0mm x 3.0mm. The ones I got are 3.3mm x 3.3 mm as you said. The bigger ones are a pain in the ass cause you can't see any of the traces underneath it and I just centered it where I thought it looked the best.
                          Did you notice this?
                          Looking at the data sheets, the mos I got and the mos you found has a different Pin layout for the gate and source. Could this be the whole problem we are having? The one you found will work right?
                          Give me the word and I will order the ones you found!
Name:	sub mos 2.jpg
Name:	Mic mos 2.png
                          Wonder why the Digikey tech guy didn't suggest the one you found?
                          • m1ch43lzm
                            • Mar 2019
                            • 1075
                            • Peru
                            #173
                            Look where it says "Bottom view", it means you flip the MOSFET and you're looking at the solder pads
                            Top view is when you're looking at the case/markings
                            Both are correct, maybe on the Diodes one they labeled the pin numbers differently, but the order is the same if you look at the bottom side
                            Click image for larger version  Name:	sub mos 2.jpg Views:	0 Size:	162.5 KB ID:	3669245
                            Click image for larger version  Name:	Mic mos 2.png Views:	0 Size:	233.5 KB ID:	3669246
                            Here's the original one
                            Click image for larger version  Name:	sm3313.jpg Views:	0 Size:	124.0 KB ID:	3669295
                            And the AON7318
                            Click image for larger version  Name:	aon7318.png Views:	0 Size:	94.6 KB ID:	3669296
                            The AON7318 is slightly bigger, the pin order is the same if you look at the bottom
                            Same pin order with the DMT3006LDK
                            Also doesn't help that each manufactures labels their package type differently, but they're compatible, also that leads to confusion on 3*3 and 3.3*3.3 until you look at the mechanical drawings...
                            Did you tell him that you were looking for a replacement to the SM3313NSQG?
                            EDIT: Also, which version of the TPS65994 did you order? Was it the AD or AE?
                            Here's the AD version
                            https://www.digikey.com/en/products/...DRSLR/13245681
                            While you're there maybe order the RT6585C
                            https://www.digikey.com/en/products/...5cgqw/16376843
                            • bogart219
                              • May 2009
                              • 200
                              • usa
                              #174
                              Both are correct, maybe on the Diodes one they labeled the pin numbers differently, but the order is the same if you look at the bottom side Oh, ok
                              And the AON7318
                              Did you tell him that you were looking for a replacement to the SM3313NSQG? No, I told them what was written on the chip, SM 3313 PY1A8
                              Here is the TPS chip I ordered.
                              Do You want me to order this chip now?
                              So our mosfets appear to be right, Not sure about the TPS chip. I'm pretty sure I just typed in the info that was on the old chip and that is what it crossed over to.
                              Where do we go from here?
                              • m1ch43lzm
                                • Mar 2019
                                • 1075
                                • Peru
                                #175
                                On the MOSFETs, slight difference in packaging as the DFN3x3A-8_EP package from Sinopower is actually 3.3*3.3mm, according to the mechanical drawings
                                And the SM3313NSQG original ones are the DFN3x3D-8_EP package, slightly smaller 3*3mm
                                Had to look at several datasheets to be sure
                                Thst's why the new MOSFETs don't fit properly, they should align themselves when the solder melts, and when poking with tweezers
                                Another tip when soldering these type of packages, is to flux+tin the pads with the soldering iron on the part itself, just a bit on the center pad (no need to make a "pillow")
                                Reference video how to solder these packages (it's a QFN like the TPS65994), not in English but the technique is understandable, you'll notice he tins the pads on the IC itself, and also the board
                                https://www.youtube.com/watch?v=y-QKN2O3Xck
                                Or this one in short form, but somehow the solder wire appears from "nowhere" and he got a "dual needle" for flux, everyone has their own technique, you'll see how the chip aligns itself when the solder melts, and spits out some solder from the underside when pressed from above, but the part when he cleans up the excess solder is cut..., flux+soldering iron, then clean the iron tip
                                https://www.youtube.com/shorts/Iw6QAHNpFyQ
                                Also this one, skip to 16:00 to the part when he solders the MOSFETs
                                https://www.youtube.com/watch?v=DzIBOjPviwE
                                On the TPS65994AD you got from digikey, does it say "AD" below "TPS65994", or is it an empty line like the original one?
                                I found a picture of the "AE" version and it does say "AE" below "TPS65994"
                                At this point I'm not sure anymore what's the underlying fault, but I recommend to get new mosfets that fit properly, and just in case new TPS65994 and RT6585C
                                • bogart219
                                  • May 2009
                                  • 200
                                  • usa
                                  #176
                                  On the TPS65994AD you got from digikey, does it say "AD" below "TPS65994", or is it an empty line like the original one? Once more. here is the one I ordered and got from digikey.
                                  Click image for larger version  Name:	tps65994ae.jpg Views:	0 Size:	102.2 KB ID:	3669495
                                  I will order the "new " modfets that fit right and the two other chips you suggest. Thanks and talk to you in a few days!!!
                                  • bogart219
                                    • May 2009
                                    • 200
                                    • usa
                                    #177
                                    Mich, just to be clear, can you tell me what exactly what TPS chip I should order? This the mosfets I will order, DMT3006LDK-7, correct?
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 1075
                                      • Peru
                                      #178
                                      MOSFETs, get at least 4 https://www.digikey.com/en/products/...6LDK-7/6010148
                                      Just in case RT6585C https://www.digikey.com/en/products/...5cgqw/16376843
                                      Check the markings on the original TPS65994, if the next line is blank after "TPS65994" i think is the "AD" version, according to pictures from ebay/aliexpress sellers
                                      TPS65994
                                      (blank line)
                                      TI XXXXX
                                      YYYY ZZ
                                      TPS65994AD https://www.digikey.com/en/products/...DRSLR/13245681
                                      Also compare with the one you got from digikey, the XXXX YYYY are just date/lot codes
                                      I'm suggesting to get another one, as those ICs can be damaged with too much heat for long time; or if badly soldered
                                      Also solder it with leaded solder; tin the pads on the chip itself with leaded solder too before soldering it to the board
                                      If instead of the blank line it says something else, it's the "something else" version, example for the TPS65994AE:
                                      TPS65994
                                      AE
                                      TI XXXXX
                                      YYYY ZZ​
                                      Took measurements from the MOSFETs according to the boardview, as a reference I used the distance from one pad to next, the red square is exactly 3mm*3mm
                                      • bogart219
                                        • May 2009
                                        • 200
                                        • usa
                                        #179
                                        Hello. I'm going to order these, MOSFETs, get at least 4 https://www.digikey.com/en/products/...6LDK-7/6010148
                                        one of these RT6585C https://www.digikey.com/en/products/...5cgqw/16376843
                                        and one of theseTPS65994AD https://www.digikey.com/en/products/...DRSLR/13245681​
                                        Here is the original chip I believe
                                        and here is the one I bought fro dk before:
Name:	tps 2nd chip.bmp
                                        I'm going to practice my soldering in the mean time. Thanks for those youtube clips too btw. As always thank you my friend!
                                        • m1ch43lzm
                                          • Mar 2019
                                          • 1075
                                          • Peru
                                          #180
                                          The rest of the numbers on that TPS65994 are : TI 218 G2 A9D6 G4. I ordered another one from digikey when I ordered the mosfets but Mon2 said those have to be programmed. Is that something I can do if i get one of those inexpensive programming boards?
                                          Do you think I screwed that chip up, well yeah it was something I did cause it wasn't drawing 6-700 milliamps before I changed those mosfets out. I thought maybe one of those caps was shorted causing those readings on the TPS65994. Hopefully Mon2 has an idea. Thanks!
                                          Going back to this post on page 4, it's the AE version from your latest pictures; now which one was the original?
                                          Click image for larger version  Name:	tps 2nd chip.bmp Views:	0 Size:	5.93 MB ID:	3670357
                                          It says
                                          TPS65994
                                          AE
                                          TI 218G2
                                          A9D8 G4
                                          This one "AE" appears to be older, "218" maybe means year 2022, month 2 (february), maybe it's the original one after all?
                                          The other one "blank line" says "338", maybe 2023 , month 3 (march) (newer)?, since you said you ordered the "AD" version from Digikey, this one is the AD...
                                          Click image for larger version  Name:	Original tps.bmp Views:	0 Size:	5.93 MB ID:	3670356​
                                          Here's the link for the AE version, hopefully you can change your order
                                          https://www.digikey.com/en/products/...erslr/14634219
                                            Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:20 AM
                                            Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
