Asus f15 Fa506 no screen BQ24780s
  • greg1985
    • Oct 2023
    • 18
    • Polska
    Hi to All. Problem with laptop is no screen after power up. I have changes bios software many times and there is new bios chip also. Laptop still coming on with no picture.
    Every power line is present.
    I have noticed that in off Mode laptop take 7mA and then 10 to 16mA and coming back. Was interesting what is taking this current. Bq24780 is flickering. I check there is 2.6v, 6v, 18v present. Baterry is charging. What could be problem then? When i remove bios chip laptop takes 7mA only. Could be bios issue still or next step is kbc?
  • greg1985
    • Oct 2023
    • 18
    • Polska
    This is third BQ ic tested and still the same
    • mon2
      • Dec 2019
      • 14996
      Can you clarify this comment? Which exact battery charger IC was onboard the original logic board?
      • greg1985
        • Oct 2023
        • 18
        • Polska
        When laptop is connect to power, under thermal camera bq ic get hot, pulsuating. power supply shows 7 to 16mA. Also I've noticed strange voltage on BATFET gate - from 6.5 to 8volts and changing. There should be voltage from BQ ic connected by 4kohm resistor. But i dont know why this gate voltage changing.
        • greg1985
          • Oct 2023
          • 18
          • Polska
          Orginal is Bq24780s.
          • mon2
            • Dec 2019
            • 14996
            Part should not be heating up.
            1) Soldered in properly? Pin #1 to pin #1 on PCB? No solder shorts?
            2) Some offending interconnect is causing this fault. Flux and remove the batfet to test if the issue is resolved. Perhaps leaking?
            • greg1985
              • Oct 2023
              • 18
              • Polska
              Thank You for response. Yes i will do that. My next idea is also to take another laptop (diffrent company) but with the same BQ ic and check pin voltages also.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                If battery is charging fine,BQ24780S is unlikely to be faulty.
                Check powergood signals one by one.
                Mention the voltages on all coils after powering on.
                All_SYS_PWR_Good is present?
                • greg1985
                  • Oct 2023
                  • 18
                  • Polska
                  Thank You for reply. Update is: oscillating voltages on bq ic could be normal. Found on other forum voltages but not sure for 100%.
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    It was taken from a working device, it may help.
                    I'm not happy to be so strong. because it's not humanly
                    • greg1985
                      • Oct 2023
                      • 18
                      • Polska
                      Thank You.
                      • greg1985
                        • Oct 2023
                        • 18
                        • Polska
                        Update. Found missing resistor line 1.8v_gpu_aon.
                        Closed. Thanks for help.
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • FallenOne008
                          Asus G712L No Screen Backlight
                          by FallenOne008
                          Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                          The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                          03-31-2025, 08:27 PM
                        • kara
                          Asus GX501v keyboard not working - keyboard firmware - solved!
                          by kara
                          Hello, i had a problem with this laptop keyboard. not working even after replacing with new original palmrest.
                          Solution after hours of researching is using a small software found on asus forum !
                          https://rog-forum.asus.com/t5/rog-ga.../701169/page/6
                          Thank you Bogdan Ciulei
                          Finally some good news :
                          I have managed to fix the problem.
                          First,
                          I am not responsible for any damage you might do to your hardware !
                          YOU DO THIS AT YOUR OWN RISK ! I ONLY PROVIDE POINTERS , DO
                          12-09-2025, 02:27 AM
                        • reformatt
                          by reformatt
                          07-31-2025, 08:37 PM
                        • krige
                          asus g750js ms1130c (203) turns on nothing on the screen
                          by krige
                          hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
                          03-22-2024, 04:59 AM
