Dell Inspiron Mini 10 , 17v on power switch
  • degutji
    • Dec 2012
    • 173
    • Indonesia
    Have a nice day to u all,
    Need advice on MB KIU20 LA-9051P Dell Mini 10
    First Come with condition, Power on just for a few second and off,
    Plug power from my PSU show 0.002A - 0.025A, when I hit power on, the current not moving at all. JP42 ( on/off switch ) get 17v instead 3.3v as usual.
    5v and 3.3v is present, JBATT1 normal. What I have done :
    1. Flash Bios
    2. Reballing ICH7 Chip
    Problem still there...
    Actually there is Acer As 4937G with same problem power switch got 17v.
    Need advice from you all, what next...?
    Best Regards
  • degutji
    • Dec 2012
    • 173
    • Indonesia
    Re: Dell Inspiron Mini 10 , 17v on power switch
    • cephei328
      sparky
      • Feb 2014
      • 49
      • NewZealand
      Hi mate,
      This is strange issue which happens on some motherboards
      I have face this issue mostly in Acer motherboards where you will have 17 volts near power button instead of 3.3 volts
      But when you check pin 117 in EC/SIO chip it will read 3.3 volts.
      I have solved this issue by replacing BIOS chip (re-flashed) in Acer motherboard once.
      So try replacing BIOS chip
      Also check PQ1 on page 30.
      Good Luck
      • degutji
        • Dec 2012
        • 173
        • Indonesia
        Thx Cephei
        re-flash bios chip with working one that I save before, exactly model and type.
        Yes Indeed, you are correct, on EC/SIO pin#117 and #32 it have 3.3v
        PQ1 on #1,2 read 17volts and #3 read 18volts
        Is it normal ?
        • cephei328
          sparky
          • Feb 2014
          • 49
          • NewZealand
          No its not normal. it should read 3.3 Volts
          Check PC9 for short
          • degutji
            • Dec 2012
            • 173
            • Indonesia
            Check PC9 for short
            No short on PC9 and PC10
            (Take out from MB and test with DMM)
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              17v is normal at 51_ON# upon plugging in the adapter. It should go low to 3.3v when you press the power button.
              Check pin 100 of SIO for 3.3v before/after power button is pressed. This will indicate if BIOS is working normally.
              • degutji
                • Dec 2012
                • 173
                • Indonesia
                Thx for your replies whaldsz
                there is no 3.3v before and after , it's that mean bios problem ?
                • degutji
                  • Dec 2012
                  • 173
                  • Indonesia
                  • whaldsz
                    • Apr 2013
                    • 395
                    • Philippines
                    possibly yes. try reflash the BIOS then check for 3.3v at RSMRST# again.
                    • atsio
                      • Oct 2013
                      • 819
                      • Greece
                      Your problem probably has to do with PQ1.
                      • arieshenri
                        • Jul 2011
                        • 10
                        Hi there, Just want to share my case.
                        Sometimes on some laptop, 17-18v on power switch is normal. Try hitting power button, then turn off, then check voltage on power switch, if it goes back to 3.3v, then it is normal. I also don't know why it happens.
                        For turn on then turn off after a couple seconds, i have this experience where gate on 5valw to 5vs switching mosfet have abnormal voltage. So 5valw is having 5v then try hitting power button - gate has voltage from ec / chipset (i forgot). But the output on 5vs is less than 5v (it was around 3-4v). Then assuming mosfet is broken, try finding replacement and replace the mosfet. Then try hitting power button, power drop has gone, 5vs has 5v. Then laptop working properly. Try tracing the alw voltage to vs voltage switching.
                        Hopefully it has the same problem that i have experienced.
                        • arieshenri
                          • Jul 2011
                          • 10
                          Bios problem usually is related to rsmrst# and s5_enable. But try it anyway, because it will not do any harm as long you have backup the original rom / bin.
                          • ponga
                            • Nov 2012
                            • 10
                            • united arab emirates
                            i just repair one acer at your same case, 17v on power pin, but in my case i found some corrosion in the motherboard, i just clean the corrosion, and i found a cold solder in the corrosion part. RESOLDER AND DONE..
                            • degutji
                              • Dec 2012
                              • 173
                              • Indonesia
                              Thx whaldsz, Still same, no 3.3v before and after ( flashing bios 2x )
                              Thx Atsio, replaced PQ1 but no change, still 17v
                              Thx arieshenri, I'll try that
                              Thx ponga, already do that before, maybe I miss on that area, I'll try any possible
                              • degutji
                                • Dec 2012
                                • 173
                                • Indonesia
                                Still can't find on the problem is..
                                • whaldsz
                                  • Apr 2013
                                  • 395
                                  • Philippines
                                  then you need to replace the SIO chip. also check if the crystal is giving out 32.768Khz.
                                  • atsio
                                    • Oct 2013
                                    • 819
                                    • Greece
                                    51_ON# should be low in order to open PQ1's gate. 51_ON# is geting low when EC_ON is high. No RTC voltage, something is stoping SIO from raising that signal. Check for shortages on coils, and if OK, replace SIO.
                                    • dspok
                                      • Jan 2014
                                      • 553
                                      • Nepal
                                      I have same problem today, did you manage to solve it?
                                      • polytek
                                        • Dec 2013
                                        • 496
                                        • TUNISIA
                                        hi, look at page 28, if the gate of Q12 is shorted to source, the 3.3V become 17V,
                                        check if Q12 is shorted, if yes replace and try to mesure again.
                                        • LimesKey
                                          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                                          by LimesKey
                                          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                                          10-17-2025, 05:33 PM
                                        • Powderfanupnorf
                                          Dell AL440LX power on switch circuit help required
                                          by Powderfanupnorf
                                          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                          06-24-2024, 01:24 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • Tomylee
                                          Dell Inspiron 15 3511 – Won’t power on after plugging in, one chip gets extremely hot
                                          by Tomylee
                                          I have a Dell Inspiron 15 3511 that stopped turning on after my friend plugged in the power adapter.
                                          Here’s what I’ve checked so far:
                                          No reaction when pressing the power button (no LEDs, no fan).
                                          The power adapter works fine (tested).
                                          One chip gets extremely hot as soon as I plug in the charger.
                                          The capacitors around that area are not shorted.
                                          I’m attaching photos of the board to show the issue.
                                          Based on this, what kind of fault or defective component could be related to this overheating?...
                                          10-19-2025, 12:24 PM
