HP DV6 6080ep - GPU ATI
    Hello!
    A friend of mine brought his DV6 with GPU problems.
    The laptop has intel integrated graphics and an ATI gpu.
    A month ago, he was unable to enable the ATI and could only work with the laptop with the integrated Intel graphics.
    He told also that the laptop when turning on, if the fan would start full speed, we would'nt turn on.
    To work on it he had allways to force the Intel graphics, most of the times removing the plug to force battery mode.
    If the ATI was activated in Windows, the image would come blurry and unreadable.
    Well, I removed the BGA and cleaned it. Reballed it and tested it.
    When I booted into windows I allways get a BSOD related to atipackage.
    Installed a fresh OS, laptop works fine until I try to install the ATI.
    Mesured the SMD's on the chip and found 4 of them with 0.6 ohm (see picture).
    Any thoughts?
    BGA is dead?
    Should I order a new one?
    Another issue is that the BGA has the code unreadable, and so I dont know wich BGA order to replace this one in case of need.
    Waiting for your follow ups!
    Thanks!
    Re: HP DV6 6080ep - GPU ATI
    Hello!
    Update : the BSOD is the atikmdag.sys.
      Some screens of the Gpuz before installing ATI drivers
      Nice temps and core clock
        check this out
        http://forums.guru3d.com/showthread.php?t=363233
          The 0.6 ohm in 4 of the small capacitors isn't a sign of bad BGA chip?
          Could it be just a software/drivers issue?
            Well bought an ATI 216-0752001 new chip.
            Gonna wait for him to arrive and put him on the board... and see if the issues are gone!
              If you can't install the driver of the old chip after you reflowed or reballed it, you must replace it.
                This chipset is known to be faulty.
                Change it to be sure.
                  indeed, you need to replace this chip.
                    Waiting for the BGA to arrive and gonna swap it
                    I'll share the results...
                    thanks!
                      Hello!
                      After a big mess with getting the right BGA from the supplier, I got the correct one a few days go.
                      So I attached him to the board and ... working like a charm!
                      A few pics.
                      Thanks for all the help!
                      Cheers,
                        Great job magneh!
                          Hello!
                          A few pics.
                          Cheers,
                          that chip got more one type of balls?
                          what size did you use?
                            dj_ricoh best chip source you can get BRAND NEW , factory sealed .. GOLDEN CHIPSET ...since started to buy from them .. never had any troubles or machines coming back .. altough very good prices.
                              good job, thanks
                                Can you guys share the link of the store. Is that on ebay or Aliexpree?
                                  first time i bought something from them was about 490$
                                  all seems ok to what they sell
                                  ps: good work magneh
                                    Hmm to be honest for new chips they aren't that expensive actually quite a good price .
