Asus tuf fa507r BSOD
  • guyandpit
    • Oct 2021
    • 78
    • Philippines
    Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
  • Sephir0th
    • Oct 2020
    • 1283
    It will probably need a very detailed inspection of the exposed areas from a very experienced technician. And you even didn't share any pictures so far. So not sure how you planned to approach the fault with the given informations.
    especially with this history
    FairRepair on YouTube
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
    • trbovan
      Asus GL731GT Boot loop
      by trbovan
      Laptop is a GL731GT with the I7-9750h and GTX1650.
      Full model number is gl731gt-rb71-cb
      Serial: (placeholder for when I get home)
      Board model: G531GT REV. 1.5
      Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
      I assembled and tested anyway. The bios worked, I was able...
      10-04-2023, 07:27 AM
    • jrodefeld
      Asus laptop won't boot (no power) - possible bad caps?
      by jrodefeld
      I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
      The model:
      Asus Zenbook Pro Duo UX582L
      I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
      However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
      09-02-2024, 04:55 PM
    • lukkihapsi
      Asus Vivobook X515JA Weird Boot Issue
      by lukkihapsi
      Asus Vivobook X515JA Laptop
      Issue :
      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
      Tried :
      Cleaned inside for dust, applied fresh thermal paste. No Change!
      Removed keyboard, Trackpad, fingerprint sensor. No Change!
      Removed Internal SSD. No Change!
      Updated BIOS to latest version. No Change!
      Removed battery and pressing power button for 1 minute. No Change!
      Weird Part :
      Upon turning laptop ON, screen lights up - stays black,
      I...
      07-07-2025, 12:07 PM
    • futadmytro
      Asus g713qm-es94 stuck on boot bios problem
      by futadmytro
      sn^M4NRKD02753616E
      MB- g533-6050a3250201-MB-A03
      Stuck on boot after ROG logo, did not enter to bios
      In flash bios , laprop boot but have video issue
      orig bios...
      06-25-2025, 08:07 AM
