Acer Nitro5 (N20C2) doesn't charghe battery
  • shybear
    • Jan 2010
    • 105
    hi,
    I don't figure out why this laptop doesn't charge battery. At first I thought it was the original battery that showed charged at 100% didnt' work at all. So I bought a new battery that is recognized from operating system and shows its charging. orange charge LED is on but keep it under charge dosen't charge! So I downloaded board schematic (Compal LA-L191P rev. 1C) and find out that D-S of PQ 201 give 1.7 ohm no matter if battery is connected or not but gate result insulated from drain and source. So i moved away mosfet and on board short disappear but testing mosfet looks working. Anyway I had here an other Compal board with same component and I replaced it with any success. Power adapter is orginal and using a lab power supply from laptop in shut down orange charge LED is on but current rise just to 0,03 A.
    Between + and GND there is just 1,5V and on pin 7-8 and GND just 3,2V. I'm sure that the new battery works properly because I tested it on an other same laptop. I attach the picture of schematic Really thanks in advance for some support.
  • mon2
    • Dec 2019
    • 14660
    Attach the power adapter. Meter in DC volts mode (30v or higher is ok).
    Measure the voltage to ground on each pin on DCin mosfet PQB11.
    Interested in the voltage on
    1-2-3 (source);
    4 (gate)
    5-6-7-8 (drain)
    PUB1 (charger IC):
    pin 28 (Vcc)
    pin 24 (REGN)
    pin 6 (ACDET
    • shybear
      • Jan 2010
      • 105
      Thanks mon2 for reply.
      Laptop isnt' mine and the owner didn't sat me anything but on the internal side of back cover I noticed some trace of possibile liquid and there some little trace of liquid (maybe coffee or coke) on the right side of ram socket . (ref. Nitro5.jpg)
      I still didnt' dismount mainboard thing that I finished to make right now.
      There were also a great trace of oxide and PUB1 was really in bad condiction. (ref. PUB1.jpg)
      I cleaned carefully all and lucky pcb stil looks in good shpe and also PUB1 looks like (ref.PUB1_OK.jpg) ok and doesn't over heat if I power board.
      Cleaned it solved the weird short between drain and source of PQ 201.
      As asked here's valuse you asked me for:
      PQB11 (near DC power socket):
      1-2-3 (source): 19,7 V
      4 (gate): 25,5 V
      5-6-7-8 (drain): 19.7 V
      PUB1 (charger IC):
      pin 28 (Vcc): 19,37 V
      pin 24 (REGN): 6,0 V
      pin 6 (ACDET): 2,6 V
      Battery isn't still charching but as before is recognizd from Windows and looks like its charching, also orange LED is still on.
      Waiting for your opinion about voltage values.
      • mon2
        • Dec 2019
        • 14660
        The charger IC looks really bad but the cleaned up is improved. Be sure every part is clean of any corrosion. Use the TI datasheet to locate the battery charge mosfets. Then remove all power -> measure the resistance of each mosfet linked to the battery. It is possible that you have a leaky high side mosfet that is used to dial up the charge voltage for the battery unit.
        The posted voltages (above) all look correct.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Dont use such cheap quality flux. Use atleast a flux like AMTECH
          • shybear
            • Jan 2010
            • 105
            I think the PUB1 works properly. Also mosfet PQB1 - PQB2 and PQB13 looks good - no shorts. I've a doubt that something doesn't works as expected because +17.4V_BATT_CHG is just 4,9V even if on pin 5-6-7-8 of PQB13 there are correctly 19V
            • mon2
              • Dec 2019
              • 14660
              Carefully, measure the voltage to ground on each pin on this charger IC.
              Also suggest to remove all power -> no battery -> meter in resistance mode -> measure the resistance between the battery charge current leg on the charger IC. Measure directly on the charger IC. The full path resistance must be very close to the resistance in the schematic. What is the resistance in ohms of this path?
              The battery is still a suspect unless you are testing this exact battery on the same logic board in another box.
              • shybear
                • Jan 2010
                • 105
                If I understand well if I measure restitance between PIN 27 (PHASE LX_CHRG) and +17.4V_BATT (i.e. pin1 of PCB28) I get 30 ohm.
                • mon2
                  • Dec 2019
                  • 14660
                  No. Remove all power. Meter in resistance mode. One meter probe on pin # 19 of PUB1. Other meter probe on pin # 20 of PUB1. What is the resistance in ohms?
                  We are checking the full path resistance of the current sense loop circuit used by the battery.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    PQ201 working properly? What is the voltage on battery connector pins
                    01.Only adapter
                    02.Adapter+battery
                    • shybear
                      • Jan 2010
                      • 105
                      ah ok. I didn't understand exactly your first message so I detailed exactly where I made measurment. In the meanwhile following your suggestions I wanted to check better battery so I charghed it directily connecting to power supply. When I put on laptop again and started operating system battery LED was still orange but at the end of operating system turned to blue and battery level showd 100%. So I disconnevted power adapter and laptop didnt' shut off but battery level went down to 99% so I plugged again power adapter and battery LED went orange for like 1 minute and next turned blue again and battery went to 100%. I supposed that all worked fine! Next I wanted to make a double check leaving battery discharge at 91% and next I plugged again power adapter but even if system says battery charge level doesn't rise up staying at 91%.
                      Going to resistance values of PUB1 you asked me for are:
                      pin #19 - GND arounf 9 MB (rising to infinite)
                      pin #20 - GND 65K
                      • shybear
                        • Jan 2010
                        • 105
                        01.Only adapter
                        02.Adapter+battery
                        Testing PQ 201 works fine.
                        On battery connector PJP201:
                        without connecting battery: 4,98 V
                        with (charghed) battery 16,1 V
                        • mon2
                          • Dec 2019
                          • 14660
                          We still need to confirm the path resistance between pins # 19 & # 20 on the charger IC.
                          From post #9 - Remove all power. Meter in resistance mode. One meter probe on pin # 19 of PUB1. Other meter probe on pin # 20 of PUB1. What is the resistance in ohms?
                          We are checking the full path resistance of the current sense loop circuit used by the battery.​
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            You need to post voltage on all pins of battery connector and not the positive pinonly as asked in post#10
                            • shybear
                              • Jan 2010
                              • 105
                              Ouch forgive me! I was reading your message too quick.
                              On PUB1:
                              pin #19 - pin #20 resistance (with no power) is: 20 ohm
                              • shybear
                                • Jan 2010
                                • 105
                                PJP201 battery connector voltage:
                                pin# ______no bat__ charghed bat (orange led ON)
                                1 - 2_____ GND____ GND
                                3________ 3,2 V____ 3,2 V
                                4 ________3,2 V____ 3,2 V
                                5________ 3.1 V______ 153 mV
                                6__________ 0 V_____ 0 V
                                7 - 8______ 4,9 V___ 16,2 V
                                • mon2
                                  • Dec 2019
                                  • 14660
                                  The current sense path for the battery leg is fine.
                                  Remove all power. Meter in diode mode. Test the dual diode @ PDB1. The diode should conduct in one direction (red on anode; black on common cathode) but should block in reverse. Test both diodes.
                                  • shybear
                                    • Jan 2010
                                    • 105
                                    Put black on PIN 1 and positive on PIN 2 or PIN 3 give 0,605V on reverse blocked
                                    • mon2
                                      • Dec 2019
                                      • 14660
                                      Conducts in both directions? Flux and remove this part. Test again while it is off the board. Careful to not lose this tiny part. Been there.
                                      • shybear
                                        • Jan 2010
                                        • 105
                                        Yep before to remove I tested again. Now I removed PQB1 and it just give 0,6V if I put - on PIN1 and + on PIN3. Right now I put back this component and works fine., but battery still doesntì charge.
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • Klevjetack
                                          Charge a L19D3PDA battery externally from the laptop
                                          by Klevjetack
                                          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                          03-05-2024, 07:26 AM
                                        • dclass-pro
                                          Latitude 3301 not charge battery
                                          by dclass-pro
                                          Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                                          I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                                          I noticed 2 things:
                                          1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                                          2) if I try to turn it on without the battery...
                                          05-06-2025, 06:19 AM
