Acer Nitro5 (N20C2) doesn't charghe battery
  • mon2
    • 14657
    When you attach the battery and power adapter for charging, what is the voltage to ground on PLB2 inductor (either side is ok to measure)?
    What is the voltage to ground of ACDET (pin 6) on PUB1?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Try putting a jumper between GND and pin5 of battery connector and then test again.
      • shybear
        • Jan 2010
        • 105
        hi I'm back! Followed your instructions, with battey plugged in and power adapter connected (orange LED on) I have:
        > 15,7V on PLB2
        > 2,6 V ACDET (pin6 of PUB1
        • shybear
          • Jan 2010
          • 105
          If I put pin5 on GND and next I plug battery and power adapter orange charching LED stay off and same results with power adapter connected or disconnected:on PJP201 battery connector:
          0V (GND) on pins 1 - 2 - 5
          3,2V on pins 3 - 4
          0V on pin 6
          15,7V on pins 7 - 8
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Acer's have a battery switch and needs to be pressed for charging to start. have you checked that?
            • shybear
              • Jan 2010
              • 105
              #26
              I dont' see any switch on the board, anyway sounds strange that as you say charcge must to be started pressiing this switch because if charging isnt' working how come that the orange charging LED is on when power adapter is connected?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                SW3 near edp connector. press this switch and check if charging starts.
                • shybear
                  • Jan 2010
                  • 105
                  #28
                  Get it, there isn't a phisical button so I shorted it with solder, but nothing. I also tried before to close SW3 shorting BI GATE to ground and next plug battery and insert power adapter. The only thing that happen is that ORANGE LED power on but on battery connector there is just 15,8V with battery and 5V without it.
                  Anyway for sure SW3 start the cherge circuit becauuse while I was making test happened that orange LED didn't light ON and shorting SW3 make it light on, but currente move just 300mA
                  • techfreak9356
                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                    by techfreak9356
                    09-14-2023, 11:10 PM
                  • razenxd
                    How can I charge that battery pack?
                    by razenxd
                    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                    Now, I have noticed a few things.
                    The "dead" battery, while connected to charger and NOT Charging will...
                    12-05-2024, 06:11 AM
                  • ruletero
                    Acer a515-43 low battery charge voltage
                    by ruletero
                    Hi
                    Acer A515-43
                    LA-H801P
                    Fail: Does not charge battery, has low voltaje on connector.
                    Laptop didn't want to turn on, only charge led blinked.
                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                    10-24-2022, 02:31 PM
                  • Klevjetack
                    Charge a L19D3PDA battery externally from the laptop
                    by Klevjetack
                    Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                    03-05-2024, 07:26 AM
                  • dclass-pro
                    Latitude 3301 not charge battery
                    by dclass-pro
                    Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                    I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                    I noticed 2 things:
                    1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                    2) if I try to turn it on without the battery...
                    05-06-2025, 06:19 AM
