HP 625 only starts up when it wants to
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I've done a few of those already so i didn't expect trouble, but this one seems to be intent on giving me a headache.
    It powered up but didn't display anything at all. No blink codes either.
    Replaced NB - same thing.
    Flashed the BIOS - at first it blinked the CPU error code on the Caps Lock, then after a few attempts it started working and displayed fine. Turned it off and on again and it doesn't work anymore... Also, it started blinking Caps Lock continuously.
    Thinking i've got a dud chip, i reballed the original NB and put it back. It does exactly the same deal. Either 1 blink or continuous blinks of Caps Lock. It did display once, and was able to get in the BIOS and mess around with things, but as soon as i restarted it it's dead again.
    I think it is impossible for both NBs to be faulty in exactly the same way. It immediately recognizes if there is no RAM in and blinks the appropriate code (also on the POST card), and it takes longer for it to start blinking if i put in more RAM, so i would guess that the NB is fine and it's something else it's getting stuck at.
    POST card reports it gets stuck at either "7B" or "15" if that helps anyone.
    A working TV? How boring!
    • 30979
    Re: HP 625 only starts up when it wants to
    maybe the bios is gone again.
    if it's one of those serial chips then they can fail sometimes by randomly losing bits.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      hp 625 have ATI HD 3200IGP which is always problem. try to reheat.
      • atsio
        • Oct 2013
        • 819
        • Greece
        It mostly points to a CPU error or a communication error of DIMM slots to CPU. Have you asked the customer if laptop had a fall incident?
        You can check it by checking continuity of rails between CPU and DIMM slots (on the dimm, not dimm pads) but is a labouries work.
        At least you can resolder dimm slots and reflow CPU socket.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          Th3_uN1Qu3> WHAT KIND OF POST CARD U R USING?
          • loser18
            • Nov 2013
            • 274
            Try this
            This helped me many times (especially on dv5s)
            -Take out CPU & mems
            -hold pwr button for 20-30 sec without psu
            -connect psu & start laptop without anything
            -put the mems in, but without cpu
            -then take out mems start with only cpu
            -now you should get 3 blink code which indicates mems problem
            -put the mems in & should come up
            It doesn't make any sense to me, but sometimes works...
            Also noticed, when I've took the cpu off the bad board & put to 100% working one, had 1 cont. blink code (CPU) anyway...
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              I'm using the "Debug King" POST card.
              Don't think it's the socket but i may give that a go... thanks. I don't know whether it took a fall or not, but it may have.
              BIOS was completely dead (not recognized by programmer), has been replaced by new one. I'm 100% sure this chip is okay.
              It's HD4250 actually, and i have already replaced it twice with the same result.
              • gcomputers
                • Apr 2013
                • 509
                • Albania
                i have the same problem now just replaced NB with new , flashed bios , changed Cpu same problem 1 blink and no display . any idea please
                • polytek
                  • Dec 2013
                  • 496
                  • TUNISIA
                  hi Th3_uN1Qu3,
                  yesterday, i was working on dell inspiron N5040, that give 7 beeps code of cpu,
                  i have repalced cpu but steel beeping, but when i repalace the cpu regulator that was isl95831, display come and no beep sound, try to replace your cpu regulator and see if it help, good luck friend.
                  • dj_ricoh
                    • 2073
                    • uk
                    Originally posted by polytek
                    hi Th3_uN1Qu3,
                    hy mate!
                    can you tell me what give it away ?
                    like how did you knew it was bad?
                    thanks
                    • gcomputers
                      • Apr 2013
                      • 509
                      • Albania
                      I have another funtional hp 625 tested on it Cpu and ram are functional also i get the it Dump flashed but the same problem , 1 blink .
                      • gcomputers
                        • Apr 2013
                        • 509
                        • Albania
                        hi Th3_uN1Qu3,
                        Look if have Ati NB reflow it.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3577
                          • slovakia
                          have same 6735s. one blink. reballed, replaced still one blink.
                          this ati igp systems is worst ic in the world. but giving me lot of work so it is good
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            This is shaping up to be close to the nvidia fiasco of 2005-2009... But still, those AMD chips fail in lesser numbers and most of them are fine for a long time after reballing. Here it's more a case of bad thermal management. Most of the laptops with these chipsets have poor cooling, and many do not even monitor the temperature of the chipset.
                            • polytek
                              • Dec 2013
                              • 496
                              • TUNISIA
                              Originally posted by dj_ricoh
                              hy mate!
                              thanks
                              the cpu volatge is not stable, and cpu not getting hot, i check all mosfet and caps and coil for poor conatact, then i have replaced the isl95831
                              • chaos-theory
                                Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                by chaos-theory
                                I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                03-14-2025, 05:37 PM
                              • arabex21
                                Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
                                by arabex21
                                Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
                                I have a problem with this configuration:
                                ASUS PRIME B450M-A
                                RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
                                When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
                                09-19-2024, 03:05 AM
                              • IamPritesh
                                Help - Auto starts after 1 minute of shutdown - Dell vegas/turis 15341-1
                                by IamPritesh
                                I have two such machines which is having this issue. After shutdown the system starts on its own in a minute. It does not start immediately. It takes around 20-40 seconds before it starts again on its own. This is driving me crazy and not sure where to start ..
                                Some very important points :
                                • Laptop does not auto starts after shutdown if adapter is connected.
                                • It will only auto start after shutdown if the laptop is in BATTERY only mode.
                                • I have tried replacing batteries with a known
                                • if I shutdown the laptop with adapter connected and lets say remove the adapter after 5-10
                                09-24-2021, 05:01 AM
                              • rumpumpel1
                                ThinkPad T490s only starts with battery
                                by rumpumpel1
                                I am testing a ThinkPad T490s with this setup: only the bare mainboard NM-B891 with a fan and the small Power-On daughterboard as well as with a USB-C monitor (no BIOS battery!).
                                If I connect a battery, the mainboard starts up normally. After about 50 seconds the logo appears and after another 30 seconds the final message “... System configuration is invalid. Press Esc to continue or F1 to enter setup”.
                                If I connect the power supply unit instead of the battery, a USB meter shows the usual fluctuating power consumption for approx. 30 seconds, then the mainboard switches off...
                                12-02-2024, 01:42 PM
                              • Gjackson
                                LCD Tv starts to display black horizontal lines after half an hour of use
                                by Gjackson
                                Hi, I have a sort of old Grundig LCD Led TV that starts to display black horizontal lines after some use. After it's been turned off for a while and cold it does not display any artifacts however after some use it starts to display some faint horizontal lines at the top of the screen and a bunch in the middle of the screen. The longer the tv is on the worse they get until they become very clearly visible. I suspect that heat has something to do with this as when the lines start to appear i notice that the tv's metal case has gotten warm. Could the T-CON start to malfunction when it starts to get...
                                01-31-2022, 02:25 PM
