Sony VPCSB - Plugged in but not charging.
  • orientalsniper
    • Apr 2013
    • 459
    Hello all, there's this MBX-237 I've just repaired (will post solution after I fix this issue in my other thread) but it won't charge the battery, I'm sure the battery is fine.
    In Windows, it shows "Plugged in, not charging" and the battery LED keeps flashing nonstop.
    I've tried different BIOS'es.
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Re: Sony VPCSB - Plugged in but not charging.
    I have a friend with the same issue, I still haven't checked with him but I read somewhere to try power reset, if it doesn't work, remove battery, disable TPM (?) in BIOS, uninstall battery checker and insert it after.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
    • mohamed.mostafa
      • Sep 2012
      • 40
      • egypt
      hello
      i faced this issue after repairing it .
      i found that the connector cables " between MB and charging small board" need to be fixed with Adhesive tape.
      sorry for Weak language
      • orientalsniper
        • Apr 2013
        • 459
        Yeah, I made sure the cables are making contact, I've:
        1) Flashed different BIOS'es.
        2) Pressed the battery off button underneath with a needle.
        3) I don't see TPM in the BIOS, I don't think this model has it.
        4) This is a clean system, so no Sony bloatware.
        EDIT: The battery LED is solid in the first 5 seconds when laptop is being turned on, then it starts blinking nonstop, therefore the motherboard knows the battery is installed but is not being detected somehow.
        • orientalsniper
          • Apr 2013
          • 459
          I attached the docking board (charger IC) schematic, does anyone have any idea what are the battery signals and how to test them?
          EDIT: Attached a photo of AIDA64, battery is detected as Sony, but status and capacity are not being detected.
          • Learn2Day
            • Jun 2013
            • 254
            • Portugal
            Hey,
            I'm way too noob to talk about this with any true knowledge of the facts but from what I've researched, I believe this issue is in the battery itself and it's related to critical low levels. My friend tested the battery in another Sony laptop and the light still blinks.
            Isn't your battery also on low/critical level?
            Try Harder!
            • orientalsniper
              • Apr 2013
              • 459
              Yes! It blinks nonstop which means it's on critical level (0%), so did your friend tried another battery to confirm?
              • Learn2Day
                • Jun 2013
                • 254
                • Portugal
                He didn't tried another battery, he tried his battery on another laptop.
                Try Harder!
                • Learn2Day
                  • Jun 2013
                  • 254
                  • Portugal
                  Dunno if this helps but..
                  https://www.youtube.com/watch?v=qr2pchS-N-0
                  http://forum.notebookreview.com/sony...w-battery.html
                  https://bbs.archlinux.org/viewtopic.php?id=123624
                  Try Harder!
                  • orientalsniper
                    • Apr 2013
                    • 459
                    Thank you, if he could confirm with another battery that would be great.
                    Regardings the links:
                    1) That's Vaio Battery Care, it limits charge to 70%-80% I think, the laptop I'm working on won't go past 0%, besides it's a clean install with no Sony bloatware.
                    2 & 3) Those applied for the old models (VGN), I had fixed those before with a modded BIOS, but the new models are different (UEFI) and besides I already flashed different BIOS'es including flashing a modded one with advanced menu.
                    I found the battery signals which are: B_BAT+, DAT_SMB, CLK_SMB, BATT_PRS#, SYS_PRS#, BATT_ID, however I'm told I require an oscilloscope to check those signals.
                    My last resort to is to find a way to test this battery, any ideas anyone.
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      Hey,
                      My tested his laptop with another battery and it worked fine. It's confirmed, problem is in the batteries itself.
                      Try Harder!
                      • Learn2Day
                        • Jun 2013
                        • 254
                        • Portugal
                        Hey OS,
                        Do you have any news on this?
                        Thanks.
                        Try Harder!
                        • orientalsniper
                          • Apr 2013
                          • 459
                          Hello, sorry, but I don't have another battery to test laptop with, but the laptop had been in repair for 5 months and battery was never used, I think it could be the battery, but it's all speculation at the moment.
                          • Learn2Day
                            • Jun 2013
                            • 254
                            • Portugal
                            Thanks. If you come up with a solution or need any tests I could perform like earlier, post back.
                            Thanks again, L2D.
                            Try Harder!
                            • Learn2Day
                              • Jun 2013
                              • 254
                              • Portugal
                              Sniper, could you please see if this helps?
                              this happened to me one night, out of the blue. the battery refused to charge. i let it charge overnight, and it went from 4% charge to 8% charge in 8 hours, and the light kept blinking. HWiNFO64 showed the charge rate to be extremely low. i tried everything, and even took the battery out and pressed the power button for 30 seconds to discharge the internal capacitors to presumably reset the laptop. nothing worked. i then went in VAIO Control Center and disabled the Battery Care function, and re-enabled it after a minute, and everything returned to normal all of a sudden! very weird.
                              BIOS might also cause problems related to this..
                              R2087H4 Changelog:
                              The computer intermittently does not charge the battery.
                              The computer may shutdown at random.
                              The computer may not resume from standby or hibernation
                              The computer may hang, freeze, (stop responding) or is unable to start Windows® after POST
                              Reduces fan noise
                              The computer may hang or freeze, (stop responding) during playback of a High Definition video while using battery power
                              The computer may display No Boot / No OS Found errors due to a failure in communication between the BIOS and the Hard Drive
                              Unable to login to the computer due to a critical battery message when starting Windows using battery power
                              Battery status shows as "Not present" when the battery is fully charged
                              R2085H4 changelog:
                              The computer may not resume from standby or hibernation modes
                              The computer may hang, freeze (stop responding), or is unable to start Windows® after POST
                              Reduces fan noise
                              The computer may hang or freeze (stop responding), during playback of High Definition video when running on battery power
                              The computer may display "No Boot" or "No OS Found" errors due to a failure in communications between the BIOS and the Hard Drive
                              Resolves an issue where the user is unable to login to the computer due to a critical battery message when starting Windows when using the battery to power the computer
                              The battery status shows as "Not present" when the battery is fully charged
                              Try Harder!
                              • netosuper
                                • Jul 2014
                                • Brasil
                                I'm having the same problem. Have bought an original new battery and keeps blinking the LED battery after about 30 seconds. If I press the reset the battery it is with the battery attached and led back to flash after 30 seconds. While the LED is lit it raises the voltage to about 11.20v. After 30 seconds, comes back to the present battery voltage. His problem was solved?
                                Digital oscilloscope have here, but I have no deep knowledge of electronics. If someone can guide me check some signals.
                                Translated by google!
                                • orientalsniper
                                  • Apr 2013
                                  • 459
                                  I didn't solve it, I assumed the battery was having problems.
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3588
                                    • slovakia
                                    check all pins of charger ic to chceck if it aint poroblem with it
                                    • bicalov
                                      • Nov 2014
                                      • 294
                                      • Netherlands
                                      VPCEB2S1E: Same issue here. After repair and after installing all drivers.
                                      About the next day problem start. Blinking bat led and system will not go on. Only when the battery was taken out.
                                      Deleted Sony control center and put in battery and everything acted normal again.
                                      • Farrukh Zaib
                                        • Mar 2017
                                        • Pakistan
                                        I have vpcsa model and it shows plugged in and not charging and charging light keeps on flashing i tried to install the nios but it stops on say that you have updated Bios no need to install i just wanted to know how can i install the BIOS completely and how can i resolve the issue for battet assistance sharing pics.
