Macbook a1707 820-00281 Battery no Power
  • leonemax81
    • Nov 2015
    • 57
    • italia
    #41
    C7023 black probe to GND pin 1 and pin 2 high resistance over 1,200 kohm, while if I put black probe on pin 1 and red probe on pin 2 I measure 2.7 ohms.
    • leonemax81
      • Nov 2015
      • 57
      • italia
      #42
      also replaced R6950 without success.
      • mon2
        • 14677
        2R7 sounds high. Confirm the resistance across R7021. Then test resistance across R7022. Each should be 1 ohm.
        Also confirm again the dual diode @ D6902. Be sure that it is not leaking. Measure in diode mode in each direction with your meter. Respectively, the output voltage to ground of this dual diode @ pin 3 must be stable. Then voltage to ground of PP3V3_G3H @ R6923 must be stable. Check both sides of this resistor @ R6923.
        • leonemax81
          • Nov 2015
          • 57
          • italia
          #44
          resistor R7021 R7022 I confirm they are 1ohm, when the battery plate is connected I have all the voltages in loop, even the PP3V3_G3H voltage, while with the plate not connected, the voltages are ok.
          • mon2
            • 14677
            Is the battery with a charge? What is the voltage on the battery? If there is a voltage, can the laptop power up with only the battery? (no power adapter)
            Is the battery mosfet Q7065 on or off the board?
            • leonemax81
              • Nov 2015
              • 57
              • italia
              #46
              the battery is 74% charged, the laptop does not turn on with the battery connected, as I have said several times as soon as I connect the black flat cable the Mac does not turn on the USB ports loop up to 5V, the mosfet without the battery has voltage, with battery I have no voltage.
              • leonemax81
                • Nov 2015
                • 57
                • italia
                #47
                also replaced the D6902 diode several times, without success.
                • mon2
                  • 14677
                  Disconnect the battery. Connect the battery flex. Power up with the power adapter.
                  What is the voltage to ground of:
                  Q7065, pins 5-6-7-8 = Drain = PPVBAT_G3H_CONN
                  Q7065, pins 1-2-3 (source)
                  Q7065, pin 4 (gate)
                  • leonemax81
                    • Nov 2015
                    • 57
                    • italia
                    #49
                    with only the black cable connected to the battery. mosfet:
                    Q7065 pin 1.2.3.5.6.7.8 voltage 0.998 v
                    Q7065 pin 4 gate 0.0v
                    while with black cable disconnected:
                    Q7065 pin 1.2.3. voltage 12.61 v
                    Q7065 pin 5.6.7.8 voltage 12.61 then drops 11.45v in loop.
                    Q7065 pin 4 gate 4.5v then rises 12.61v then drops 4.5v in loop.​
                    • leonemax81
                      • Nov 2015
                      • 57
                      • italia
                      #50
                      with black battery flex cable disconnected:
                      SMBUS_SMC_5_G3_SCL voltage 3.41v then drops 3.23v in loop.
                      SMBUS_SMC_5_G3_SDA voltage 3.41v then drops 3.23v in loop.
                      with black battery flex cable connected:
                      SMBUS_SMC_5_G3_SCL voltage 2.95v then drops 0.900v in loop.
                      SMBUS_SMC_5_G3_SDA voltage 2.95v then drops 0.900v in loop.
                      • leonemax81
                        • Nov 2015
                        • 57
                        • italia
                        #51
                        replaced Q7065 twice without success.
                        • leonemax81
                          • Nov 2015
                          • 57
                          • italia
                          #52
                          hi friend do you have another suggestion, this board is making me lose my mind, thanks so much for the help.
                          • leonemax81
                            • Nov 2015
                            • 57
                            • italia
                            #53
                            could it be a bad CD3215 chip? when the battery is connected it doesn't work well?.
                            • mon2
                              • 14677
                              Confirm the resistance to ground of pin # 1 of the battery flex while it is connected to the logic board. Do not believe it is the CD3215.
                              • leonemax81
                                • Nov 2015
                                • 57
                                • italia
                                #55
                                should I check the SYS_DETECT_L signal with battery flex connected if it goes to low signal?
                                • mon2
                                  • 14677
                                  Yes. We wish to be sure that this line is parked with the pull-down resistor of 10k and not floating. You will still measure the 0v if the line is floating. We need to be sure this line is parked to a logic low.
                                  • leonemax81
                                    • Nov 2015
                                    • 57
                                    • italia
                                    #57
                                    with only the black cable connected 3,700 kohm
                                    • mon2
                                      • 14677
                                      What are the details of your power adapter?
                                      macbook a1707 820-00928 - Badcaps
                                      * post # 22
                                      I think you will be ok if using a 100W PD adapter with a certified 100W cable.
                                      • leonemax81
                                        • Nov 2015
                                        • 57
                                        • italia
                                        #59
                                        I use a bench power supply, and the macbook starts with my bench power supply.
                                        • leonemax81
                                          • Nov 2015
                                          • 57
                                          • italia
                                          #60
                                          I have repaired many machines with this power supply, never had any problems of any kind, it is not a power supply.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • PITERPENY
                                            Macbook A1707 820-00928 battery replacement
                                            by PITERPENY
                                            brought in a working MacBook for battery replacement (swelled up). After replacing the battery it stopped turning on. tried connecting the old battery without changes. consumption with the battery connected and without the battery is the same 5v\0.200a on all 4 ports. replacing 9239 did not help
                                            04-20-2025, 03:22 PM
                                          • AdrenalinTL
                                            Macbook Pro A1707 - Dead - Battery 'popped'
                                            by AdrenalinTL
                                            Hi Peeps.
                                            Just a quick question please as I am by no means an Apple fundi at all.
                                            Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                                            Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                                            Don't want to go buy a battery for no reason.
                                            Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                                            07-18-2024, 09:52 AM
                                          • gboone
                                            820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                                            by gboone
                                            Hi, I was given this laptop by my uncle who said:
                                            • It would occasionally shutdown if not plugged in
                                            • battery had been replaced
                                            • touchbar would "strobe"
                                            I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                                            After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                                            BUT
                                            When powered off, it would at some point have a...
                                            01-27-2025, 09:12 AM
                                          • kurland
                                            MacBook A1707 - low batt sign displayed then shutdown - but battery voltage is ok!?
                                            by kurland
                                            Hi fellow repair gurus,
                                            Liquid damaged A1707 was stuck on 5V. I replaced corroded CD3215 and SMC now successfully raises voltage to 20v.
                                            The fans spin, the screen comes on and displays a "low battery" sign before the machine shuts down.
                                            After that the screen and fan stays off but PPBUS_G3H continue to toggle every 4-5 secs between
                                            • 11.4v (and 170mA current draw on usb-c power meter)
                                            • 12.6v (zero current draw)
                                            The toggeling occurs when battery is connected but regardless if external usb-c is connected or not. It seems...
                                            10-21-2022, 02:04 PM
