Macbook a1707 820-00281 Battery no Power
  • mon2
    • 14732
    What are the details of your bench power supply? Can it support 100W?
    MacBook Pro 2017 board 820-00928 with missing PPBUS | Rossmanngroup Forums
    * post # 10
    • leonemax81
      • Nov 2015
      • 57
      • italia
      #62
      of course I support 100w, I never had problems, I already repaired many A1707 machines with this power supply, I also have the original 87w apple power supply for the macbook and the defect is the same.
      • leonemax81
        • Nov 2015
        • 57
        • italia
        #63
        replaced U7000 for the third time with ISL9239C0, I read that it is compatible, nothing usual defect does not work with battery connected.😡
        • leonemax81
          • Nov 2015
          • 57
          • italia
          #64
          honestly this macbook is boring me, is there a way to turn it on without the battery? the customer is fine even without the battery.
          • leonemax81
            • Nov 2015
            • 57
            • italia
            #65
            with the original 87w power supply the low battery symbol appears and it does not turn on, can this be bypassed?
            • mon2
              • 14732
              Maybe losing track of the many permutations but thought this laptop boots fine if the battery flex is not connected. So leave the battery disconnected.
              • mon2
                • 14732
                interesting. this thread is pointing back to the battery
                A1707 820-00928 erratic 5V+bootloop on USB-C | Rossmanngroup Forums
                • leonemax81
                  • Nov 2015
                  • 57
                  • italia
                  #68
                  I have an 87w power supply, it doesn't turn on, the low battery symbol appears, can I bypass it?
                  • mon2
                    • 14732
                    Is your 87W power supply with captive or removable USB Type C cable? If removable, is the type C cable certified for 100W use? Such a cable will contain an e-marker IC inside of the cable connector ends. We typically use only 100W marked cables with our type C power adapters for the beefier macbook repairs.
                    Summary from assorted sites including this thread:
                    a) adapter - test with another 100W rated adapter
                    b) battery - test with another known good battery
                    A1707 2017 15” Pro won't turn on without battery? : r/macbookrepair (reddit.com)
                    • leonemax81
                      • Nov 2015
                      • 57
                      • italia
                      #70
                      solved it was the thin cable, put 100W cable and it starts without battery, thanks for the help.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • PITERPENY
                        Macbook A1707 820-00928 battery replacement
                        by PITERPENY
                        brought in a working MacBook for battery replacement (swelled up). After replacing the battery it stopped turning on. tried connecting the old battery without changes. consumption with the battery connected and without the battery is the same 5v\0.200a on all 4 ports. replacing 9239 did not help
                        04-20-2025, 03:22 PM
                      • silver60618
                        Macbook Pro A1990 - Battery not detected after connector torn off
                        by silver60618
                        Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
                        Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
                        11-12-2025, 06:36 PM
                      • AdrenalinTL
                        Macbook Pro A1707 - Dead - Battery 'popped'
                        by AdrenalinTL
                        Hi Peeps.
                        Just a quick question please as I am by no means an Apple fundi at all.
                        Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                        Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                        Don't want to go buy a battery for no reason.
                        Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                        07-18-2024, 09:52 AM
                      • gboone
                        820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                        by gboone
                        Hi, I was given this laptop by my uncle who said:
                        • It would occasionally shutdown if not plugged in
                        • battery had been replaced
                        • touchbar would "strobe"
                        I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                        After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                        BUT
                        When powered off, it would at some point have a...
                        01-27-2025, 09:12 AM
