You have 20v so believe the cd3215 are working.
macbook a1707 820-00928
For A1707 models You must use an exact 87W OEM Apple brick. For some odd reason the board does not like anything less or more. Hope this helps.sigpic
MEOWING IN THE IMPOSSIBLE UNIVERSE!Comment
so I rewrote several options for the OS, including with a clean region, the board consumption is still = 0V, substitution from other boards also did not give anything! I installed a BIOS chip from this board onto another one and it starts it up! Apparently we need to look for the reason elsewhere (
What is the voltage to ground of the following points? Given that your PPBUS_G3H is boosted, these lines should be ok but do confirm it. Along with the current PPBUS_G3H voltage to ground.
SMBUS_SMC_5_G3_SCL
SMBUS_SMC_5_G3_SDA
After you attempt to power up, what is the current draw ? Stuck @ 0A ? What is PPBUS_G3H? Stable voltage till you unplug the adapter?Comment
by CG_DionysosHello,
I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:- Model: A1707
- 15-inch, Mid 2017
- 3.1 GHz Core i7
- 16 GB RAM
- Radeon Pro 560
- 1 TB SSD
- Board number: 820-00928-A
Thanks in advance!
Greetings from Germany...-
09-16-2025, 06:43 AM -
by leonemax81Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM -
by jesihi all techs
require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
update:
when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...08-23-2025, 02:35 PM -
by tommy97Hi,
I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
I've also replaced U6300, but the problem persists.
Here are the current voltage readings:- PPV18_S0: 1.8V
- R6402: 1V
- R6405: 1V
- R6403: 1V
- AUD_SPKRAMP_RESET_L: 1.3V
- PPBUS: 12.6V
- Loading...
I fiddled with it for 2 weeks, replaced the PCH (U1100) and the MacBook came to life. therefore, if A1707 consumes 0.000A, I think 99% of PCH(U1100) should be replaced.
