Lenovo N500 - No power
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hi, i have this lenovo N500 that wont start. It wont spin fan.
    I found that rail i marked on picture is shorted with ground (13ohm) but i cannot find where, please help.
    ...the quieter you become the more you are able to hear...
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: Lenovo N500 - No power
    PQ18 is OK, and PQ12 does not exist
    • khaahk
      • Dec 2013
      • 769
      • Estonia
      13 ohm is normal resistance for vga chip.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        ok, i found that one MOSFET have oscilating voltages.
        • khaahk
          • Dec 2013
          • 769
          • Estonia
          With battery connected? Without?
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            Without, i do not have battery
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              hi, if notebook doesnt start, first look for usual 3v and 5v always if present or not. then we can go on PL10 PL11 coil. check 3 and 5 volt here
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                i have 3V and 5V for few seconds, then it go to 0V
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  the ovner of laptop say that it worked on battery, but no charger. Is this the PU10 fail?
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    if with battery charged it works ill focus more on the dcin circuit rather then charger problem
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      ok, i check PU10 and i found that VIN have oscilating voltage 8v to 14v
                      • rtstorm
                        • Feb 2012
                        • 971
                        • Croatia
                        Pq42 ok
                        • khaahk
                          • Dec 2013
                          • 769
                          • Estonia
                          If the owner is correct, then pu10 should be fine, look for the charger ic PU1 fault or circuit around it.
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            ok i found that PQ38 have oscilating voltages on D
                            • rtstorm
                              • Feb 2012
                              • 971
                              • Croatia
                              check PQ38 IT IS ok, I TRY TO REMOVE PL12 and then on PQ38 i have stable 17V. Is this the PU1 fail?
                              • spleenharvester
                                • Mar 2010
                                • 902
                                By VIN do you mean the +ve voltage point on the DC jack itself?
                                If so check for continuity between the ground nearest to the oscillating voltage points and the ground on the barrel of the DC plug. A good adapter wouldn't work when loaded to 8v. You may have an open ground somewhere.
                                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                                • rtstorm
                                  • Feb 2012
                                  • 971
                                  • Croatia
                                  i mean VIN marked on PU10
                                  • spleenharvester
                                    • Mar 2010
                                    • 902
                                    Oh yeah I see. So no oscillation at the DC jack?
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      no, on DC jack i have 19V. In this rail i have oscilate voltages.
                                      • spleenharvester
                                        • Mar 2010
                                        • 902
                                        Firstly that CHG_B+ rail is confusing me, it doesn't seem to connect to anything else on the schematic. But that aside for now, I would try removing PQ5 and seeing if that has the same effect. I doubt the ceramic caps are shorted or else it would be dead. It looks to me like something closest to the CHG_B+ side of PL12 is causing the oscillation, not PU10 itself.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Mita99
                                          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                          by Mita99
                                          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                          04-27-2025, 07:20 PM
                                        • Dr.d
                                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                          by Dr.d
                                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                          04-05-2024, 11:48 AM
