A1708, 820-00840-A, 20V but stuck at 0.045A
  • Theking3737
    • Aug 2024
    • 9
    • Netherlands
    I've recently acquired a 13 inch MacBook Pro 13 2017 (A1708, 820-00840-A). I bought it with the intention of trying to fix it and learn a thing or two about electronics repair along the way. So I've never repaired or even had another MacBook or Apple product before actually. However, I do have some experience with designing and producing my own PCB's so I do have some equipment like hot air station, oscilloscope, microscope, hot plate, etc at home. Today I received my USB ammeter and got to work.
    The USB ammeter first showed 5V and after a few seconds it was up to 20V, so if I understand correctly that means that both of the CD3215 IC's are doing great. But of course I bought the thing as defective and that showed... When it reached 20V I noticed it got stuck at 0.045A. Weirdly enough it got stuck at exactly 0.04500A. Sometimes it would briefly go a few decimals off but then quickly go back to exactly 0.04500A.
    The seller mentioned that the device broke after trying to upgrade the replaceable SSD.
    When measuring with the USB ammeter I had already removed the logic board from the case so I moved on to measuring some voltages with a multimeter.
    PPBUS_G3H 12.96V
    PP3V3_S5 0V
    PP5V_S4 0V
    PP3V3_G3H 3.38V
    PP5V_S5 0V
    PP1V8_S5G 0V
    PPBUS_G3H_CPU 12.96V
    PPBUS_G3H_SSD 12.96V
    P3V3S5_EN 0V
    P5VS4_EN 0V
    P1VOPC_EN 0V
    I wonder if anyone has some tips for me on how to continue and what to measure next. I know someone who has a FLIR camera which I could borrow if necessary to better visualize voltage injection.
    Thanks in advance
  • mon2
    • Dec 2019
    • 14667
    Remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor (usually grey in color; 2 leads). Checking for lower than normal resistance to ground. Report any suspects for a review.
    • Theking3737
      • Aug 2024
      • 9
      • Netherlands
      Here are some measurements. The ones I left out were all super high resistance, usually in the MΩ range.
      L7430 2.1 Ω
      L7410 2.1 Ω
      L7420 2.1 Ω
      L7210 4.1 Ω
      L7370 6.5 Ω
      L8060 0.4 Ω
      L7900 0.4 Ω
      L8030 212 Ω
      L7960 35.9 Ω
      L7690 0.5 Ω
      L7900 seems to be dead short to ground. This kinda worries me since I saw it's connected to the PCH...
      • mon2
        • Dec 2019
        • 14667
        L7690 0.5 Ω
        = PP3V3_S5
        This is a show stopper. You have a shorted part on this rail. Would you have an adjustable power supply? Consider to use it at 1 volt (to be safe; not higher) and inject onto this inductor. Whomever is shorted will heat up and/or crack under the injection pressure. Often it is a shorted capacitor. The PCH may be also low but start with this review and hunt down the suspect.
        • piernov
          • Jan 2016
          • 4439
          • France
          3 power rails going to the PCH shorted to ground? Conclusion should be pretty obvious, no point in wasting time.
          • Theking3737
            • Aug 2024
            • 9
            • Netherlands
            I tried the voltage injection at L7690 but my power supply can't do more than 3A. It was near impossible to spot or feel anything heat up. I also tried pouring some IPA on the board but it didn't really help. I think I saw the alcohol evaporate a tiny bit quicker near the PCH, but it could just be my mind thinking I saw that because it seems likely to me that there's a fault there. I will try to borrow a FLIR camera next week and have a better look at it. I'm doing this purely as a hobby project and to learn a thing or two so there's basically nothing to lose at this point. I will update the post if I find something.
            Could it be helpful to desolder L7900 or L8060 and see on which pad the short is on?
            • Theking3737
              • Aug 2024
              • 9
              • Netherlands
              The PCH is dead...
              • crnimrki
                • Nov 2024
                • 11
                HI.
                I have similar problem as here described. Same board, similar resistance on inductors:
                L7430
                L7430 5,1
                L7410 5,1
                L7420 5,8
                L7210 14,2
                L7370 23,3
                L8060 0,9
                L7900 1,6
                L8030 145
                L7960 81
                L7690 1,3
                7220 14
                When I inject 1V on L7690 current is 1,5 A and can not locate any heated element with the IPA method.
                Does anyone have an idea how to more closely locate the short circuit?
                Thank you all.
                • mon2
                  • Dec 2019
                  • 14667
                  L7690 is a power rail (PP3V3_S5) that feeds many sections of the board including the PCH / CPU. Remove the heatsink off the CPU. Test again to see if the PCH is heating up.
                  • crnimrki
                    • Nov 2024
                    • 11
                    With 1V there is no warming on the CPU.
                    • mon2
                      • Dec 2019
                      • 14667
                      A thermal camera will really be helpful here. Suspecting a shorted capacitor. You can also consider a low ESR meter used to measure in the milli-ohm range for components. This process will then demand to test each and every part on the board to hunt for the shorted component.
                      Alternatively, but in my opinion risky, is to check if there is a path from this shorted one to the CPU rail / any low voltage rail on the board. If not, only then you can consider to use a higher voltage to 'smoke' out the shorted component. We are using a product called 'short killer' which is dialed up to 0v8 (by us) but will spike out 20A/30A surges. This combination cracks up the target part in seconds. No can hind under this pressure. Purchased it from Aliexpress. A good variable power supply should also be ample. Can you push out 5A or more on yours?
                      • crnimrki
                        • Nov 2024
                        • 11
                        Unfortunately my power supply can only output 3A. I'll try to borrow a thermal camera somewhere. Thanks.
                        Question: Is there anyone who can borrow a thermal camera in the Nuremberg area (Germany)?
                        • mon2
                          • Dec 2019
                          • 14667
                          You can always try Amazon and return it as "do not need it anymore". There are a few good ones that mate to the phone. If you truly wish to purchase one, then review the detailed threads on eevblog:
                          https://www.eevblog.com/forum/thermal-imaging/
                          These days, consider one with 25Hz refresh rate.
                          • crnimrki
                            • Nov 2024
                            • 11
                            It's unlikely that this would help, at 1V the current doesn't rise above 1.5 A. All that remains is for me to try with a higher voltage. What is the upper limit that would be relatively safe?
                            Unfortunately, my 30 power supply doesn't go below 8V.​
                            • mon2
                              • Dec 2019
                              • 14667
                              Officially, the max voltage is the voltage value defined by the circuit. The concerns are, what is someone on this rail is leaking onto another lower voltage rail. For that reason, the general rule is to keep the voltage as high as the lowest voltage on the logic board which is often 0v8 to 1v0.
                              Suggest to inject the 1v0 onto the same rail, then hunt and measure each inductor on the logic board to test if there is a voltage from this injection present downstream.
                              You can also, measure the resistance from this rail to each and every inductor on the board. Do you see a short between the points of tests? No power of course during resistance checks.
                              • Stunt
                                Hp Laptop Stuck on Hp protected by hp sure start screen
                                by Stunt
                                Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                screen that's it and stuck there. I left it until the following day and i still...
                                09-02-2025, 01:51 PM
                              • EpicFix
                                MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                                by EpicFix
                                Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                                04-08-2025, 09:55 AM
                              • stormanimal83
                                Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                by stormanimal83
                                Hey....
                                Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                01-18-2024, 02:15 PM
                              • ekozeko333
                                [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                by ekozeko333
                                I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                🔥 The Problem Started After Suspected ESD/PD Fault
                                I experienced a power issue or ESD event through a USB-C charger
                                After that, the NX20P5090 power switch was visibly burned and was replaced
                                Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                🧠 What I’ve Done So Far
                                Flashed...
                                06-21-2025, 02:48 AM
                              • mon2
                                A1708 stuck @ 20V, 34mA on charger
                                by mon2
                                Hi. Welcome feedback on this logic board.
                                820-00840
                                Client complained that it was not charging the battery. We originally took the logic board apart for measurements and found the logic board was working ok. Gave it back to the client and requested they bring it back for a battery replacement (charge cycles ~950 on the original battery).
                                Now the logic board is not booting, much like their original complaint about it being flaky.
                                Charger shows 20v @ 34mA / 33mA on Type C meter.
                                PPBUS_G3H @ 0v. No shorts. Current sense resistors...
                                12-06-2021, 11:05 AM
