asus g750js ms1130c (203) turns on nothing on the screen
  • krige
    computertech
    • Nov 2022
    • 21
    • south africa
    hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?
  • krige
    computertech
    • Nov 2022
    • 21
    • south africa
    solved
      • 21968
      Originally posted by krige
      solved
      What was the problem
      • krige
        computertech
        • Nov 2022
        • 21
        • south africa
        i opened up my screen and on the inside under tape was a torn screen cable. no way to repair unless i order a new screen. the cable is made that way.
        • krige
          computertech
          • Nov 2022
          • 21
          • south africa
          thanks for the interest
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • frannyjunk
            Hisense 40H4F no backlight but turns off after splash screen
            by frannyjunk
            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
            TIA.
            09-24-2025, 10:59 AM
          • FallenOne008
            Asus G712L No Screen Backlight
            by FallenOne008
            Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
            The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
            03-31-2025, 08:27 PM
          • Rav_tangle
            MacBook Pro 2011 turns on with keyboard light , screen dead
            by Rav_tangle
            Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
            I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
            Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
            is this...
            05-31-2024, 04:09 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
