Usb voltage 5v to 0v
  • lgf700b
    • Oct 2013
    • 16
    • Turkey
    Hello everyone. I have a LA-4854p Acer mobo with broken usb ports. This mobo have only 2 usb ports and both broken. I pulled out old ports and soldered new ones. Board worked well. I checked new soldered usb pins. No short circuits and checked 5v voltage. But there is a problem. When i plug in an usb device, 5v drops to 0v.
    I checked pins of D23 , C538 , U28. They are all working properly. What should i do.
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Usb voltage 5v to 0v
    check that you have not fitted the wrong usb ie usb1
    • lgf700b
      • Oct 2013
      • 16
      • Turkey
      Checked and desoldered both sockets but nothing changed. Still 5 to 0v.
      • lgf700b
        • Oct 2013
        • 16
        • Turkey
        I'm getting closer. When something plugged to usb, board cuts power. Something is making short circuit with usb but what? By the way i replaced U28 too.
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          Make sure you check the proper positioning of the port you just soldered.
          A few months ago I made a mistake of replacing the port. The port is almost identical until I noticed that the inside pins are inverted. Check the images I attached. hope this helps
          • lgf700b
            • Oct 2013
            • 16
            • Turkey
            You know i just figured it. My ports are reversed ones. Thank you man.
            • lezsimply
              The Wanderer
              • 645
              • Philippines
              No problem
              • tomodachi
                • Apr 2012
                • 602
                • Turkey
                Happened me once before, good u noticed quickly
                • cyberhack
                  • Feb 2013
                  • 466
                  • Uk
                  did tell him to check that he has not fitted usb 1 instead of usb 2 in the 1 post oh well
                  • sasser
                    • Dec 2012
                    • 364
                    • Malaysia
                    so it means lgf700b not fitted well usb1 and usb2? is that different
                    • sasser
                      • Dec 2012
                      • 364
                      • Malaysia
                      im also face with this problem i replace with the new one usb port. actually both i pull out from another acer machine. till now usb cant detect but 5v is present.
                      • lgf700b
                        • Oct 2013
                        • 16
                        • Turkey
                        I fixed that board yesterday. I didnt have laptops bottom case so i didnt figured that ports reversed.
                        • sasser
                          • Dec 2012
                          • 364
                          • Malaysia
                          oh im understand reversed mean u soldered in wrong position right.
                          • lezsimply
                            The Wanderer
                            • 645
                            • Philippines
                            in some way yes, check post #5. same solder points but different pinouts.
                            • Instafixx
                              Macbook A2179 820-01958
                              by Instafixx
                              Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                              The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                              I checked the Power Sequences below and found this -
                              Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                              PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                              PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                              05-20-2023, 05:19 AM
                            • Fernon@Repair
                              Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                              by Fernon@Repair
                              i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                              VCCIO voltage ok
                              VCCSA Voltage OK
                              VCCPLL Voltage OK
                              Ram Voltage ok
                              RamVTT OK
                              VPP 2.5 OK
                              But No Core Voltage
                              and i want to this vrm ic datasheet or pinout (ISL69269)
                              anyone have this ic pinout voltages?...
                              06-25-2025, 07:19 AM
                            • electron_jj
                              Panasonic TH-L42D25A checking the PSU output voltage
                              by electron_jj
                              Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                              I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                              08-29-2021, 08:13 AM
                              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                              Based on Intersil's Robust Ripple Regulator...
                              11-05-2024, 03:24 PM
