820-0085-a no power/ no charge
  • pantsos
    • Feb 2021
    • 13
    Hey there,
    I have a MacBook 820-0085-a that was working perfectly, after keyboard replacement the MacBook would not charge any more. As we speak the battery might be completely dead. I think that this MacBook need a battery to boot up.
    I have a very limited experience with newer MacBooks. If anyone would suggest where to start taking measurements or testing, I would appreciate it.
    All I know is that the MacBook was working perfect before the keyboard switch.
    A tech confirmed that he used a universal charger.
    Thank you
  • mon2
    • Dec 2019
    • 14662
    I think you mean 820-00850 logic board.
    Do you have a USB Type C meter? To confirm, even after the keyboard was replaced, only the battery would not charge?
    Remove all power. Meter in resistance mode. Measure the resistance to ground of each pin on the battery connector. It is ok to remove the battery and then probe the pins on the battery connector that is on the logic board.
    No battery / no power adapter during these tests. You can use the metal shield for the ground on the logic board.
    Pins # 2 & # 3 are of the most interest. These are the SDA / SCL lines which are the SMBUS / I2C lines used to communicate with the battery BMS inside of the battery pack.
    Post each measurement.
    • mosfetratus
      Sure Not
      • Feb 2019
      • 174
      • Resistron
      It needs to be fully assembled so the pins on the board are grounded. Otherwise board will act as dead.
      • pantsos
        • Feb 2021
        • 13
        Click image for larger version  Name:	J6951.png Views:	43 Size:	364.7 KB ID:	3235090
        Thank you for getting back to me.
        You are correct the model is 820-00850.
        after the keyboard replace whoever replaced it said that it would be possible to turn it on, but didn't charge.
        me I never saw the MacBook turning on.
        Yes I do have usb c meter tester.
        i think on the downside of the usb c port have different behavior that the top ones.
        Measuring the battery in diode mode connector it seems that everything is good.
        j6951
        Pins:
        1)0,5
        2) 0.8
        3)0.8
        4) OL
        5) GND
        6) OL
        • mon2
          • Dec 2019
          • 14662
          What is the voltage to ground on pin #2 of the battery connector? Red probe on pin # 2; black probe to ground.
          Repeat for pin #3 of the battery connector. Post each voltage measurement.
          What voltage and current draw is showing on your USB Type C meter? It should be 20V if working properly.
          • pantsos
            • Feb 2021
            • 13
            The board is out. Plugged in with the charger only, pin 2 and pin 3 have the same behavior.
            rapid changes in number that I can not even read, but every 2-3 seconds I see 0.000 and then playing and mostly i think there is a short somewhere.
            USB C meter shows 5V and amps starting 0.19A goes to 0.49A and then hangs at 0.19 and then goes to 0.50A
            if I plug it in the second plug USB C port, 0.00 I see 0.31 and then again 0.00. I
            • pantsos
              • Feb 2021
              • 13
              I guess my issue is not that simple?
              • mon2
                • Dec 2019
                • 14662
                Carefully measure the voltage (meter in DC volts mode @ 20v or higher scale) of PPBUS_G3H @ fuse F7000. Check both sides of this fuse. What is the voltage? Is it stable?
                What is your USB Type C meter reporting for the adapter voltage? Adapter current being used by the logic board? Post all observations. For a normal board to boot, the adapter voltage should be @ 20 volts.
                • pantsos
                  • Feb 2021
                  • 13
                  This board has 4 usb c ports. Each side, the top ones starting from 3V and then slowly goes down to 0.3V.
                  the bottom ones is not stable. It plays from 8-10V all the way down and then up again in 1-2 seconds.
                  type c meter is the SATECHI.
                  The way I test it is the board is completely out and only connect the usb c port while plugged with the usb c meter and then the original charging adaptor
                  • mon2
                    • Dec 2019
                    • 14662
                    1) Is the power adapter the original and recommended model for this laptop?
                    2) The USB-C meter is reporting 3v down to 0v3? What is 8-10V and then power cycles? Is this the voltage measurement @ fuse F7000 = PPBUS_G3H​ to ground?
                    • pantsos
                      • Feb 2021
                      • 13
                      1)Yes it's the original 61W that comes with the laptop.
                      2) The USB meter is stable at 5V and I see 0.15A and when I check voltage on F7000 the voltage starts at 2.9V and then slowly goes down.
                      The bottom port I see again 5V and then power cycles 0.00A and then 0.45 then 0.35A then back to 0.00
                      For these measurements I use DC on my multimeter black probe to ground and red probe on F7000 on both sides
                      • mon2
                        • Dec 2019
                        • 14662
                        Remove all power. Meter in resistance mode (not diode mode). Measure the resistance to ground at F7000 (check both sides). Post the measurement. Suggest to flux and remove F7000 off the logic board.
                        Then power up again. Measure the DC voltage to ground of F7000 @ pcb pad of the removed fuse. Do you now have a stable voltage at PPBUS_G3H​ ?
                        • pantsos
                          • Feb 2021
                          • 13
                          Power is off. Multimeter in resistance mode with the F7000 removed. One side I get 3.9 MΩ. Other side I get 16.40 MΩ.
                          Power on with the fuse still removed DC voltage one side 0.100V stable - other side 0.316V stable
                          • mon2
                            • Dec 2019
                            • 14662
                            The resistance is good for both sides of the removed fuse F7000.
                            Where do you observe this voltage range?
                            • pantsos
                              • Feb 2021
                              • 13
                              Bottom usb c ports when I connect power measuring in DC with F7000 on the board.
                              • pantsos
                                • Feb 2021
                                • 13
                                Just checked again the bottom usb c port power in with f7000 removed - one side DC voltage is 0.005V and the other side is 12.30V
                                top port with f7000 removed power in in DC one side is 0.005 and other side is 1.420V
                                • SarcasticOP
                                  General question about MacBook power rails for repair.
                                  by SarcasticOP
                                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                  • PPBUS_G3H (12.6V-12.8V)
                                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                  • PP3V42_G3H (3.42V)
                                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                  • PPVRTC_G3H (3.3V)
                                    • This
                                  12-12-2024, 05:50 PM
                                • Schluchti45
                                  MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
                                  by Schluchti45
                                  i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
                                  Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
                                  11-18-2024, 02:05 AM
                                • platinumsteel
                                  Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
                                  by platinumsteel
                                  Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
                                  03-03-2023, 10:17 AM
                                • leonemax81
                                  Macbook a1707 820-00281 Battery no Power
                                  by leonemax81
                                  Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                  08-23-2024, 09:24 AM
