MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
  • Schluchti45
    • Oct 2024
    • 6
    • Austria
    i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
    Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
  • mon2
    • 14735
    If available as an option, consider to source yet another known good battery from Amazon or similar. This is only to rule out the battery as a defect (which is quite possible). You can always return the battery back to Amazon if it is not required. Aside from this, you will need proper tools like a multimeter + screwdriver set to open up the unit for inspection. Hot air soldering tools or someone with these if parts need to be replaced.
    Ifixit is apparently a stable outfit for parts so you can ask them if they have come across DOA batteries. Assuming not, we need to dig deeper to take some measurements.
    Can you post a good pic of what the Coconut Battery tool reveals?
    • piernov
      • Jan 2016
      • 4439
      • France
      Heard from other technicians that iFixit batteries are no better than other random suppliers. They may provide a little bit better customer service than the cheapest Aliexpress listing though…
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Do the fans spin when you turn on the computer while the battery is connected? If so this would rule out that the battery is defective even if it is new. Very common to get bad batteries from suppliers. It is always better to remove a pre-owned battery and reseal it from an A2141 if you have that chance. They seem to be more reliable than new ones lately.
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • Schluchti45
          • Oct 2024
          • 6
          • Austria
          ​the fans turn when the battery is connected but only with the power supply but it is not charged.
          • oxonater
            • Oct 2012
            • 77
            • uk
            Hi
            Sounds silly but do you have the correct BMU flex had a few issues myself in the past with these (even new ones supplied by Apple)
            Make sure there is a good connection failing this I/O boards could also be and issue have you tried all 4 ports with same result ?
            • mon2
              • 14735
              This logic board was able to charge the battery ok before this replacement?
              The BMS (battery management) flex cable is separate from the rather beefier cabling used to power the unit. Is the larger & beefier cable firmly attached to the main board? The logic board will be able to detect the serial #, brand of the battery using the smaller BMS / BMU flex cable but will show 0 charge current if the other cable is not properly mating with the logic board.
              Be sure the wide head screw has been applied to pressure fit the battery pcb contacts onto the main logic board. If that is missing or is a loose fit, the charge current will be 0A as showing in your posted screens.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • silver60618
                Macbook Pro A1990 - Battery not detected after connector torn off
                by silver60618
                Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
                Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
                11-12-2025, 06:36 PM
              • gboone
                820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
                by gboone
                Hi, I was given this laptop by my uncle who said:
                • It would occasionally shutdown if not plugged in
                • battery had been replaced
                • touchbar would "strobe"
                I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
                After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
                BUT
                When powered off, it would at some point have a...
                01-27-2025, 09:12 AM
              • felix27
                Macbook air M3 Battery
                by felix27
                i have a Macbook air M3 15 inch (820-03286) which had some water damage, everything works now but battery charging. Sadly i currently do not have another Battery to test, and want to find out if Battery behaviour is normal before wasting time searching for non existant board problem. Cell voltage is 3.7V for each single Cell but shorting SYS_DETECT_L does not result in any output voltage. Is 3.7V to enable output with SYS_DETECT_L shorted? Macbook shows 65536 Cycles and service recommended so i2c communication seems to be broken. If battery is disconnected it shows normal values...
                11-05-2025, 04:00 PM
              • mferna14
                MacBook Air A2681 battery problem after Screen Replacement
                by mferna14
                Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                12-06-2024, 08:10 PM
