Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
  • arevut
    • Mar 2019
    • 17
    • Ukraine
    #41
    Originally posted by mon2
    For a good mosfet, these are low resistance measurements. Carefully, flux and remove this mosfet off the board and test using the same method after the mosfet has cooled down and on your work bench. Confirm if the measurements remain this low or not.
    Hi. I ordered new mosfets and today I replaced old with the new one. And... nothing changed. When I disconnect the battery the voltage in PPBUS_G3H is normalizing to 13V. When I connect the battery it decrease to 11V. Which guy will be the next? May be U7000 (ISL9239
    • arevut
      • Mar 2019
      • 17
      • Ukraine
      #42
      source (1-2-3) & drain (5-6-7-8) = 8K vs OL
      • CornholioGSM
        Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
        by CornholioGSM
        I have here one interesting problem.
        Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
        I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
        Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
        06-25-2024, 12:27 PM
      • mavaro
        MacBook A1990 — No Display With Battery Connected
        by mavaro
        Hi, I have a problem with MACBOOK A1990 - The laptop starts with no image when the battery is connected, but without the battery it starts with an image - however, when using only the power supply, when logging into the system it turns off and resets again.
        Battery replaced with another unit → same problem.
        ISL9239 replaced → no change.
        SMBUS_BATT_SCL / SDA measure ~20-50kΩ to GND with battery disconnected (normal).
        Any ideas or advice would be a huge help!
        Thanks in advance for your time.​
        04-18-2025, 08:07 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • tommy97
        Macbook A1708 battery not detected
        by tommy97
        Hi guys, i have weird problem with A1708, laptop does not detect battery, currently I'm using tested new battery, laptop works on it but does not show any details such as percentage, cycle counts etc. and works on it only for like 1-2 minutes with battery cross icon.
        I've tried new battery flex, no change.
        PPBUS_G3H 10.9v on battery
        D6950 - tested fine (replaced also just in case, no change)
        R5381 - 3.3V (2kOhm)
        R5380 - 3.3V (2kOhm)
        R6950 - 10kOhm - 0.08v or 0 (Checked path and fine with connector)
        On battery data connector...
        07-14-2023, 03:32 AM
