On bios show the SN of the battery....
					HP Omen 15-ax014ns - Don't charge or discharge battery!!
Battery SN is a good sign that the SCL / SDA lines are working as they should. The BMS inside the battery module is spitting out the requested information by the EC. Good.
Remove all power. Review the resistance across PQ1001. Being a N-channel mosfet (AON6414), the gate pin must be higher than the voltages being passed between source / drain pins on the same mosfet to ENABLE. Anything lower will leave this mosfet as OFF.
Meter in resistance mode, check the resistance across the mosfet pins:
source & drain
source & gate
gate & drain
Post each measurement.Comment
Hi again! It's OL in all cases...
source & drain = OL
source & gate = OL
gate & drain = OL
The problem i see is the voltage on the gate and source of PQ1001, are 5,85V. If i desolder the mosfet, the volatges are the same on these 4 pins of the board, 5,85V. And no short on PC1005... And i replace these mosfet but nothing different....Comment
Thanks again for your support...This is the question, why the gate of AON6414 didnt be activated... I post the voltages of BQ738H, i hope it helps to resolve this question:
Without battery, only AC:
PIN 1: 19'9V
PIN 2: 19,9V
PIN 3: 19,9V
PIN 4: 25'8V
PIN 5: 3V
PIN 6: 2,8V
PIN 7: 0V
PIN 8; 3,3V
PIN 9: 3,3V
PIN 10: 1V
PIN 11: 5,8V
PIN 12: 5,8V
PIN 13: 5,8V
PIN 14: 0V
PIN 15: 0V
PIN 16: 6V
PIN 17: 5,8V
PIN 18: 5'7V
PIN 19: 5'8V
PIN 20: 19'9V
With battery, and AC:
PIN 1: 19'9V
PIN 2: 19,9V
PIN 3: 19,9V
PIN 4: 25'8V
PIN 5: 3V
PIN 6: 2,8V
PIN 7: 0V
PIN 8; 3,2V
PIN 9: 3,2V
PIN 10: 1V
PIN 11: 11,5V
PIN 12: 11.5V
PIN 13: 11.5V
PIN 14: 0V
PIN 15: 0V
PIN 16: 6V
PIN 17: 11.5V
PIN 18: 11.4V
PIN 19: 11.5V
PIN 20: 19'9V
Only battery:
PIN 1: 11,5V
PIN 2: 11,5V
PIN 3: 11,5V
PIN 4: 11,5V
PIN 5: 0V
PIN 6: 1.5V
PIN 7: 0V
PIN 8; 3,2V
PIN 9: 3,2V
PIN 10: 1V
PIN 11: 17,6V
PIN 12: 11.5V
PIN 13: 11.5V
PIN 14: 0V
PIN 15: 0V
PIN 16: 6V
PIN 17: 11.5V
PIN 18: 11.4V
PIN 19: 11.5V
PIN 20: 11VComment
Check PR1002. Measure the voltage to ground on each side of this resistor with only the battery. It should be the same voltage as charger pin # 11.
At ~18 volts, this N-channel mosfet should be enabled.
With no power, check the resistance of this resistor.Comment
Review the low side battery charge mosfet @ PQ1007. Pin # 15 on the charger IC (gate voltage for the low side mosfet) remains at 0 volts for each of the cases? This is not correct when the charger is expected to charge the battery since it will be toggling on/off to create the charge voltage from the high Vin from the power adapter.
Confirm pin #15 is not shorted and that it is reaching the gate of the low side mosfet.Comment
			I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
			by razenxdHello,
it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
Now, I have noticed a few things.
The "dead" battery, while connected to charger and NOT Charging will...-
			by ruleteroHi
Acer A515-43
LA-H801P
Fail: Does not charge battery, has low voltaje on connector.
Laptop didn't want to turn on, only charge led blinked.
I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know... -
			by sam_sam_samThis is another battery testing machine that needs to be modified for the cooling fans because these are noisy but not as bad as one of the other battery testing machines that I had modified recently because of it being too noisy
The battery testing machine is going to get two temperatures controlled cooling fans like one I put in the other battery testing machine I just have to remove the temperature sensor and relocate the temperature sensor to one of the heat sinks and put one on the other heat sink so the fan speed can be controlled by temperature
https://www.eb... -
			by KlevjetackIs there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
 - Loading...
