HP Omen 15-ax014ns - Don't charge or discharge battery!!
  • tesnic
    • Jun 2022
    • 48
    • Spain
    On bios show the SN of the battery....
    • mon2
      • Dec 2019
      • 14684
      Battery SN is a good sign that the SCL / SDA lines are working as they should. The BMS inside the battery module is spitting out the requested information by the EC. Good.
      Remove all power. Review the resistance across PQ1001. Being a N-channel mosfet (AON6414), the gate pin must be higher than the voltages being passed between source / drain pins on the same mosfet to ENABLE. Anything lower will leave this mosfet as OFF.
      Meter in resistance mode, check the resistance across the mosfet pins:
      source & drain
      source & gate
      gate & drain
      Post each measurement.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Voltage on gate pin of PQ1002/1003 is not reported so far.As a basic checks must be checked.
        • tesnic
          • Jun 2022
          • 48
          • Spain
          Hi again! It's OL in all cases...
          source & drain = OL
          source & gate = OL
          gate & drain = OL
          The problem i see is the voltage on the gate and source of PQ1001, are 5,85V. If i desolder the mosfet, the volatges are the same on these 4 pins of the board, 5,85V. And no short on PC1005... And i replace these mosfet but nothing different....
          • mon2
            • Dec 2019
            • 14684
            OL on which resistance meter scale?
            • tesnic
              • Jun 2022
              • 48
              • Spain
              #26
              in auto... the sense of the meter tips doesn't matter right?
              • tesnic
                • Jun 2022
                • 48
                • Spain
                #27
                Anyway, i isolate the PQ1001, it's not the problem. The problem is the 5'8V of BQBATCHG, i dont know if is a good value... These voltage go to source and gate of the PQ1001, and do the vale of BATCHG+ be the same 5'8V
                • mon2
                  • Dec 2019
                  • 14684
                  • tesnic
                    • Jun 2022
                    • 48
                    • Spain
                    #29
                    Thanks again for your support...This is the question, why the gate of AON6414 didnt be activated... I post the voltages of BQ738H, i hope it helps to resolve this question:
                    Without battery, only AC:
                    PIN 1: 19'9V
                    PIN 2: 19,9V
                    PIN 3: 19,9V
                    PIN 4: 25'8V
                    PIN 5: 3V
                    PIN 6: 2,8V
                    PIN 7: 0V
                    PIN 8; 3,3V
                    PIN 9: 3,3V
                    PIN 10: 1V
                    PIN 11: 5,8V
                    PIN 12: 5,8V
                    PIN 13: 5,8V
                    PIN 14: 0V
                    PIN 15: 0V
                    PIN 16: 6V
                    PIN 17: 5,8V
                    PIN 18: 5'7V
                    PIN 19: 5'8V
                    PIN 20: 19'9V
                    With battery, and AC:
                    PIN 1: 19'9V
                    PIN 2: 19,9V
                    PIN 3: 19,9V
                    PIN 4: 25'8V
                    PIN 5: 3V
                    PIN 6: 2,8V
                    PIN 7: 0V
                    PIN 8; 3,2V
                    PIN 9: 3,2V
                    PIN 10: 1V
                    PIN 11: 11,5V
                    PIN 12: 11.5V
                    PIN 13: 11.5V
                    PIN 14: 0V
                    PIN 15: 0V
                    PIN 16: 6V
                    PIN 17: 11.5V
                    PIN 18: 11.4V
                    PIN 19: 11.5V
                    PIN 20: 19'9V
                    Only battery:
                    PIN 1: 11,5V
                    PIN 2: 11,5V
                    PIN 3: 11,5V
                    PIN 4: 11,5V
                    PIN 5: 0V
                    PIN 6: 1.5V
                    PIN 7: 0V
                    PIN 8; 3,2V
                    PIN 9: 3,2V
                    PIN 10: 1V
                    PIN 11: 17,6V
                    PIN 12: 11.5V
                    PIN 13: 11.5V
                    PIN 14: 0V
                    PIN 15: 0V
                    PIN 16: 6V
                    PIN 17: 11.5V
                    PIN 18: 11.4V
                    PIN 19: 11.5V
                    PIN 20: 11V
                    • mon2
                      • Dec 2019
                      • 14684
                      Check PR1002. Measure the voltage to ground on each side of this resistor with only the battery. It should be the same voltage as charger pin # 11.
                      At ~18 volts, this N-channel mosfet should be enabled.
                      With no power, check the resistance of this resistor.
                      • tesnic
                        • Jun 2022
                        • 48
                        • Spain
                        #31
                        The voltages of PR1002, with only battery, is 17,6V and 17,3V. The resistance is 200K ohms. The mosfet is 17,3V on gate and 11,5V on source. The problem still being to charge the battery....
                        • mon2
                          • Dec 2019
                          • 14684
                          Review the low side battery charge mosfet @ PQ1007. Pin # 15 on the charger IC (gate voltage for the low side mosfet) remains at 0 volts for each of the cases? This is not correct when the charger is expected to charge the battery since it will be toggling on/off to create the charge voltage from the high Vin from the power adapter.
                          Confirm pin #15 is not shorted and that it is reaching the gate of the low side mosfet.
                          • tesnic
                            • Jun 2022
                            • 48
                            • Spain
                            #33
                            Yes, PIN15 it's 0V in all cases. I confirm that PIN15 is not shorted, but when i plug the AC or battery, it shows me 1ohm resistance to ground... And yes, these PIN15 and gate of PQ1007 are connected, tested with mulitmeter.
                            • mon2
                              • Dec 2019
                              • 14684
                              Never measure resistance with power to the board.
                              remove all power and check the resistance of this same mosfet as before.
                              source & drain
                              source & gate
                              gate & drain
                              • tesnic
                                • Jun 2022
                                • 48
                                • Spain
                                #35
                                Resistances of PQ1007:
                                source & drain = 350K ohms and uploading..
                                source & gate = 1,7K ohms
                                gate & drain = 0.8M ohms
                                but if I reverse the tips...OL in all cases
                                I replace these pair of mosfets (PQ1007 and PQ1006) twice...
                                • tesnic
                                  • Jun 2022
                                  • 48
                                  • Spain
                                  #36
                                  I replace, again, the BQ IC charger. For 4th time... And it seem it charge, the voltage of PIN 15 is present. Windows don't animate the battery icon, but increase the percentage of it. Don't estimate the full charge time, but it seems is charging.....
                                  • mon2
                                    • Dec 2019
                                    • 14684
                                    Review the SMBUS lines on the battery connector. If they are not active, the missing details will not be visible. The gauge is based on the SMBUS traffic.
                                    • techfreak9356
                                      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                      by techfreak9356
                                      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                      09-14-2023, 11:10 PM
                                    • razenxd
                                      How can I charge that battery pack?
                                      by razenxd
                                      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                      Now, I have noticed a few things.
                                      The "dead" battery, while connected to charger and NOT Charging will...
                                      12-05-2024, 06:11 AM
                                    • ruletero
                                      Acer a515-43 low battery charge voltage
                                      by ruletero
                                      Hi
                                      Acer A515-43
                                      LA-H801P
                                      Fail: Does not charge battery, has low voltaje on connector.
                                      Laptop didn't want to turn on, only charge led blinked.
                                      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                      10-24-2022, 02:31 PM
                                      EBC-X 8-Channels 18650 Battery Capacity Tester Charge & Discharge 10A Aging Test Modificatio
                                      by sam_sam_sam
                                      This is another battery testing machine that needs to be modified for the cooling fans because these are noisy but not as bad as one of the other battery testing machines that I had modified recently because of it being too noisy
                                      The battery testing machine is going to get two temperatures controlled cooling fans like one I put in the other battery testing machine I just have to remove the temperature sensor and relocate the temperature sensor to one of the heat sinks and put one on the other heat sink so the fan speed can be controlled by temperature
                                      https://www.eb...
                                      05-05-2024, 06:07 PM
                                    • Klevjetack
                                      Charge a L19D3PDA battery externally from the laptop
                                      by Klevjetack
                                      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                      03-05-2024, 07:26 AM
