HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
  • KvnTM
    • May 2018
    • 434
    Re: HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
    Quoting myself:
    Originally posted by KvnTM
    C26 = 0.1uF / 10V
    C20 = 220pF / 50V (Can be left unpopulated, just for EMI)
    Just populate both to be safe. At least C26.
    C20 isnt that important.
    • antony.ag
      • Nov 2019
      • 59
      • Italia
      #62
      hi, KvnTM right now I'm in front of the card. could you tell me how to set up the tester to take measurements? should I set it to diode or ohm?
      • KvnTM
        • May 2018
        • 434
        Depends on what you want to measure.
        If you want to measure for shorts or resistance then set it to Ohm
        If you want to measure voltage set it to Volt
        • antony.ag
          • Nov 2019
          • 59
          • Italia
          #64
          in the previous post I wrote that pr12 heated a lot and for this reason I removed it. you advised me to test pr12 without resistance to see if it was pc16 in short or the chip.
          • antony.ag
            • Nov 2019
            • 59
            • Italia
            #65
            So my card shows up: pr12 Missing c26 Missing c20 missing
            • KvnTM
              • May 2018
              • 434
              Oh yeah I remember.. Put your meter in Ohm mode and put your red probe on the left pad of pr12 and the black probe on either one of those screw holes.
              • antony.ag
                • Nov 2019
                • 59
                • Italia
                #67
                nothing ... it gives me some value if I put the red probe on the right ... I put the tester at 200k
                • antony.ag
                  • Nov 2019
                  • 59
                  • Italia
                  #68
                  I put the tester at 2000 and put the black probe where the screws go and Red probe both to the right and to the left of pr12 but no value
                  • KvnTM
                    • May 2018
                    • 434
                    Resistance could be out of range. Measure with 2000k range
                    • antony.ag
                      • Nov 2019
                      • 59
                      • Italia
                      #70
                      I don't know if it could be strange to me from 480 and slowly it increases
                      • KvnTM
                        • May 2018
                        • 434
                        Yeah that's due to capacitors charging through your meter.
                        Have you already removed any component from the board? The cap I mentioned?
                        • antony.ag
                          • Nov 2019
                          • 59
                          • Italia
                          #72
                          do I have to remove pc16?
                          • antony.ag
                            • Nov 2019
                            • 59
                            • Italia
                            #73
                            ehehe I hope as soon as possible ehehehe ... another question I wanted to ask you those capacitors that I removed I can leave them without or I'm forced to put them
                            What cap ?
                            • KvnTM
                              • May 2018
                              • 434
                              What cap ?
                              Could you put the readings and where you probe in the photo? I'm not sure if you are measuring correctly..
                              My question was if you did anything to the board when the resistor was heating up. I know you removed the resistor but anything else?
                              • antony.ag
                                • Nov 2019
                                • 59
                                • Italia
                                #75
                                measured at 2000k and brings me 480 and goes up ... the components removed are only those mentioned before c26 and c20 ... when I removed the resistance I did not remove any other component ... the first component that I had removed was c26 then I removed c20 and afterwards I realized that pr12 burned and I took it off ... I didn't take anything anymore
                                • antony.ag
                                  • Nov 2019
                                  • 59
                                  • Italia
                                  #76
                                  how can i proceed? Please :-(
                                  • KvnTM
                                    • May 2018
                                    • 434
                                    Replace C26 & C20 with the proper caps and put a 20Ohm resistor where PR12 was and start over. Randomly ripping parts of the board while not knowing the issue won't fix it..
                                    • antony.ag
                                      • Nov 2019
                                      • 59
                                      • Italia
                                      #78
                                      ok perfect I will try to do it immediately ... how can I measure the capacitors I need with the tester?
                                      • KvnTM
                                        • May 2018
                                        • 434
                                        I already posted the correct ones but here it is again:
                                        C26 = 0.1uF / 10V
                                        C20 = 220pF / 50V
                                        PR12 = 22Ohm (Not 20 or 220...)
                                        • antony.ag
                                          • Nov 2019
                                          • 59
                                          • Italia
                                          #80
                                          yes thank you very much very kind ... but I had to take them in another motherboard how can I measure if they can go well? because on the cards the value is not marked ... with the tester how can I measure the value of the capacitor that I would like to take from another motherboard?
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • Anooc7
                                            Samsung UN75NU6950 no backlight but leds works when checked individually!
                                            by Anooc7
                                            Hi, This model has bottom mounted leds . Got it with right ride 1/3 of the display black. So I checked the 6 + and - wire that powers 6 different zones and found that the 5th zone was open, which opens 6th zone too makes the right 1/3 of the display dark. Opened it and found one blown led on the 5th zone and shorted that path using solder. So now all the zones works when I check it using the bl tester , but when I put everything back together there is no backlight! The voltage I am getting when neg to chassis is 387v. How does that happen? Still individual zones working with bl tester .
                                            09-16-2021, 06:16 PM
                                          • lpraderi
                                            Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                                            by lpraderi
                                            Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                                            In some cases to use LVDS screen PCB use converter IC RTD2132/6
                                            Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                                            at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                                            Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                                            11-25-2023, 09:31 AM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
