Macbook Pro M1 820-02020 - no display
  • piernov
    • Jan 2016
    • 4439
    • France
    Originally posted by obelix24
    according to schematics RP844 and RP845 should be 0ohm ?
    Click image for larger version  Name:	screen-2024-02-05-22-34-40.png Views:	0 Size:	81.0 KB ID:	3211061
    • obelix24
      • Jun 2023
      • 300
      • Slovakia
      mon2
      BL_PWR_EN - 0V
      I2C_BKLT_SCL - 5,2V
      I2C_BKLT_SCL - 5,2V
      • mon2
        • Dec 2019
        • 14720
        Voltage of IPD_LID_OPEN_1V8​ ?
        • obelix24
          • Jun 2023
          • 300
          • Slovakia
          IPD_LID_OPEN_1V8 - on trackpad connector (pin 1) - 1,8V
          I found that there was missing one cap C5824 I've replaced it but behaving still the same
          • obelix24
            • Jun 2023
            • 300
            • Slovakia
            mon2 any idea ?
            • mon2
              • Dec 2019
              • 14720
              Does the trackpad function when using the external hdmi display?
              • obelix24
                • Jun 2023
                • 300
                • Slovakia
                #27
                mon2 I'm not able to get output to external display (as the touch bar is not showing anything) but external display recognizes macbook and on macbook screen i can operate mouse.
                • mon2
                  • Dec 2019
                  • 14720
                  Are you using a USB mouse or the trackpad? It is important.
                  Have you attempted a DFU?
                  https://iboysoft.com/wiki/apple-configurator-2.html​
                  • obelix24
                    • Jun 2023
                    • 300
                    • Slovakia
                    #29
                    I'm using trackpad. I haven't tried DFU
                    • obelix24
                      • Jun 2023
                      • 300
                      • Slovakia
                      #30
                      mon2 I've tried DFU and I get successfully to DFU and restored the MacBook with another MacBook with apple configurator but still no backlight.
                      I tried to connect external display with HDMI and I can see the screen but I can not finish first setup as main screen is still on MacBook (even if I disconnect display cable) , as the Touch Bar is not showing anything I'm not able to switch displays
                      Do you know if Touch Bar from other MacBook (1708,1989 will work) ? are they interchangeable ?
                      may finishing setup enable somehow backlight ?
                      and yes keyboard and trackpad work (on the second screen only thing that is possible to do is connect to wifi)
                      • obelix24
                        • Jun 2023
                        • 300
                        • Slovakia
                        #31
                        I've checked also
                        RP611 - LPDP_INT_HPD - 1,167V
                        RD560 - all pins 12,3V
                        CC720 - P3V3S2_FB - only - 0,7V
                        CC720 - P3V3S2_VOS - 3,3V
                        • mon2
                          • Dec 2019
                          • 14720
                          Not sure on the touch bar compatibility but as they are sold as different part numbers then there must be a difference. You can confirm by reviewing Aliexpress / Mobile Sentrix stores on the same.
                          https://youtu.be/O-kNBdxAo5w
                          With no power / no battery, what is the exact resistance to ground of PPVOUT_LCDBKLT ?
                          I believe that when you connect the HDMI external monitor, the unit will enter extended display mode as you are observing. The main functions are still local on the dark LCD till you make use of the non-working touchbar. Does the touchbar look to be damaged or cracked? In the end, it is just a fancy but high resolution rectangular LCD with a touch panel.
                          Carefully measure the voltage to ground of:
                          I2C_AOP_ALS_SCL
                          I2C_AOP_ALS_SDA
                          I2C_ALS_1V8_SCL
                          I2C_ALS_1V8_SDA
                          If this is not practical then remove all power (no battery); meter in DIODE mode.
                          Red meter probe (yes red) to ground. Black meter probe to the point to test from the above list. We are checking to see if the I2C lines that are low voltage variations for this M1 board are defective or not.
                          Post each measurement.
                          • obelix24
                            • Jun 2023
                            • 300
                            • Slovakia
                            #33
                            battery and charge disconnected
                            PPVOUT_LCDBKLT - approx 5M ohms and falling down
                            I don't see any cracks or any damage on Touch Bar
                            I2C_AOP_ALS_SCL - 0,338V
                            I2C_AOP_ALS_SDA - 0,339V
                            I2C_ALS_1V8_SCL - 0,594V
                            I2C_ALS_1V8_SDA - 0,594V
                            • mon2
                              • Dec 2019
                              • 14720
                              Both of these power rails are of the wrong voltage. The 1v8 side should be parked by default @ 1v8. The lower voltage side of the same signals should be @ 1v25 for each. UD140 is a fet based voltage level translator between the 2 power planes.
                              • obelix24
                                • Jun 2023
                                • 300
                                • Slovakia
                                #35
                                mon2 values are from Diode mode
                                • rany
                                  • Oct 2018
                                  • 10
                                  • Lebanon
                                  #36
                                  This model has many resistors around the backlight driver. Test each and every one of them to make sure they have the correct resistance, then lift them to make sure none of them has a corroded pin underneath the resistor.
                                  Ask me how I know to check these very very carefully.
                                  Same applies for the keyboard controllers by the way.
                                  • obelix24
                                    • Jun 2023
                                    • 300
                                    • Slovakia
                                    #37
                                    ok yesterday I was working on this Mac and I was checking with thermal cam and UP700 was getting hot when it was turned on (still without backlight)
                                    I've give it change and replaced UP700 from donor and MacBook turned on with backlight but still looks like not charging (showing battery 78% but not charging if I disconnect charger immediately MacBook turns off
                                    • mon2
                                      • Dec 2019
                                      • 14720
                                      Good. Measure the voltage to ground of each pin on the battery connector. Post each measurement.
                                      • obelix24
                                        • Jun 2023
                                        • 300
                                        • Slovakia
                                        #39
                                        ok I've measured battery pins when battery and charger are connected :
                                        I2C_SMC_PWR_3V3_SCL - 3,2V not stable falling to 2,8V
                                        I2C_SMC_PWR_3V3_SDA - 3,2V not stable falling to 2,8V
                                        SYS_DETECT_L - 0V
                                        When battery is disconnected and charged is connected I've measured :
                                        I2C_SMC_PWR_3V3_SCL - 3,2V stable (it's going from 3,251V to 3,249V)
                                        I2C_SMC_PWR_3V3_SDA - 3,2V stable (it's going from 3,251V to 3,249V)
                                        Also I have issue that Power button is working but Touch ID not.
                                        Also camera is not detected.
                                        Touch Bar starts working - I have to test it more.
                                        battery is showing 12,10V and 0a in stats
                                        • obelix24
                                          • Jun 2023
                                          • 300
                                          • Slovakia
                                          #40
                                          ok update. Battery is charging fine now.
                                          Issue was that I didn't know that over battery connector (that one attached with screw) was missing one black part that was creating probably more pressure
                                          So now I have 2 issues left.
                                          1. Touch Bar is working but when I turn on MacBook it's black, I close the lid a reopen and Touch Bar is fully working
                                          2. camera is not working. I was told by previous owner that it was working before.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • som_b1
                                            Macbook screen does not display an image
                                            by som_b1
                                            Hello. I encountered such a problem - the MacBook screen lights up but does not display an image. Almost like a flexjgate in reverse). Maybe someone has encountered such a breakdown. The problem is in the cables or maybe in the t-con?
                                            11-05-2025, 12:20 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • Ado02
                                            MacBook Pro A2159 - No Display / Works on External Screen
                                            by Ado02
                                            I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
                                            Please see the attached image.
                                            I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
                                            Can anyone suggest where to go from here?...
                                            01-12-2023, 03:35 AM
                                          • ledbylight
                                            M1 A2337 Macbook - No Display, likely due to logic board
                                            by ledbylight
                                            Hi all!
                                            This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                            I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                            11-04-2024, 06:36 PM
