Macbook Pro M1 820-02020 - no display
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    #81
    mon2 do you think it's ok ?
    • obelix24
      • Jun 2023
      • 300
      • Slovakia
      #82
      This macbook died and after checking i found out there is small crack in U7700 (also after thermal camera check right in that place where U7700 is cracked it's getting hot) my question is if it's possible to replace U7700 with another one from donor board or it's paired with CPU or board ...
      • mon2
        • 14717
        Personally have not come across this case. The schematics show that U7700 is part # 998-22526. No hits on any website nor Aliexpress. Perhaps a larger concern is what is the reason for this PMIC to get nuked. Respectively, very likely that downstream leg of the circuit is also killed. This may be a no fix case.
        • obelix24
          • Jun 2023
          • 300
          • Slovakia
          #84
          Yes i've also not able to find any info about this IC. I've replaced it anyway and macbook is now starting and i'm getting error that i need to restore.
          I've tried Revive, restore, via apple configurator 2 but problem is that i don't have other macbook with latest MacOS only one older one a1706 and there revive, restore is not finished and i don't know if because it's not newest macos or why
          • obelix24
            • Jun 2023
            • 300
            • Slovakia
            #85
            ok so according Camera, touch bar and ALS not working ... i found that it's not motherboard related (most probably) as i put in this case know working M1 macbook pro (a2338) and there is exactly same issue (camera not detected, ALS not working, touch bar working but lights up after some time) it looks like these issues are related all together with something bad in display unit (probably will need new display
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • som_b1
              Macbook screen does not display an image
              by som_b1
              Hello. I encountered such a problem - the MacBook screen lights up but does not display an image. Almost like a flexjgate in reverse). Maybe someone has encountered such a breakdown. The problem is in the cables or maybe in the t-con?
              11-05-2025, 12:20 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • Ado02
              MacBook Pro A2159 - No Display / Works on External Screen
              by Ado02
              I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
              Please see the attached image.
              I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
              Can anyone suggest where to go from here?...
              01-12-2023, 03:35 AM
            • ledbylight
              M1 A2337 Macbook - No Display, likely due to logic board
              by ledbylight
              Hi all!
              This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
              I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
              11-04-2024, 06:36 PM
