Macbook Pro M1 820-02020 - no display
  • mon2
    • 14717
    If the current draw is a sudden fixed value then you will need to check the resistance to ground on the vbus rail on the usb type c connector. There may be a partial short on this leg of the circuit. Is the current draw the same value if the power cable head is flipped by 180 degrees? Do not inject such a high voltage till more is known about your case.
    • obelix24
      • Jun 2023
      • 300
      • Slovakia
      #62
      mon2 it's same draw on both ports and both side (still same 5V 0.2A)
      • obelix24
        • Jun 2023
        • 300
        • Slovakia
        #63
        if CD3217 is bad it will be visible on thermal cam ? and also there will be different voltage output on FF200 and FF201 ?
        • mon2
          • 14717
          Test the voltage of each ldo on each cd3217.
          • obelix24
            • Jun 2023
            • 300
            • Slovakia
            #65
            mon2
            Voltage is only on that side where power is connected
            PP3V3_UPC0_LDO - 3,4V
            PP1V5_UPC0_LDO_CORE - 1,5V
            USBC0_3V3LDO_EN - 0V
            PP3V3_UPC1_LDO - 3,4V
            PP1V5_UPC1_LDO_CORE - 1,5V
            USBC1_3V3LDO_EN - 0V
            • mon2
              • 14717
              Also need the voltage to ground of:
              PP1V25_S2
              PP1V8_S2
              PP3V3_AON
              • obelix24
                • Jun 2023
                • 300
                • Slovakia
                #67
                Voltage to ground power adapter connected
                PP1V25_S2 - 0V
                PP1V8_S2 - 0V
                PP3V3_AON - 0V
                Diode mode
                PP1V25_S2 - 0,280V (tested on CF735, CF230)
                PP1V8_S2 - 0,340V (tested on CF503, CF403)
                PP3V3_AON - 0,400V (tested on RD208, RD207)
                but i'm still confused as on PPBUS_AON on F5200 i'm getting in diode mode only 0,07V (on other board that i have i'm getting there 0,506V) according to https://openboarddata.org/?a=showboa...pple/820-02020 0,5V should be ok)
                When i inject voltage to F5200 there is no A draw )
                • obelix24
                  • Jun 2023
                  • 300
                  • Slovakia
                  #68
                  I've removed F5200 and checked in diode mode both pins on
                  PPVBAT_AON_CHRG_REG - 0,5V
                  PPBUS_AON - 0,07V
                  I've tried to inject 1V to PPBUS_AON side but it's taking nothing 0A
                  • obelix24
                    • Jun 2023
                    • 300
                    • Slovakia
                    #69
                    mon2any idea ?
                    • obelix24
                      • Jun 2023
                      • 300
                      • Slovakia
                      #70
                      ok so finally I got it working I've turned on thermal camera and slightly increased voltage input on PPBUS_AON from 1V to approx 2,3V and UR730 was getting hot (same as on video I've posted on previous page). Replaced UR730 reconnected everything and now MacBook is turning on and taking 20V
                      I've connected everything except keyboard backlight as I'm little bit scared if this haven't cause short on UR730 ... I will probably order keyboard backlight directly for a2338.
                      one thing ... when I turned MacBook there was popup and os is damaged and needs to be reinstalled.
                      • obelix24
                        • Jun 2023
                        • 300
                        • Slovakia
                        #71
                        in the meantime waiting for backlight keyboard i'm wondering how can i fix touchbar ... It's working fine but when i turn on macbook touch bar doesn't light up, but it respond on touch, also when i close the lid (LCD is turned off i was slowly closing lid and i can see that screen turns off when there is small gap only) and reopen touch bar is visible. Also if i turn on macbook and leave it as is after approx 3 min touch bar is visible ...
                        I don't understand what can cause this strange issue. probably some doggy capacitor, resistor but how to find it ?
                        • mon2
                          • 14717
                          Careful - we have seen that the touchbar will light up AFTER the login screen and most likely after a device driver has been loaded on a recent repair in the shop. The touchbar is a standalone LCD panel with CTP for touch and it is quite possible the firmware is loaded much later in the boot cycle. We too thought to replace this client's touchbar but the owner reported there was no fault here since it lit up around the time we saw the desktop. You can perform a DFU if you suspect any firmware corruption.
                          • obelix24
                            • Jun 2023
                            • 300
                            • Slovakia
                            #73
                            But this touch bar doesn't light up with desktop. I'm already in macos and the touch bar is still black (but it responses as whene i touch finger where icons should be i can operate volume, brightness, ...
                            Issue is that it lights up after some time (i've checked and it's approx 3 minutes) or when i close and reopen lid (then it's still on if macbook goes to sleep and wakes up it's still working. I've tried few times DFU (revive, restore, reinstall) nothing helped.
                            I don't know maybe it's connected to the camera that is not recognized (maybe it's waiting for some sensor from camera ...
                            i found here same issue as i have
                            https://boards.rossmanngroup.com/thr...0-02020.64122/
                            • mon2
                              • 14717
                              Try the DFU to fix the Touch Bar.
                              • obelix24
                                • Jun 2023
                                • 300
                                • Slovakia
                                #75
                                I tried DFU few times but the problem is still the same
                                i've tried to replace UR200 from donor board but after replacemet macbook behaves strange ... backlight was off, when i go near power button with my finger backlight starts but the screen was turning on and off i immediately returned old UR200 and it's working fine (but still the same issues no camera detected and touch bar working after 3 min or after closing and reopening lid)
                                • obelix24
                                  • Jun 2023
                                  • 300
                                  • Slovakia
                                  #76
                                  I found one thing i've disconnected Trackpad flex cable from motherboard but everything else stay connected (except keyboard backlight) macbook started and there was logon screen but keyboard was not working at all (even it was connected). When i connect trackpad flex keyboard was working again.
                                  Is this normal behavior ?
                                  • mon2
                                    • 14717
                                    Review the mated cables. Disconnect them all and use the bare minimum set of interconnects. You can attach a USB Type C hub onto which you can use a standard USB keyboard / USB mouse. They will work since USB keyboards / mice are USB HID class codes so all operating systems will recognize them.
                                    • obelix24
                                      • Jun 2023
                                      • 300
                                      • Slovakia
                                      #78
                                      ok today i received backlight and now when backlight is connected is working
                                      But i noticed one thing when i turned macbook battery was 0% and i know that i've charged it few days ago to 100% ... so it's discharging ... is there any way how i can found what is discharging it ? there must be something draining battery but how to find what ?
                                      • mon2
                                        • 14717
                                        How is the health of the battery? How many charge cycles? Can you test with another known good battery?
                                        • obelix24
                                          • Jun 2023
                                          • 300
                                          • Slovakia
                                          #80
                                          battery health is : 87%
                                          Cycle count : 440
                                          Condition : Normal
                                          in app stats (from GitHub) it's showing health 81%
                                          I don't have any other battery to test I expect this one is good.
                                          I've checked with thermal camera when MacBook was turned off and there was only one spot near U7700 that was warmer ... It looks like it was one of the diodes
                                          I've checked diode mode on near caps C746, 745, 744 and the result was 0,03V (battery connected)
                                          But when I turned on MacBook and checked voltage there it was normal 1,06V (PP1V06_S2SW_DRAM)
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • som_b1
                                            Macbook screen does not display an image
                                            by som_b1
                                            Hello. I encountered such a problem - the MacBook screen lights up but does not display an image. Almost like a flexjgate in reverse). Maybe someone has encountered such a breakdown. The problem is in the cables or maybe in the t-con?
                                            11-05-2025, 12:20 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • Ado02
                                            MacBook Pro A2159 - No Display / Works on External Screen
                                            by Ado02
                                            I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
                                            Please see the attached image.
                                            I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
                                            Can anyone suggest where to go from here?...
                                            01-12-2023, 03:35 AM
                                          • ledbylight
                                            M1 A2337 Macbook - No Display, likely due to logic board
                                            by ledbylight
                                            Hi all!
                                            This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                            I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                            11-04-2024, 06:36 PM
