Macbook Pro M1 820-02020 - no display
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    I got one MacBook Pro M1 that was water damaged.
    It was not turning on I've changed one CD3217 IC and now MacBook is taking 5V instead of 20V, I've also replaced U5700 as there was clicking sound when charger was connected.
    But MacBook turns on (when I connect charger it's taking only 5V 0,04a) but there is chime and when I connect external screen over HDMI I can see login screen. Trackpad is working, keyboard backlight is also working and keyboard looks also ok (but not tested fully)
    Issues are :
    Touchpanel is of there is no sign of life...
    Internal display is not working but previous owner told me that screen should be ok. He gave this MacBook to two other people to check and each of them make something (but it looks like no board level repair was done by them)
    I'm trying to find out if the screen is ok.
    I've checked
    PP1V8_AON - stable 1.8V
    PP3V8_AON - stable 3,8V
    Is there anything that can cause no Touch Bar and no internal display only external ?
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    I've checked
    PP1V5_UPC0_LDO_CORE - 1,5V
    PP3V3_UPC0_LDO - 3,3V
    PP1V5_UPC1_LDO_CORE - 1,5V
    PP3V3_UPC1_LDO - 3,3V
    FF200 on both sides stable 20V
    FF201 on both sides stable 20V
    But on all CP870, 71, 72, 73, 64, 65, 66 (PPVOUT_LCDBKLT - 0V (but i don't know if screen needs to be connected when testing this) - here no screen connected
    Also on L5230 on both sides i don't have stable V .... CHRG_PHASE1 and PHASE2
    on F5200 - both sides stable 12,04V
    • obelix24
      • Jun 2023
      • 300
      • Slovakia
      I've checked with screen connected and same result.
      Also between LCDBKLT_FB (PIN2 on RP831) and PPVOUT_LCDBKLT there is no continuity, there is resistance 17k Ohms
      also one more thing this macbook came to me without display flex cable so i found one that looks same but it's probably from a2189 or a1708 is this problem ?
      • obelix24
        • Jun 2023
        • 300
        • Slovakia
        any idea anyone ?
        • mon2
          • 14713
          Not recommended unless you are 100% sure it is the same. We have faced a similar issue with trackpad cables where the width of the cable was 100% but the pad to pad pitch was different than the original so the # of contacts did not match and respectively, the trackpad failed to function.
          Find a known good cable for the actual unit under test.
          • obelix24
            • Jun 2023
            • 300
            • Slovakia
            I've ordered new flex at monday i will have it so i will check
            • obelix24
              • Jun 2023
              • 300
              • Slovakia
              ok today I've got the flex finally
              I've installed it and I've turned MacBook on and I can see image but no backlight.
              I've checked
              PP5v_BKLT_A and PP5v_BKLT_D - both 5,2V (stable)
              but I still don't have continuity between pin 2 of RP831 (LCDBKLT_FB) and PPVOUT_LCDBKLT - there is resistance 17k ohms
              PPVIN_LCDBKLT_F​ - is 12V
              BKLT_EN_R - 0V
              • mon2
                • 14713
                Measure the voltage to ground on QP800. Post each measurement.
                • obelix24
                  • Jun 2023
                  • 300
                  • Slovakia
                  pin 1 - PPVIN_LCDBKLT_Q - 0V
                  pin 2 - PPVIN_LCDBKLT_Q - 0V
                  pin 3 - LCDBKLT_EN_L - 11,94V
                  pin 4 - PPVIN_LCDBKLT_R - 12,04V
                  pin 5 - PPVIN_LCDBKLT_Q - 0V
                  pin 6 - PPVIN_LCDBKLT_Q - 0V
                  • obelix24
                    • Jun 2023
                    • 300
                    • Slovakia
                    as checking schematics it looks like that CP801 and CP810 should be responsible for transferring voltage from LCDBKLT_EN_L to PPVIN_LCDBKLT_Q so most probably one of this should be wrong ? I have to check when i will be home
                    I've tried also diode mode (red on ground black on pin)
                    on QP800 on ping 1,2,5,6 - 0,899V
                    PPVOUT_LCDBKLT (CP869,CP868,CP867,CP860,CP861,CP862,CP863) - 1.2V (does this mean there is short on this rail ? maybe inject voltage ? 1V 3A ? or never inject voltage to this rail ?
                    • obelix24
                      • Jun 2023
                      • 300
                      • Slovakia
                      mon2 what do you think ?
                      • mon2
                        • 14713
                        What is the voltage to ground of BL_PWR_EN? This must be a logic '1' or at least 1v2
                        Voltage to ground of PP5V_S2 ?
                        The mosfet @ QP800 is acting like a switch from the main power rail to feed into this backlight circuit. QP800 is a P-channel mosfet so this will require the GATE voltage to be lower than the voltage being passed between source / drain pins. At this time, the gate voltage is the same as the SOURCE which results in keeping this mosfet OFF.
                        To enable this mosfet, the gate voltage must be lower and this is lower voltage is created by the voltage divider built by RP801 & RP802. That is, RP802 must be grounded through the backlight IC @ UP800.
                        For now, start with the check to see if the backlight is being enabled.
                        • obelix24
                          • Jun 2023
                          • 300
                          • Slovakia
                          PP5V_S2 - 5,2V
                          BL_PWR_EN - 1,8V
                          • obelix24
                            • Jun 2023
                            • 300
                            • Slovakia
                            mon2 it looks ok.
                            so this means that most probably UP800 is faulty ?
                            • mon2
                              • 14713
                              Perhaps. Carefully, with a piece of wire - connect one side to the gate pin of the mosfet at qp800. The other side of the wire to ground. This action will force the p-channel mosfet to enable. Be sure to study which pin is the gate pin (pin #3) before attempting.
                              Post your results.
                              • obelix24
                                • Jun 2023
                                • 300
                                • Slovakia
                                mon2 I've tried what you mentioned carefully connect pin 3 of QP800 to ground and turned on but still no backlight. Picture was visible but no background as before
                                • obelix24
                                  • Jun 2023
                                  • 300
                                  • Slovakia
                                  I've ordered spare board a2338 to have spare parts. When it will arrive i will try to replace UP800 if this fix issue with backlight. Also i have to replace cd chips as it's taking only 5v
                                  • obelix24
                                    • Jun 2023
                                    • 300
                                    • Slovakia
                                    Today i've received donor board ... I tried to replace UP800 but still no backlight I'm really out of clue what can case this problem
                                    Also MacBook is taking now 19V on both ports.
                                    • obelix24
                                      • Jun 2023
                                      • 300
                                      • Slovakia
                                      according to schematics RP844 and RP845 should be 0ohm ?
                                      both are 10ohms in my case
                                      On one side of RP844 and RP845 I have 5,2V and on other side 5,1V
                                      I'm thinking if I should not try to use wire so there will be 5,2V on input and also on output. To see if this is not causing problems. But I don't want to damage MacBook more ... Does anyone have fully working A2338 where can be checked resistance of RP844 and RP845 ?
                                      • mon2
                                        • 14713
                                        I think you are ok here for the resistance values.
                                        BKLT_EN_R - 0V
                                        So the board is not requesting for the backlight to be enabled. Check the voltage to ground of:
                                        BL_PWR_EN ; the other side of the 0 ohm resistor
                                        IPD_LID_OPEN_1V8 ; the signal that will be used to decide to enable the backlight or not and is linked to the hall effect sensors inside of your trackpad
                                        Carefully also confirm the voltage to ground for:
                                        I2C_BKLT_SCL
                                        I2C_BKLT_SDA
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • som_b1
                                          Macbook screen does not display an image
                                          by som_b1
                                          Hello. I encountered such a problem - the MacBook screen lights up but does not display an image. Almost like a flexjgate in reverse). Maybe someone has encountered such a breakdown. The problem is in the cables or maybe in the t-con?
                                          11-05-2025, 12:20 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • Ado02
                                          MacBook Pro A2159 - No Display / Works on External Screen
                                          by Ado02
                                          I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
                                          Please see the attached image.
                                          I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
                                          Can anyone suggest where to go from here?...
                                          01-12-2023, 03:35 AM
                                        • ledbylight
                                          M1 A2337 Macbook - No Display, likely due to logic board
                                          by ledbylight
                                          Hi all!
                                          This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                          I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                          11-04-2024, 06:36 PM
