HP G62 Overheating
  • lagouzas
    Nemesis3
    • Oct 2013
    • 28
    • Greece
    HP G62 Overheating
    Hello everybody, I need your lights and exepience to gain some time.
    Laptop is HP G62 with an I3 processor and a switchable AMD Radeon GPU.
    Laptop appears a heavy load of RAM use and it's powering down. When powered on, BIOS shows that system was put in hybernation due to overheating.
    My actions:
    - I Cleaned the fan from inside, put new thermal grease compound. (it really gives a blast of cool air now.)
    - I tried new ram module and a used I3 working processor with no effect.
    Laptop cannot complete the format process in windows 7. It always crashes and shows the annoying message.
    I am thinking of the following actions:
    -Modify the fan in order to continuously work. (I don't think that it is needed, but I don't know what else to do.
    - Reball the GPU bga chip. (my customer used to be a heavy gamer.)
    - Reball the northbridge bga chip.
    Any suggestions from someone willing to help would be appreciated.
    Seing is Believing
  • dj_ricoh
    • 2073
    • uk
    Re: HP G62 Overheating
    what message did it show?
    • tomodachi
      • Apr 2012
      • 610
      • Turkey
      My actions:
      I'll be damned ! I have same motherboard on my bench, it was working well yesterday but it shut down because of dust inside the cooling fan while I was installing new OS and not working now Would you please help me clarify whats wrong with it, I need to know if there is 3.3V at first pin of SPI flash rom, mine does not
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Cooling seems to suck like the Athlon II HP Compaq laptops.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • tomodachi
          • Apr 2012
          • 610
          • Turkey
          My actions:
          Hi again,
          I need flash dump file of SPI flash, can you share it please ?
          • jtamad44
            • Apr 2013
            • 145
            • israel
            My actions:
            before you go deeper, try another processor with the same bus speed.
            Check hard drive if the health is ok, othewise if the HDD bad, you can not able to install OS.
            • lagouzas
              Nemesis3
              • Oct 2013
              • 28
              • Greece
              HDD has no bad sector, and processor change had no luck.
              Seing is Believing
              • jtamad44
                • Apr 2013
                • 145
                • israel
                if you got good voltage runnin on coils, caps and 8 legs ic around cpu, the problem might be cpu socket, you can reflow it, use liquid flux. make sure you have good upper/lower heater, otherwise the socket will become uneven after reflow.
                • lagouzas
                  Nemesis3
                  • Oct 2013
                  • 28
                  • Greece
                  If anyone can be helped from that, the problem of the laptop was a faulty heatsink. The fluid or gas, or whatever has inside was absent, so it couldn't freeze the system. No obvious hole on the heatsink... Sometimes things may be simpler than we believe.
                  Seing is Believing
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    lagouzas u think just like me. seen lot of it. somebody just cant disassembly laptop without damage
