How to replace nec/tokin OE128 in laptop motherboard?
  • hitmen
    • Oct 2013
    • 79
    • Pakistan
    Re: How to replace nec/tokin OE128 in laptop motherboard?
    plz indicat wich caps i can use frm abov pics?
    • hitmen
      • Oct 2013
      • 79
      • Pakistan
      can i use anyone like these? Please indicat.
      • jtamad44
        • Apr 2013
        • 145
        • israel
        use the one from Bestsheng Elecronics.. its has 350uf value with low ESR 0.024.. the other black caps has only 315uf with ESR 0.025..
        put 4x350uf ESR 0.024
        • spleenharvester
          • Mar 2010
          • 921
          You want under 10mOhm ESR ideally. Like I said you're best recycling the 4 tantalum caps nearest the CPU on a dead board, they serve exactly the same function. Random caps found elsewhere on the board are almost definitely too high ESR.
          Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
          • hitmen
            • Oct 2013
            • 79
            • Pakistan
            How u find these charactrs of a caps by seeing its pic, but there is no writen esr and voltage? Im new in electrnics.
            Plz detil me.
            • jtamad44
              • Apr 2013
              • 145
              • israel
              #26
              you can get it from here..
              http://www.aliexpress.com/item/Free-...699744043.html
              • hitmen
                • Oct 2013
                • 79
                • Pakistan
                #27
                U dont undrstand my question. I say how can we identify esr and v of a caps?
                • jtamad44
                  • Apr 2013
                  • 145
                  • israel
                  #28
                  i got a lcr/esr meter, it tells you the value and esr.
                  if you are plannin to buy, buy this one with 100 khz frequency..
                  http://www.amazon.com/Precision-886-.../dp/B0000WTXF6
                  • hitmen
                    • Oct 2013
                    • 79
                    • Pakistan
                    #29
                    thnx.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #30
                      Plz detil me.
                      This may be more the answer you want
                      Ok You posted the picture
                      if you move the mouse over the image or copy the link from the picture
                      http://i01.i.aliimg.com/wsphoto/v0/1...pg_200x200.jpg
                      and paste it into notepad you will see among other things the part number 2R5TPE330M9 and the voltage 2.5v
                      If you copy the part number and paste it into google the first listed item I get is the electronics retailer digikey.
                      Click on that and you will see all the details of the item and also a link to a full datasheet for it.
                      http://www.digikey.com/product-detai...art_dkc_buynow
                      The second listing on google is Datasheet archive that will take you straight to the datasheet (may take time to download)
                      http://www.datasheetarchive.com/2R5T...datasheet.html
                      You can find details of most electronic components if you google the part number followed by datasheet.
                      Hard part is understanding them
                      In this case the member who answered you may simply have an understanding of the part numbering as you can see it contains the info 2R5 Must be the voltage TPE is the series 330 is the uf and M9 is the ESR
                      Actually I thought he may have mis typed when he said 350uf value with low ESR 0.024 as it is clearly labelled 330 but see his esr meter may not be accurate? though 350 may be within tolerance.
                      • dj_ricoh
                        • 2073
                        • uk
                        #31
                        omg 835$
                        you can get a fluke for 250 gbp top of the line
                        • jtamad44
                          • Apr 2013
                          • 145
                          • israel
                          #32
                          i'am just kind of shy to recommend my lcr meter, its good but not too good..
                          yes, this is really high price, but some technician they can afford it, this one is better compare to mine.
                          • hitmen
                            • Oct 2013
                            • 79
                            • Pakistan
                            #33
                            I hardly found 6 caps of 220uf and there is written word 'g' near the digits 220. Means, these are of 4vdc. Can i use these caps instead of 4*330uf. If yes, how many caps of 220uf and 4v i use?
                            I will upload pictures of it.
                            • hitmen
                              • Oct 2013
                              • 79
                              • Pakistan
                              #34
                              I upload its picture.
                              • jtamad44
                                • Apr 2013
                                • 145
                                • israel
                                #35
                                i think the value of nec 128 is 1200uf, you can put up to 1500uf.
                                • hitmen
                                  • Oct 2013
                                  • 79
                                  • Pakistan
                                  #36
                                  means, i can use 6 caps of 220uf and 4v.? In which order? Plz give me a simple diagram?
                                  • hitmen
                                    • Oct 2013
                                    • 79
                                    • Pakistan
                                    #37
                                    plz urgently help me.
                                    I want to fix it today,becoz today i am free.
                                    • hitmen
                                      • Oct 2013
                                      • 79
                                      • Pakistan
                                      #38
                                      • hitmen
                                        • Oct 2013
                                        • 79
                                        • Pakistan
                                        #39
                                        simple diagram?
                                        Plz urgent.
                                        Thanks.
                                        • innocentforeign
                                          innocentforeign
                                          • Jun 2013
                                          • 172
                                          • KSA
                                          #40
                                          check this
                                          https://www.badcaps.net/forum/showthread.php?t=8991
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • Username338
                                            Laptop BA92-09470B motherboard schematics
                                            by Username338
                                            Thank you for deciding to read this topic!
                                            Laptop: NP700Z3A-S02RU
                                            Motherboard: BA92-09470B
                                            I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
                                            I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
                                            03-09-2025, 03:52 PM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
