How to replace nec/tokin OE128 in laptop motherboard?
  • hitmen
    • Oct 2013
    • 79
    • Pakistan
    #41
    Re: How to replace nec/tokin OE128 in laptop motherboard?
    1st, please see the pictures below care fully.
    1st picture shows the situation of my laptop's damaged NEC/TOKIN 0E128.
    2nd shows 330 d cap, means smd capacitor of 330uF and 20v.
    U can see that there is blank spaces for capacitors left and right side of the NEC/TOKIN, and two caps of 330d already putted near the blank spaces which shows in pictures.
    I want to know that, can i add two more caps of 330 d in blank spaces because theres plus and minus lines are same? (or any other 2 caps, means 330 g,330 e, 220 g or 220 d. [there, words g, d and e show voltage of caps] . Becuase,i hardly found only these types of caps from another dead motherboard, i cant found 4 caps of 330 e but i have 3 of it)? Instead of pull offing the damaged NEC/TOKIN. Will my problem is solved by this?
    Please help me quickly.
    I am waiting for ur replies.
    Thanks.
    • dj_ricoh
      • 2073
      • uk
      #42
      you try to remove a tokin capacitor with a heat gun?
      thats a plastic cover
      just rip it off slow.
      • hitmen
        • Oct 2013
        • 79
        • Pakistan
        #43
        Please answer my this question only.
        >just I want to know that, can i add two
        • jtamad44
          • Apr 2013
          • 145
          • israel
          #44
          Originally posted by hitmen
          means, i can use 6 caps of 220uf and
          4v.? In which order? Plz give me a
          simple diagram?
          Plz urgent.
          Thanks.
          never tried 4v or 6.3v, but you can try..
          • hitmen
            • Oct 2013
            • 79
            • Pakistan
            #45
            If i try 4v. There is any risk?
            • dj_ricoh
              • 2073
              • uk
              #46
              maybe you will "hardware overclock the CPU"
              :O
              just kidding.
              better safe then sry
              • hitmen
                • Oct 2013
                • 79
                • Pakistan
                #47
                :O
                just kidding.
                Please be serious.
                Can i use 6 caps of 220uf and
                4v in the place of nec tokin or 4 caps?
                • spleenharvester
                  • Mar 2010
                  • 921
                  Remove the NEC Tokin with pliers before you do anything. It could be shorted.
                  Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                  • hitmen
                    • Oct 2013
                    • 79
                    • Pakistan
                    #49
                    okay
                    • hitmen
                      • Oct 2013
                      • 79
                      • Pakistan
                      #50
                      Please tell. I have 6 caps of 220uf,4v. I want to know i use 4 or 6 caps of 220uf, 4v in the place of nec tokin??
                      • jtamad44
                        • Apr 2013
                        • 145
                        • israel
                        #51
                        check if you have enough room for 6x220uf.. you can put those but i don't think it can kick the power all the way up, it might glow as a bulb but not bright as it used to be. lack of powers may be. try and discover it yourself.. remember, we are adventurer.
                        (save some bucks for a new mobo).....
                        • spleenharvester
                          • Mar 2010
                          • 921
                          If the caps are low ESR, then yes, they will work. (where did you find them? If they were by the CPU in the Vcore section of another motherboard, they will be fine)
                          Also, on all the L300 boards I've used - the two positive strips are common to eachother and the two ground strips are common to eachother. So you could put 5x220 on if you really felt like it. A lot of people seem to think there has to be the same amount on both sides.
                          • hitmen
                            • Oct 2013
                            • 79
                            • Pakistan
                            #53
                            I found them from another dual core laptop motherboard and they were putted near the processor.
                            • spleenharvester
                              • Mar 2010
                              • 921
                              They will be fine then.
                              • hitmen
                                • Oct 2013
                                • 79
                                • Pakistan
                                #55
                                But, Many persons suggested 4*330uf,2.5v. But i have only 3 of them. Can i use 3*330uf,2.5v and 1*220uf,4v? Or 5*220uf,4v will be best according to you?
                                Please response me quickly.
                                Thanks.
                                • spleenharvester
                                  • Mar 2010
                                  • 921
                                  Either of those combinations will work. 4*330 is often suggested but it doesn't have to be that combination - I've done 6 of these repairs and used all kinds of combinations. The ESR is fine, the capacitance is fine, the voltage is fine - I can't see any reason why that wouldn't work.
                                  I think 3x330 + 1x220 will be best though, since it reaches greater than 1200uF.
                                  • hitmen
                                    • Oct 2013
                                    • 79
                                    • Pakistan
                                    #57
                                    But different voltage is not matter? 3 of 2.5 v and 1 of 4v?
                                    • hitmen
                                      • Oct 2013
                                      • 79
                                      • Pakistan
                                      #58
                                      I putted 5*220uf,4v(according to ur 1st suggestion) but when i press power button, all indicators on but for a very short time about 1/4 second and off again and i hear a voice like 'tekk' near hdd. When i press power button again and again i observ that again and nothing show on lcd.
                                      Now what i do?
                                      • hitmen
                                        • Oct 2013
                                        • 79
                                        • Pakistan
                                        #59
                                        Quote: Originally Posted by spleenharvester So you could put 5x220 on if you
                                        on both sides.
                                        Again i use 2 * 330 +3*220uf.
                                        But i faced same problem.
                                        Now, What i do?
                                        • hitmen
                                          • Oct 2013
                                          • 79
                                          • Pakistan
                                          #60
                                          Now i use 3*330uf+220uf. But faced same problem.
                                          When i press powr butn nothing is happen(dont runs fans,hdd) only i hear 'tekk', indicators on and at a time off.
                                          What is problem?
                                          Please suggest me.
                                          Thanks.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • Username338
                                            Laptop BA92-09470B motherboard schematics
                                            by Username338
                                            Thank you for deciding to read this topic!
                                            Laptop: NP700Z3A-S02RU
                                            Motherboard: BA92-09470B
                                            I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
                                            I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
                                            03-09-2025, 03:52 PM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
