How to replace nec/tokin OE128 in laptop motherboard?
 Re: How to replace nec/tokin OE128 in laptop motherboard?
 Do you understand that the outer + strips are likely not connected in the PCB?
 This will cause no power to get from the Vcore regulator to the CPU.
 Take some continuity measurements to confirm.Comment
 I cheked it once before, but two inner - strips already connected but i checked to connect outer also but nothing happened.Comment
 I am come back after long time b coz i was so busy and even my laptop still in problem and i couldnt gave it time for repairing. . .
 Frndz . . !
 I find a new thing about my laptop problem, i think it is real problem of my laptop is that, i find 8 terminals device(IC) fired/burried near the battry.
 What happened if this one damaged/fired? And how can i replace it??
 Please please suggest me.Comment
 yes you can replace it.
 we need to know what is it. changing that mosfet soic8 it takes about 1 min to change after you found out what is that and what you need to put back.Just cook it! It's already broken.Comment
 I think, it is 8(4+4) terminals IC which is shown in given pic near the batry.and
 PG2AG
 FDS
 6900S Written on it.
 How and with i can replace it and acording to ur mind what is its function in mothrbord ??Comment
 That part contains two MOSFETs used in a Buck converter for battery charging. Why do you think it is faulty?Comment
 The capacitors AND the links need to be fitted at the same time.
 The Vcore voltage needs to get to the CPU.
 Are you too young to understand this?
 It is likely that you have caused extra damage by now.Comment
 I saw smoke from this when i supplied power and checking differend devices on motherbord by connecting their lines. When i connectio two sides of a capacitor which is shown in pic near mosfet, i saw smoke and smell.Comment
 If the MOSFET is really only for charging. It might be ok just to remove it for now until you fix the other problems. The part near the MOSFET marked with "T" is a fuse.Comment
 Before damaging it, laptop's indicators light up for a bit sec whenever i press powr butn.but now nothng hapend with indicatrz and fan etc, laptop is likely to dead.Comment
 Yes. You should never replace nec/tokin capacitor with same, the laptop will fail again as the nec/tokin parts have short life times and are especially affected by heat (such as soldering).Last edited by Th3_uN1Qu3; 08-27-2014, 07:51 AM.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
 i was use my reballing station to remove the chip and because want come off easily i am afraid that overhead the whole area, also i find that to remove easy the chip must put also a bit of solder.
 After remove the tokin i place the new one and heat it about 5-6 secComment
 You don't mind destroying the old Tokin on removal. Before you solder the new one, remove the unleaded tin from the pads, apply leaded tin, bring your board to 190 degrees with the preheater and you are done.Comment
			by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
			by Geeker007Hi All,
 So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
 So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
 I have not tried putting...
			by Username338Thank you for deciding to read this topic!
 Laptop: NP700Z3A-S02RU
 Motherboard: BA92-09470B
 I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
 I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...-
			This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...09-06-2024, 09:30 PM
			This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 08:47 AM
- Loading...
