How to replace nec/tokin OE128 in laptop motherboard?
Re: How to replace nec/tokin OE128 in laptop motherboard?
I already checked but 2 of 330d already putted of the co, when i putt 4 more they become 6 of 330d, there is any harm???Comment
RIEVAX_60 has got something there - in the above it appears you are justThen i putt battery and place positive line of multimeter on positive of battery and negative line place on different places of PCB of motherboard. I find, current is vary on most places but where was nec tokin there current is same means if battery current is 10.31v, it show 10.31 on both sides( and -) of the capacitors, capacitors, which are putted in the place of nec tokin.
measuring the battery voltage. You will get 10.31vdc wherever you put the
meter black lead on ground.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Once again I opened the laptop and remove all caps including 2 already putted 330d caps and clean it by petrol.
Then i put 6 caps of 330d including 2 which are already putted near nec tokin by co.
And I fitt alll its thing but When i press pwr on button it show same problem means indicators light up for 1/6 second and off immediately.
What is the problem could ????
Please guess??
Thanks in advance.Comment
Are the two outer strips under the NEC/TOKIN connected in the PCB?Once again I opened the laptop and remove all caps including 2 already putted 330d caps and clean it by petrol.
Please guess??
Thanks in advance.Last edited by rievax_60; 11-09-2013, 03:41 PM.Comment
I already checked it by removing all the smd caps nearby tokin and i pres pwr button it show same problm, in the absence of caps and in the presence of caps.Comment
This might sound like a stupid question. But I need to ask.
Have you ever tried having the four capacitors fitted and short wire links joining the outer strips on the PCB, all at the same time?Comment
Yes, but faced same problem. . . .Comment
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by Geeker007Hi All,
So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
I have not tried putting... -
by Username338Thank you for deciding to read this topic!
Laptop: NP700Z3A-S02RU
Motherboard: BA92-09470B
I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...-
This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...09-06-2024, 09:30 PM
This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 08:47 AM
- Loading...
