MSI u135 DX / MS-N0141 works on battery, shutsdown on adapter
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    I'm working on the above laptop motherboard, it's working fine on battery and powers off (including LEDs) when adapter is plugged in.
    Additional Information:
    Model: MSI U135 DX
    Motherboard: MS-NO141
    I'm looking for schematic diagram, could you please post it if you have one?
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Re: MSI u135 DX / MS-N0141 works on battery, shutsdown on adapter
    Shorted mosfets or regulators in the power jack area.
    I can put text here?!
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      Whaldsz,
      if battery and charger is on, what are the LEDs status?
      if power and sleep LED is on, see thread below
      https://www.badcaps.net/forum/showth...ight=msi+cr400
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        1. battery and charger is on - power off or no display. Charging and power led is on
        2. Battery on - boots normally wihout problem
        3. Battery on, then plug adapter after a few minute - power off or no display, charging and power led is on
        4. Charger on - no reaction, but power and charging led is on
        Note: Power button is responding.
        I'll try to check the the voltage regulators that supply memory and cpu if it is latched when charger is inserted. Life could have been easier if schematic for this motherboard is available.
        • whaldsz
          • Apr 2013
          • 395
          • Philippines
          mosfets, and caps are fine. no short. Even reflowed and replaced charger IC. I was hoping for a quick fix on this one that's why I replaced the chip. But still, problem persists - mobo works on battery, turns off when charger is inserted.
          I will take a look at it again, probably there were some time delays when selecting power source from battery to charger.
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            try putting 330uf 2.5v tantalum on vacant pads near proadlizer...
            i think its the same issue with toshiba
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              Thanks francis but no NEC/Tokin cap in this laptop.
              i think the issue is in the charger circuit.
              Just got the schematic for this model, i'll take a look again when i arrive at the ofc.
              • fddizon
                • Sep 2011
                • 555
                • Philippines
                whaldsz,
                did this issue been solved?
                please share...
                thanks
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  never had the chance to sit on this motherboard, the customer requested to pull out the unit.
                  • agogomaster
                    • Oct 2013
                    • Philippines
                    hi im from philippines also. i have the same problem with the same model. charger is fine as i tested it using a voltmeter.looks like the issue is on the motherboard. i badly needed the schematic diagram for this model.
                    • olalskie
                      • Nov 2014
                      • Philippines
                      Re: MSI wind u135 DX lite / MS-N0141.. display problem.. goes on and off if touching or flipping the cover/display. and recently appeared white lines at the right side border of the display.
                      • Topher_UK
                        • Feb 2014
                        • 19
                        • Northern Ireland, UK
                        Olalskie, you should probably start a new thread for this, as it's a totally different fault. However, I would guess the problem is with your LCD cable
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • bykanovm
                          Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                          by bykanovm
                          Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                          If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                          If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                          even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                          Also, the laptop does not turn on without...
                          04-02-2025, 02:45 AM
                        • techfreak9356
                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                          by techfreak9356
                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                          09-14-2023, 11:10 PM
                        • ZixuTech
                          Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                          by ZixuTech
                          Hi Guys, a weird case here.
                          This laptop came with damaged hinges, but no liquid signs.
                          It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                          I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                          I have replaced bq24780S battery charging chip, no difference.
                          With a connected new battery,...
                          04-03-2022, 04:03 AM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
