Reviving a partially working battery?
  • spleenharvester
    • Mar 2010
    • 899
    I've got a battery here for an L300. Looks like liquid has been spilled near the contacts, so maybe some kind of protection system has kicked in.
    Initially, the laptop would not detect it whatsoever. After some cleaning, It is now detected, and reads:
    Designed Capacity: 44400mWh
    Full Charge Capacity: 25308mWh
    Current Capacity: 11mWh
    Battery Voltage: 11.100v
    Wear level: 43%
    Charge level: 0%
    So clearly there is still capacity there. But it simply refuses to charge. As soon as AC is pulled it cuts out.
    I'm going to give the contacts another scrub tomorrow, this time with IPA 99.9%. Any other ideas? Am I safe just pouring IPA onto the contacts?
    Cheers
    EDIT: Cleaned it again and it's gone back to saying "100% wear, 0v, 0mWh". *shrug*
    Cleaned it another time and it's now back to reading with the original list of values.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • thesloc
    Banned
    • Dec 2011
    • 587
    Re: Reviving a partially working battery?
    Why not just replace it altogether? Batteries are like $10 bux mow.
    • spleenharvester
      • Mar 2010
      • 899
      They're £20+ over here ($30USD+). I'd rather get this thing working if possible.
      • thesloc
        Banned
        • Dec 2011
        • 587
        Open it up and replace the board on the battery. Maybe the cells are still good.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          I wonder if the battery control IC needs to be reset.
          Muh-soggy-knee
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • huzo
            HP ELITE X2 1013 G3 weird battery issue
            by huzo
            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
            01-31-2025, 12:09 AM
          • trepachka
            iPad Air A1475 Boot loops after replacing battery
            by trepachka
            This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
            The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
            I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
            11-08-2024, 03:17 PM
