Hey all.
I have a 6735s motherboard here. Bought as "untested, fan was clogged so presumed to be cooked".
It was completely dead upon plugging in, no lights anywhere whatsoever.
Shorting the R1277, C1249 or leg 3 of Q1022 to ground makes the board work and boot fine.
Here's where it starts to get weird:
1) I had exactly the same problem with another motherboard, a 6715s which was also bought as dead, in this thread: https://www.badcaps.net/forum/showthread.php?t=27074
2) Not only that, the schematics are almost EXACTLY the same: 6715s schematic / 6735s schematic
I replaced transistor Q75 in the 6715s which did not resolve the issue so I assume Q1022 is not the problem here either.
I accidentally shorted the gain leg of the FDS6673BZ on the 6715s and blew it straight off, but after that, the board booted and worked fine (but obviously not "repaired").
Could it be that the MOSFETs are the cause of the problem in both cases? Or could it be C1249?
I'm certain my trusty Dell PA-10 is not at fault, it works fine in other laptops and has the exact same voltage/current/center-positive characteristics as the HP adapter. It also worked fine in the 6715s after the leg was blown off.
