6735s - dead - more inside
  • spleenharvester
    • Mar 2010
    • 903
    Hey all.
    I have a 6735s motherboard here. Bought as "untested, fan was clogged so presumed to be cooked".
    It was completely dead upon plugging in, no lights anywhere whatsoever.
    Shorting the R1277, C1249 or leg 3 of Q1022 to ground makes the board work and boot fine.
    Here's where it starts to get weird:
    1) I had exactly the same problem with another motherboard, a 6715s which was also bought as dead, in this thread: https://www.badcaps.net/forum/showthread.php?t=27074
    2) Not only that, the schematics are almost EXACTLY the same: 6715s schematic / 6735s schematic
    I replaced transistor Q75 in the 6715s which did not resolve the issue so I assume Q1022 is not the problem here either.
    I accidentally shorted the gain leg of the FDS6673BZ on the 6715s and blew it straight off, but after that, the board booted and worked fine (but obviously not "repaired").
    Could it be that the MOSFETs are the cause of the problem in both cases? Or could it be C1249?
    I'm certain my trusty Dell PA-10 is not at fault, it works fine in other laptops and has the exact same voltage/current/center-positive characteristics as the HP adapter. It also worked fine in the 6715s after the leg was blown off.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 903
    Re: 6735s - dead - more inside
    I'm tempted to replace C1249 anyway just to see what happens, I have plenty of spares on other dead boards. Is the replacement fine as long as it's 25v, 0.1uf?
    Though having said that, I think the AM4825P may be blown.
    • Tuomo
      • 163
      • Finland
      I thin you should measure this capasitor if it is fail.
      Problems seems to be at Q1022 not take Q1031 PIN 4 to LOW.
      Can you measure Q1022 PIN 1, 2, 3, then you see if Q1022 open or not.
      It may be at ADP_EN# signal is not low then Q1022 not open.
      When you short those pins then Q1031 PIN 4 go LOW which OPEN it.
      • spleenharvester
        • Mar 2010
        • 903
        ADP_EN# measures in at 8.64 volts, as measured from diode D1010's positive side ("1" on schematic). I am guessing this is where the problem lies, then?
        D1010's negative side reads a full 18v.
        Q1022 appears fine I'll take a better look tomorrow when my DMM is fixed up.
        • spleenharvester
          • Mar 2010
          • 903
          More on above
          D1010's negative side - at ADP_EN# - reads a full 19v (sorry info in above post was incorrect)
          D1010's positive side reads ~8v.
          R2006 reads also a full 19v.
          I may be wrong but ADP_EN (not ADP_EN#) reads in at 0v.
          Just found out, when C1249 is shorted and the board booted, it gives the 5 flashing caps lock of death - "System board failure" - could this be because there's no CPU or memory? Or is the board just a dead case and not worth bothering with?
          • Tuomo
            • 163
            • Finland
            More on above
            When shorted C1249 it boots cause Q1031 PIN 4 go LOW.
            I think you should focus on ADP_EN# signal.
            ADP_EN# should be LOW and ADP_EN should be HIGH.
            It looks at AC Adapter not recogniced.
            • spleenharvester
              • Mar 2010
              • 903
              It was the adapter all along. It wasn't sending LIMITsignal and when it's shorted with the 19v supply, everything works.
              So I've blown a 6715s for nothing, and the one I didn't blow, has 5 flashing lights of death.
              ****'s sake
              • spleenharvester
                • Mar 2010
                • 903
                I think I'm gonna get to work on fixing this 5 caps lock + amber flashing issue.
                https://www.badcaps.net/forum/showthread.php?t=23141 I had a similar fault before and gave up and sold it to someone - U1018 turned out to be the culprit. But in this case, U1018 appears to be okay.
                Pressing hard on the BGA chips and powering the system does not help so it does not appear to be the southbridge BGA issue this model can suffer.
                TPS51120 appears to be okay because there are a multitude of 5v, 3.3v and 2.5v sources around the board.
                DDR2 power is fine, CPU Vcore is fine, +5v and +3.3v rails are all fine.
                BIOS chip is receiving power.
                CPU, NB, SB and KBC1091 I/O controller all warm up on booting.
                There's one odd thing I've noticed; sometimes, when booting, the amber HDD light flashes repeatedly. Other times, it will flash twice as fast.
                I wonder where these LED flashing codes are being generated from?
                • Tuomo
                  • 163
                  • Finland
                  I think KBC and South Bridge.
                  You can check few signals.
                  RSMRST = 3V, SB_PWRG = 3V, KBC_SIO_RST# = 3V.
                  RSMRST when 0 reset South Bridge.
                  SB_PWRG KBC voltages OK.
                  KBC_SIO_RST# when 0 reset KBC.
                  • double_DD
                    How can I be sure that my EC chip is dead?
                    by double_DD
                    As the title suggests, how can I be sure that my EC chip is really dead?
                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                    03-12-2025, 07:47 AM
                  • mecha1166
                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                    by mecha1166
                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                    11-25-2024, 05:22 PM
                  • redbaron1007
                    Liquid damaged macbook A1466 fan spins, but doesn't turn on.
                    by redbaron1007
                    I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
                    10-24-2024, 05:45 PM
                  • KYBOSH
                    Trying to Revive - Eufy Security Wired Wall Light Cam S100 - No Power
                    by KYBOSH
                    This found its way to my workbench this week.
                    The buyer thought he got a great deal but it turns out it was likely dead and the seller tried to get anything they could for it by passing it off on an unsuspecting buyer.
                    Rather than tossing it in the bin he gave it to me to play with as he knows how much I love to try to solve problems like these.
                    The camera portion of this device worked fine when powered via USB but when on the mains it would not work at all.
                    This reminded me of the eufy floodlight...
                    09-06-2024, 09:09 PM
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
