HP 6715s - very odd issue
  • spleenharvester
    • Mar 2010
    • 921
    Hey all. Posted this again here in the appropriate section. Other thread can be deleted.
    I have a water damaged HP 6715s motherboard here.
    It works and boots fine into Windows!
    But ONLY IF leg 1 on Q75 is bridged with the DC jack's ground.
    Full schematic here: http://www.mediafire.com/?a317h9te1hxup3e
    I replaced Q75 to only meet the same problem. I thought Q75 was faulty since the multi read 1 on one leg, but it does the same to other identical transistors on the board.
    So presumably, something that's meant to lead to ground, has given up?
    Water damage was only confined to a very small 3x3cm square on the underside of the board, as residue. The spillage had long dried up.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    Re: HP 6715s - very odd issue
    What the heck?
    I just shorted Q75 with DC jack-in by accident. Giant plume of smoke comes up from mosfet Q18, I think oh crap, this thing's done for.
    The board now works perfectly, while one leg on Q18 has literally blown off..?
    What even?
    • katzcaps
      • Feb 2012
      • 48
      Sounds like its fixed to me!
      • spleenharvester
        • Mar 2010
        • 921
        Hahahaha I really have no idea what to do with it now, can't seem to get hold of the exploded mosfet anywhere either! Ah well
        Are there any equivalent replacements around for this?
        • Tuomo
          • 163
          • Finland
          Deleted Message
          • spleenharvester
            • Mar 2010
            • 921
            Cheers for the info mate.
            Any idea what I could change Q18 with? I can't get hold of an FDS6673BZ at any good price!
            Thanks again
            EDIT: It's just struck me, maybe Q18 was at fault all along. I guess we may find out.
            • Tuomo
              • 163
              • Finland
              Thanks again
              This is possible, I have to make sure at I understand correctly that circuit.
              • spleenharvester
                • Mar 2010
                • 921
                It's leg 4 that's blown off for the record. I'm guessing either C43 or R75 would be the other two candidates for being at fault for the initial problem.
                R75 appears fine and reads in at ~21.8kOhms, C43 reads in at 350ohms resistance, but after discharging, doesn't recharge in the opposite direction as per this thread https://www.badcaps.net/forum/showpo...45&postcount=4
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  it looks like, first it was a protection circuit error, but now q18 is short.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Is Q75 connected while you are doing this?
                    I doubt R75 is bad - it is a 220K resistor - that would take a high voltage (hundreds of volts) to burn that sucker!
                    I think you should try replacing Q18. It could have been shorted D-G, and so when you shorted out Q75 (assuming you shorted it's D and G together), a large current flowed through Q18 and burnt out pin 4 (the G of the MOSFET).
                    Muh-soggy-knee
                    • spleenharvester
                      • Mar 2010
                      • 921
                      Q75 is indeed connected. It was a brand new replacement too so should be okay.
                      I've gone through my trashed motherboard stack and found a FDS6679!. It seems to be very similar to the FDS6673BZ. Worth a go?
                      EDIT: Also found a FDS6670S:
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        That could work, but it has a slightly higher on-resistance, a slightly lower continuous current (13A vs original 14.5A), and a lower pulsed current rating of 50A vs the original's 75A rating.
                        Your FDS6670S won't work because it is an N-Channel MOSFET, not a P-Channel!
                        I would say it is worth a try.
                        EDIT: The FDS6679 is lacking a gate-source voltage clamp! Not sure if that would be a big deal...
                        Muh-soggy-knee
                        • spleenharvester
                          • Mar 2010
                          • 921
                          Also just found an FDS6675A but it looks further off to me:
                          If it's no better I might give the 6679 a try.
                          Cheers
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Cheers
                            It isn't better, it has a lower current rating than the 6679, and higher on-resistance.
                            Muh-soggy-knee
                            • spleenharvester
                              • Mar 2010
                              • 921
                              Hmm. I'll look through some more scrap boards later and see if I can come up with something closer, even if it's not a Fairchild FET.
                              Also, if anyone is in the UK, and is after a really oddly specific part, feel free to PM me - I have quite a few trashed boards.
                              • Leefreeman97
                                Diagnosing short to ground issue. pcb from an e scooter
                                by Leefreeman97
                                Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
                                09-19-2025, 03:33 PM
                                20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                by sam_sam_sam
                                I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                04-09-2023, 08:04 PM
                              • ugamazing
                                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                by ugamazing
                                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                12-17-2024, 07:05 PM
                              • Askic
                                Erratic touchpad behavior - ground issue
                                by Askic
                                Hello guys,
                                I'm having almost exact same problem like described here.
                                There is also a youtube video about this issue, but remedy suggested in the video doesn't help in my case.
                                When charger is connected, the touchpad starts with its erratic behavior. So it must be the ground issue. I'm not sure I understand exactly how to solve this.
                                Can you please have a look at the attached picture of the touchpad and suggest what to do exactly to try this solution?
                                In my case it is Acer M3 laptop and not Asus, but the symptoms are the same. Without...
                                08-19-2021, 03:44 AM
                              • shahnld
                                Lenovo legion 5 pro startup issue
                                by shahnld
                                Good day Experts
                                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                08-24-2025, 12:31 PM
