HP 6735s shorted out - Multimeter time!
  • spleenharvester
    • Mar 2010
    • 921
    Had a 6735s brought to me. Would power off whenever it damn well felt like, usually when pressing the touchpad.
    It eventually turned off while I was trying to figure out what the heck's wrong and would then only boot with black screen, 5 flashing caps lock lights and a flashing amber HDD light ("Unspecified system board failure").
    Upon dismantling the laptop it's become clear a screw from the touchpad had fallen out and was wedged with the head on the pins of a DC-DC converter, model # Texas Instruments TPS51120, the pins in question are those facing north in the following picture (can take more pictures of surroundings if need be, but I couldn't get a good, focused picture of the whole board... my camera blows):
    http://i.imgur.com/rcceZ.jpg
    http://i.imgur.com/r0KTZ.jpg
    Touching that area makes the laptop power off in the way it used to so the damage must have been done to that area, if not the TPS51120 chip itself.
    Removing the screw stopped the random power offs, but now obviously, the thing is a brick.
    Anyone know where to start? I've gotten various 5.0V and 3.3V readings from surrounding components..
    Schematic for the chip is here: http://www.ti.com/general/docs/lit/g...US670&track=no
    Cheers!
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    Re: HP 6735s shorted out - Multimeter time!
    Guys, made a bit of progress. (Picture flipped so it can be compared to schematic easily)
    http://i.imgur.com/GxnTM.jpg
    Also of note, the AC adapter jack no longer flashes blue when AC is plugged in, even though it appears to be charging from it. A humming sound also comes from the board with it plugged in.
    http://imgur.com/kVgVW
    Small red circle, just above the IC. Anytime the center of that contact point is touched with the DMM, the power cuts instantly.
    EDIT: AHA! I think I found it. 7v reading back on V5REG (pin #21 on the schematic)
    • spleenharvester
      • Mar 2010
      • 921
      Can't figure this one out at all. Power is getting to the RAM, NB, SB, CPU. But nothing is happening.
      PGOOD1 also has the full 18v going through it. That's probably bad, because the max voltage is 6v.
      • spleenharvester
        • Mar 2010
        • 921
        Aw, missed the post edit time, damn it.
        Found Vref2 also has ~9v going through it when max is 6v. Is this basically a confirmed dead TPS51120 then? How likely is it there are other components in the chain damaged? How can I check?
        Are there any areas I should be testing that I haven't already?
        Also, a squealing sound came at the time the laptop died, though I couldn't see any magic smoke coming from anywhere.
        • spleenharvester
          • Mar 2010
          • 921
          http://www.mediafire.com/view/?dy5b7eupc35k65y
          ^Laptop's entire schematic if that helps someone to help!!
          TPS51120 is now completely dead if it wasn't already, accidentally shorted PGOOD1 with TONSEL (which should have been 2v but was actually 18v). Now PGOOD1 puts nothing out and there's no boot anywhere. Chip also gets scalding hot.
          Still not really found much. Some readings I've scribbled down are as follows:
          Code:
          Readings
          ///TPS-51120 + Surroundings
          +V5A, +V3A, +V3AL fine
          [b]+V5AL (lower) reading in at 7.2V![/b]
          [b]+V5AL (side, pin 4) reading in at 2v![/b]
          VBAT reading in at 4.5v
          R500 okay
          ///Test Pads
          PAD1001/+V5A ok!
          PAD1002/+V3A ok!
          PAD1003/+V1.2S ok!
          PAD1004/+V1.1S ok!
          PAD1005/+VCC_NB reads 1.01v
          PAD1006/+VCC_CORE_NB reads 0.78v
          PAD1007/+V1.8 ok!
          REFERENCE/CHECK LATER
          SMSC KBC-1091-NU is the I/O chip
          RS780
          -Page 3 contains possible leads
          These can be ctrl+f'd in the PDF.
          V3A and V5A are the only readings I've managed to get from TPS51120, can't find the other components with which to measure it.
          Trying to find out a bit more about the POWER_GOOD_3 signal. What reads it? What's generating the whole 5-caps-lock thing? Can't help but wonder if the big SMSC I/O chip is involved somewhere.
          • spleenharvester
            • Mar 2010
            • 921
            Some progress guys.
            Replaced TPS51120 today after an age of waiting for it to arrive. Fitted it, solder joints looking sweet if I may say so myself.
            LEDs at charger point light up. Power button LED flashes briefly. There is a standby 3.3v voltage present, and the correct 18v in present (I have not checked any others for fear of shorting again).
            But no response to power button. TPS51120 warms up, and eventually gets quite hot (though nowhere near as quickly as the last one did).
            Where else could the problem be?
            • lord
              • May 2011
              • 319
              • Croatia
              This one is a bit tricky.
              Where are you from? This boards are usually cheap, and i know i can get new one for less then 150€ (used ones for less than 100€) + shipping fees.
              • spleenharvester
                • Mar 2010
                • 921
                Just thought I'd bump for anyone with the same issue to say I sold the motherboard as faulty/cheaps to someone on ebay not so long ago, it turned out it was U1018 that was the cause.
                • trebo
                  • 514
                  • Wales, UK
                  what is U1018, I have searched scheme but no luck finding it, (I am not very good with schematics)
                  • dj_ricoh
                    • 2073
                    • uk
                    dc/dc converter
                    • trebo
                      • 514
                      • Wales, UK
                      Originally posted by dj_ricoh
                      dc/dc converter
                      Thanks dj
                      • juliorepmed
                        • Jun 2020
                        • 1
                        • Ecuador
                        friend can you help me with computer problem compaq 6735s
                        I already saw the u1018 pin vcc 4.95v and pin out 4.95v pin 1IN + 3.75v and pin 1IN-0v. but I still haven't changed the TPS 51120 AND IT GOT VERY HOT
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3627
                          • slovakia
                          just throw it to bin. this ATI platform is useless to repair.
                          u will still need to rebal/replace ATI NB
                          • BalkanBoy
                            Dead Razer Blade 14 2022, shorted CPU?
                            by BalkanBoy
                            today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                            Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                            I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                            Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                            I removed coil and injected 0.7V, it draw around...
                            09-27-2024, 12:44 PM
                          • ttmi100x
                            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                            by ttmi100x
                            Greetings everyone,
                            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                            Upon closer inspection...
                            07-31-2024, 06:36 PM
                          • guizmo1967
                            Dell Latitude 5501 LA-H181P shorted power rail
                            by guizmo1967
                            This is my problem:
                            Laptop: Dell Latitude 5501
                            Motherboard: EDC51 LA-H181P
                            I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
                            I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
                            I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
                            I injected +1.05V - 2A...
                            07-25-2023, 06:56 PM
                          • titomno2
                            Gaming Laptop Zephyrus S17 TFT not detected every time !
                            by titomno2
                            Hi guys,
                            I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                            So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                            On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                            Then the screen won't work for a long period of time.
                            If I wait 1 or 2 hours it work again most of the time.
                            When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                            01-19-2025, 08:27 AM
                          • davidebaldini
                            ATX power supply keeps blowing PFC mosfets — Cooler Master RS-550-ACAA-E3
                            by davidebaldini
                            This is an ATX PSU rated for 550W powering 24/7 a computer load of about 200W, fed by a line-interactive 1500VA UPS. Mains is 230V.
                            1. First issue: the PSU blew a mosfet on what I think is the active PFC boost converter, shorting its G D S pins together causing a short across the + and - lines produced by the rectifier on the 230V mains. The surge protector of the house tripped. When this happened I found that the UPS was unexpectedly disconnected from the wires of its battery. The UPS wasn't damaged, but I suspect this spontaneous detachment of a battery wire caused a condition that blew
                            01-25-2023, 02:23 PM
