Liquid damaged macbook A1466 fan spins, but doesn't turn on.
  • redbaron1007
    • Jun 2021
    • 117
    I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the same thing as before. The only damage to the area is the gnd pin for the bios chip is gone. As I write this I realized I never rebuilt that pad because I figured it wouldn't matter since the big gnd on the bottom of the chip was intact. The corrosion was mostly on pins 3,4,7,8 and nowhere else on the board. I forgot to take a picture unfortunately of the affected area.
    I measured the current draw from the charger and I'm getting 20v with 0.5A initially then it occasionally will dip to 0.3A after about a minute then after another minute it will jump back to 0.5A. It doesn't always fluctuate and when it does it always goes back to 0.5A. Pressing the power button also doesn't change how much power it's drawing from the wall.
    I checked the bios chip with my oscilloscope and found that I had only flat 3.3V readings on all pins except for the spi_clk line where I had nothing at all. I checked the pins on the clock generator IC and I believe I had all the correct clock signals coming out of it. I had 24mhz signals present on all the pins that I believe I should according to the board schematic. I haven't tried replacing the IC yet. I'm out and waiting on some new ones to be delivered tomorrow. From reading another post on badcaps I did check all the resistors in line with the spi_clk and all of them tested fine in circuit (the 15ohm and 43ohm ones read spot on so I didn't see any reason to take them out of circuit to test).
    I did try a working bios chip that was already programmed off another board I had with a dead cpu and nothing changed. I also did the basic short hunting and everything tested fine and when checking the resistance of the inductors to gnd they all read normal. Nothing high and nothing low.
    I did take voltage measurements at all the large inductors as well
    L7310: 1.8V
    L7320: 1.8V
    L7630: 1.06V
    L7430: 1.2V
    L7560: 3.3V
    L7520: 5V
    L7130: 8.5V
    L3095: 0V
    L7701: 0V
    I also checked both fuses and they weren't blown and both had 8.58V present. In some other spots I was able to read 12V, but never any 20V other than on the charger board. I'm assuming the 20v rail is fine though since I have lower voltages present even when the battery is unplugged. In general all the testing I've done has been with the battery disconnected.
    Other than waiting on more clock gen IC's to come in tomorrow I'm kinda at a loss for were to go from here since everything else at first glance and testing looks to be ok. There's plenty more I probably could have tested, but I didn't feel like sticking around work any later than closing.
    Side note tangent I don't know how these macbooks always get one tiny little drop of water inside them with no signs of water anywhere else in or outside the laptops. I swear they make these boards out of sponges.
  • reformatt
    • Feb 2020
    • 1534
    Primary area to check is U6101 connectivity to U6100. Also test connections from BIOS chip to the CPU (e.g. U6100/5 to R6112 etc). Ensure J6100 is clean and not corroded. U1930, R1931 etc often corroded.
    The bottom side of the board is the closest to the air vent, so cops most of the corrosion from accumulated dust and moisture in the air. From experience on MAC boards, any passive component with corroded/grey end caps needs to be removed and discarded, and pads cleaned up. Test pads are sometimes in line with a track, so often go open circuit. Isolated spots of corrosion at other parts of the board are usually from decomposing insects, or their droppings.
    • mon2
      A1466 Macbook Air (Liquid damage repair)
      by mon2
      Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
      Macbook AIR Model A1466 Diagnostic 09-01-2021
      Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
      Problems & Resolutions
      1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
      09-01-2021, 09:31 AM
    • BMCappelletti
      Macbook Air A1466 EMC 3178 missing power and liquid damaged
      by BMCappelletti
      Hi everyone.
      Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
      Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
      04-15-2024, 01:24 PM
    • sherifu
      Macbook Air A1466 Emc 3178 No light charger after spilling liquid
      by sherifu
      Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
      03-26-2024, 04:54 PM
    • psdavid65
      Macbook Air A1466 820-3437-B Booting Problem
      by psdavid65
      I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
      06-20-2024, 12:27 AM
    • mitchw
      MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
      by mitchw
      Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
      It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
      I quickly took it apart and washed the liquid residue off the mainboard.
      The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
      The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
      Now the laptop...
      07-16-2025, 07:55 AM
