Acer Aspire 5738G (5536, 5538) 15.6" inverter pinout
  • hercooles
    • Sep 2011
    • 7
    Hello!
    LCD cable's inverter connector was broken. I have a new connector for the cable but I dont know the correct sequence. I know only the two side one, its the green and the brown. I have blue, purple, black and gray.
    Any ideas? I already tried to google picture about it but all was covered with black tape.
    Cables original code is: 50.4cg13.012. Inverter type: 19.21030.m46
    Its a 15.6" CCFL LCD
    Thanks!
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Acer Aspire 5738G (5536, 5538) 15.6" inverter pinout
    is this not a flat ribbon cable - if you know the two outers then the others will be in order?
    Please update your profile with country and mains voltage
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      vin 10-18v, gnd, 3.3v for on/off and brigtness(you can identify by pressing fn and brightness + - while measuring.)
      • ignisydney
        • Jan 2015
        • India
        Hello there,
        I am looking for the schematics of hp mini 110 - 3606tu laptop. Thanks
        • lezsimply
          The Wanderer
          • 646
          • Philippines
          start your own thread
            Acer Aspire A515-51G-5536 Notebook 5 Specification for Upgrade or Repair
            This specification for the Acer Aspire A515-51G-5536 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-51G-5536 boardview and A515-51G-5536 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:46 AM
          • x_orange90_x
            Vizio E55-E1 bad backlights or bad inverter?
            by x_orange90_x
            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
            I don't know how exactly to test the inverter itself. Is it...
            01-29-2025, 09:24 PM
          • Gentian
            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
            by Gentian
            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
            03-06-2023, 07:07 AM
          • valvashon
            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
            by valvashon
            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
            01-04-2024, 01:44 PM
          • eccerr0r
            A modified sine wave inverter + a grid tie inverter?
            by eccerr0r
            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
            Next thing is trying to charge the batteries using solar power, but that's another issue ...
            08-31-2023, 09:14 PM
