PM_I_hpc_s mv_mb_v3
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    PM_I_hpc_s mv_mb_v3
    with battery it starts wit blank screen, no post. But with adapter not triggering. i'm taking out the mobo now. Hp G62.
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: PM_I_hpc_s mv_mb_v3
    hmm, its not working with adapter, because my adjustble dc voltage regulator is not supported by the system of this hp g62. it works with its own charger. So i think next i'll re-programme the bios.
    • Francisco.s
      • 686
      • Spain
      Hi spidey, could you explain in a better way?.
      Regards.
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        some hp laptops doesnt work with 2 pin adapter. so if you want it to work with 2 pin adapter, like mine you need to do some modification. you may try connecting 3th pin to gnd. i havent found the schem. yet. there is a problem in vcore power circuit. Cpu is overheating too much. i think cpu 's allready dead so i decided to give it bck to customer.
        • Francisco.s
          • 686
          • Spain
          PM_I_hpc_s mv_mb_v3 = Foxconn Federer, if you want it, I have the schematic.
          Regards.
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            it would be great. thanks. you can give a link or i'll give my mail to you via pm.
            • Francisco.s
              • 686
              • Spain
              it would be great. Thanks. You can give a link or i'll give my mail to you via pm.
              • spidey
                climbs
                • Dec 2012
                • 644
                • Cyprus
                Originally posted by Francisco.s
                thank you very much..
                • Francisco.s
                  • 686
                  • Spain
                  Hi spidey, I am very interested in your modification for 2 pin adapter. Is it possible for you to show how to do it over the schematic?
                  Regards.
                  • tomodachi
                    • Apr 2012
                    • 599
                    • Turkey
                    Mine was shut down yesterday due to overheating but mine had too much dirt in cooling fan. Now it has 3.3V on power button but no power on SPI flash, I m very confused,
                    I need a hand for this motherboard.
                    • whaldsz
                      • Apr 2013
                      • 395
                      • Philippines
                      You're probably looking at BIOS ROM (page 13) and not KBC ROM (page 25).
                      • tomodachi
                        • Apr 2012
                        • 599
                        • Turkey
                        Yes, BIOS rom has no voltage but KBC rom has 3.3V.
                        I guess I need dump for KBC rom because KBC doesn't power up the system.
                        • whaldsz
                          • Apr 2013
                          • 395
                          • Philippines
                          Right.
                          • mohamed.mostafa
                            • Sep 2012
                            • 40
                            • egypt
                            give the model g62-***** so i can share the EC dump file.
                            • tomodachi
                              • Apr 2012
                              • 599
                              • Turkey
                              sorry I'm late, G62-B11ET
                              • tomodachi
                                • Apr 2012
                                • 599
                                • Turkey
                                Update : I get not light on ac connectors led with adapter but when I use battery I see led blinks 3 times indicating me battery is empty.
                                does it mean charger (8731AE) is gone ? some help would be great.
                                schematic is here;
                                • whaldsz
                                  • Apr 2013
                                  • 395
                                  • Philippines
                                  3 blinks is memory, i think.
                                  • tomodachi
                                    • Apr 2012
                                    • 599
                                    • Turkey
                                    Nope, today I fixed it changing 8731AE charger and it worked!
                                    Problem description;
                                    When plug AC adapter no power no blink but when plug a charged battery motherboard powers on. MAX8731AE have a circuit for switching between AC power and battery and it was broken.
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1488
                                      • portugal
                                      I've got the same problem , g62 , i got the 3.3 volts on the main DCDC converter , getting 3.30 volts on on off button and drop to 0 when pressed ,cheked coild for dc output , i dont get 5 volts , and there is no short to the ground , cheking fet coils and caps after main dcdc , all are in shape .. simply dont notice light on the dc jack .. , could this be a bios problem ? main dc was changed and do the same thing . and also i dont get voltage on the bios IC
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1488
                                        • portugal
                                        also i dont get VCC +3.3S on the KB , also notice i should have on pin 33 of ITEkb , and ther eis no voltage there , as also there is no rsmrst as well ..i got some 3alw voltages on KB , but not main vcc
                                        • hasel17
                                          CH341a can erase and read but can't write and blank check
                                          by hasel17
                                          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                          Code:
                                          Checking for blank...
                                          (Press
                                          10-26-2023, 06:20 AM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • RetroComputingGrotto
                                          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                          by RetroComputingGrotto
                                          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                          I've uploaded a video of it happening on YouTube:
                                          I've taken the monitor...
                                          01-11-2024, 05:37 AM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • Cerberuska
                                          Mobo MSI B550-A PRO password popup
                                          by Cerberuska
                                          Hello guys,
                                          I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                                          BIOS I updated to last one.
                                          any suggestions?
                                          And same thing for two different 5600G, and yes, MoBo supposed to support it.
                                          Thank you...
                                          11-10-2024, 01:23 PM
