PM_I_hpc_s mv_mb_v3
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: PM_I_hpc_s mv_mb_v3
    nop wrong i was cheking the chipset rom , the main spi bios is ok , she got 3.3 volts on pin 3 7 and 8
    • lezsimply
      The Wanderer
      • 656
      • Philippines
      Excuse me for asking is EC bios different from KBC bios? Thanks
      • tomodachi
        • Apr 2012
        • 607
        • Turkey
        Do you have any chance to plug a full battery and try to power on then ?
        Because you have similiar symptoms as I 've encountered before.
        Remember, never ever connect two adapter pins together, it blows the charger chip. Use original HP charger.
        • Francisco.s
          • 686
          • Spain
          also i dont get VCC +3.3S on the KB , also notice i should have on pin 33 of ITEkb , and ther eis no voltage there , as also there is no rsmrst as well ..i got some 3alw voltages on KB , but not main vcc
          Which schematic are you using?
          Did you check voltage at pin 8 of EC-BIOS?
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            im using hp_g62_compaq_cq62_foxconn_star_federer_rev_1.0_sch , cheked EC bios there is no voltage there only on sprom , for what i can manage and understand after cheking schematic is that there is some anomaly on s3 state , since some os the voltages that shouldbe present are not there, therefor kb will not work properly
            im now trying to find out why i dont get 5 volts on main dc dc , and since i dont have that voltage i also dont get 5Val on the tsp51117 (1.5v ddr3 and outher smal voltages ) cheked that PQ762 should have on pin 3 voltage there due to RUN_on_load therefore i can't get as well any voltage for +3S , since i dont have this voltage i also can't have VCC on kb controler (should be +3S and its 0)
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              #26
              EC bios , 0.39 volts
              poin 3 , 7 and 8
              spi rom
              3:30 on pin 3 7 and 8
              • tomodachi
                • Apr 2012
                • 607
                • Turkey
                #27
                poin 3 , 7 and 8
                spi rom
                I can't tell how I sure about that charger chip.
                • Francisco.s
                  • 686
                  • Spain
                  #28
                  poin 3 , 7 and 8
                  spi rom
                  You should check +V3.3A at pin 8 of UI6. (EC SPI ROM)
                  Also check EC_ALW_EN and PWR_SWIN# signals are both working properly.
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    #29
                    like i mentioned before , spi rom , got 3.30 volts on pin 3 , 7 and 8
                    for EC_alw_en got 0 volts
                    for PWR_SWIN got 3.29 volts
                    • Francisco.s
                      • 686
                      • Spain
                      #30
                      Then, reprogram UI6.
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        #31
                        ok , i will reprogram the bios with the latest version i'll find in the website of hp and i let you know
                        • Francisco.s
                          • 686
                          • Spain
                          #32
                          EC-bios is the same as kbc bios. (UI6, page 25)
                          PCH-bios (or main bios) is US2. (page 13)
                          Some motherboards have the code of EC-bios integrated in the PCH-bios, so only one bios chip is needed. It is connected to intel PCH chip.
                          Regards.
                          • lezsimply
                            The Wanderer
                            • 656
                            • Philippines
                            #33
                            Thank you very much Francisco, I really appreciate it
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              #34
                              reprogramed u16 , (before i add changed the chip by another board i had here and nothing happen, even like this i reflashed the bios with the latest bios update , and the same , no DC jack led , and no 5 volts .
                              • Francisco.s
                                • 686
                                • Spain
                                #35
                                Check KBRST#_D voltage and 32KXCLKO/32KXCLKI frequency.
                                --STAR(FEDERER)--
                                • whaldsz
                                  • Apr 2013
                                  • 395
                                  • Philippines
                                  #36
                                  Check RSMRST# if 3.3v is present.
                                  But the lack of 5v is also a concern. You must fix this first.
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1488
                                    • portugal
                                    #37
                                    rsmrst = 3.30 volts .
                                    not having 5 volts is what is driving me nuts , could this be like powersaver issue ? since there is no short on the god dam line rail ....
                                    • whaldsz
                                      • Apr 2013
                                      • 395
                                      • Philippines
                                      #38
                                      What do you get at pin 7 and pin 27 of PU850?
                                      • tomodachi
                                        • Apr 2012
                                        • 607
                                        • Turkey
                                        #39
                                        Just laughing and reminding u the charger chip again
                                        • tomodachi
                                          • Apr 2012
                                          • 607
                                          • Turkey
                                          #40
                                          guys mine is working but there is no +VDD_CORE voltage on my motherboard, so no power at GPU chip, what is possibly causing that ? any help will be appreciated.
                                          • hasel17
                                            CH341a can erase and read but can't write and blank check
                                            by hasel17
                                            So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                            Code:
                                            Checking for blank...
                                            (Press
                                            10-26-2023, 06:20 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • kotel studios
                                            Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                            by kotel studios
                                            Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                            State I got it in:
                                            Squealing from the PSU
                                            After logo I get a blank screen
                                            After 10 seconds of having a blank display w/ backlight the TV dies
                                            Give it 7-10ish seconds again and it starts to bootloop.
                                            What I did so far:
                                            Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                            Checked all voltage rails:
                                            5VSB - 4.8V
                                            AMP+13V - 14.4V
                                            13V - 12.98V (in manual 12V)...
                                            09-21-2025, 02:00 AM
                                          • RetroComputingGrotto
                                            Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                            by RetroComputingGrotto
                                            I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                            I've uploaded a video of it happening on YouTube:
                                            I've taken the monitor...
                                            01-11-2024, 05:37 AM
                                          • Chrissygizmo
                                            Panasonic TX-48CX350B backlights but white screen , blank screen
                                            by Chrissygizmo
                                            Hi all, I’ve got a problem I hope someone can help me fixi.
                                            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                            01-11-2025, 03:18 PM
