Hiya, hope you everyone had a nice Christmas. I have VGN-NS10L with a dodgy screen that I'm trying to repair and it has quite a telling fault. The screen will work fine for minute or so before the image shakes for a second or so then fades to seemingly black. If I shine a torch on the screen I can see a very dark version of what should be bright i.e. the windows desktop. This is definitely a hardware fault as this will occur both inside and out of windows such as at the BIOS screen. Can anyone suggest the most likely fault or the best tests to perform to ensure the nature of the fault?
VAIO Bad Backlight?
YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
I also changed the screen because the PC fell and the screen was broken.
I changed the battery with a new and original battery.
I also had corrosion/oxidation on the... -
by frannyjunkSo I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
TIA. -
by turmixHello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
During another reassembly, I made a mistake, and...-
by FallenOne008Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself... -
by trepachkaI am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.-
- Loading...
