Not an electronics question obviously, but I get a lot of machines that could do with some plastic repairs. The biggest fault tends to be mount-points snapping off at the base or splits appearing along stress risers.
Plastic repairs?
Plastic repairs?
YouTube Repair Videos - https://www.youtube.com/user/19PLD73
FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbvTags: None -
Re: Plastic repairs?
Ended up using an old trick from my R/C aircraft building days - used CA/superglue and then dusted it with bicarb to turn it to rock hard filler. Downside is that it's rather brittle but it does hold quite strong.
There was enough of the old post still left for me to place the brass inset; an oiled screw inserted let me keep it aligned right and then I glued/dusted it a few times till I had built up enough material. The oiled screw prevents the glue locking the thread.YouTube Repair Videos - https://www.youtube.com/user/19PLD73
FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv -
That is an interesting idea for repairing plastic. How much bicarb (baking soda?) do you use and how long do you wait between layers? Some laptops just have a lot of flex do to poor design / materials, how would this method hold up in such an application since you mention it is brittle? What are the advantages and disadvantages of this method compared to using epoxy? Sorry for all the questions but they make prevent me form making a big mess experimenting.Comment
If you put the CA down first, then just drop a pinch of bicarb over it to fully cover the area, then about 5 seconds later blow away the excess or tip it out. WARNING: it will get quite hot, so don't get your finger on the join
As for flexy situations, so long as the area you're gluing isn't too large it should be okay. On the model aircraft (balsa/fiberglass) there'd be quite a lot of flex but the joins held up okay.
Compared to epoxy;
PRO: cheaper, faster, harder, better adhesion (at least what I've found)
CON: brittle, requires layers if you want to build up bulkYouTube Repair Videos - https://www.youtube.com/user/19PLD73
FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbvComment
Practice on some older chassis perhaps? Because of the low viscosity of most super-glues (unless you get the gel ones), it's better to reposition the parts into their right place -before- applying the glue + bicarb. Also, you don't have to rush, a drop of superglue will stay liquid for quite some time on plastic surfaces like laptop cases (though it'll set near instantly once the bicarb is applied).YouTube Repair Videos - https://www.youtube.com/user/19PLD73
I never knew they made such a product, excellent find. Apparently my local Home Depot carries this for $3.77. Looks like something to keep around because you are going to need it eventually.
Inflex's method could be applied to mixed materials, items that are not plastic that the Loctite system would not be a suitable bonding agent, or used if you have the supplies on hand and the store is closed. I am sure I will be making use of this information in the very near future.Comment
Wish I could get that loctite system as cheap here. They want $25 !!!
Aaah, I was looking at the wrong number - anyhow, that "activator" they have with the superglue in the Loctite 681925, it's basically the same as what bicarb is doing.YouTube Repair Videos - https://www.youtube.com/user/19PLD73
There's Selleys Plastics Glue which looks similar
http://www.selleys.com.au/adhesives/.../plastics-glue
IIRC it was around the $8 mark from Bunnings
Didn't work well enough for me, that I'd buy it againbetter to keep quiet and be thought a fool, than to open your mouth and remove all doubtComment
Very interesting - haven't seen that one at the local shops (but this is a small country town). Looks like they're all CA+activator combos, so for now I guess I'll be sticking with my CA+bicarb and then JB-Weld for super-serious situation, or at times I'll fabricate replacement parts out of polybeads.YouTube Repair Videos - https://www.youtube.com/user/19PLD73
Another job I did last night. Not quite sure how the client managed to break the primary mount post on the back-housing of the LCD, but they did.
Anyhow, a few layers of CA+bicarb has done the trick again.Attached Filesif you find these attachements useful please consider making a small donation to the site
I have done a lot of plastic repairs with JB Weld. The hinges on my old Gateway laptop are held in with nothing but JB Weld because the piece of plastic that the hinges are attached to (the housing around the display - Gateway calls this the "top lid") is not available. Even if I could get a replacement top lid, there isn't much plastic around the metal inserts.Last edited by lti; 10-19-2012, 08:55 PM.Comment
Lti, I use JB-Weld if the CA-Bicarb option fails. Mostly because of costs and that it takes a few hours before I can use the repair.
I do love JB-Weld, great stuff, at least half a tube holding my car engine together in some places
by KemerHello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
The plastic piece doesn't appear to be broken.
1. What are your suggestions for resolving this issue?
2. Is the plastic piece made of special ma... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by corrizeHello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
I have :
- hot air, and a ll stuff around
- true kapton tape
- 140 and 180 degree soldering paste
- bismuth
- little hot plate 250 degree max
- the new BGA chip with probably... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by corrizeHello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
CMOS sensor seems resist to high temps.
But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
I have low melting point solder.
I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test... - Loading...
