Plastic repairs?
  • inflex
    • Aug 2012
    • 545
    Plastic repairs?
    Not an electronics question obviously, but I get a lot of machines that could do with some plastic repairs. The biggest fault tends to be mount-points snapping off at the base or splits appearing along stress risers.
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • inflex
    • Aug 2012
    • 545
    Re: Plastic repairs?
    Ended up using an old trick from my R/C aircraft building days - used CA/superglue and then dusted it with bicarb to turn it to rock hard filler. Downside is that it's rather brittle but it does hold quite strong.
    There was enough of the old post still left for me to place the brass inset; an oiled screw inserted let me keep it aligned right and then I glued/dusted it a few times till I had built up enough material. The oiled screw prevents the glue locking the thread.
    • LDSisHere
      • May 2012
      • 727
      • U.S.A.
      That is an interesting idea for repairing plastic. How much bicarb (baking soda?) do you use and how long do you wait between layers? Some laptops just have a lot of flex do to poor design / materials, how would this method hold up in such an application since you mention it is brittle? What are the advantages and disadvantages of this method compared to using epoxy? Sorry for all the questions but they make prevent me form making a big mess experimenting.
      • inflex
        • Aug 2012
        • 545
        If you put the CA down first, then just drop a pinch of bicarb over it to fully cover the area, then about 5 seconds later blow away the excess or tip it out. WARNING: it will get quite hot, so don't get your finger on the join
        As for flexy situations, so long as the area you're gluing isn't too large it should be okay. On the model aircraft (balsa/fiberglass) there'd be quite a lot of flex but the joins held up okay.
        Compared to epoxy;
        PRO: cheaper, faster, harder, better adhesion (at least what I've found)
        CON: brittle, requires layers if you want to build up bulk
        • LDSisHere
          • May 2012
          • 727
          • U.S.A.
          Thanks for the fast response. I will have to give this a shot in the future and see how it works for me. I just hope I am not too messy, I could see this easily going from rescue to disaster in one quick oops.
          • inflex
            • Aug 2012
            • 545
            Practice on some older chassis perhaps? Because of the low viscosity of most super-glues (unless you get the gel ones), it's better to reposition the parts into their right place -before- applying the glue + bicarb. Also, you don't have to rush, a drop of superglue will stay liquid for quite some time on plastic surfaces like laptop cases (though it'll set near instantly once the bicarb is applied).
            • ecking767
              • Oct 2009
              • 492
              I use this product from Loctite call Plastics Bonding System Model # 681925
              You can buy it at your local hardware store. Its work for me and its hold very strong
              • LDSisHere
                • May 2012
                • 727
                • U.S.A.
                I never knew they made such a product, excellent find. Apparently my local Home Depot carries this for $3.77. Looks like something to keep around because you are going to need it eventually.
                Inflex's method could be applied to mixed materials, items that are not plastic that the Loctite system would not be a suitable bonding agent, or used if you have the supplies on hand and the store is closed. I am sure I will be making use of this information in the very near future.
                • inflex
                  • Aug 2012
                  • 545
                  Wish I could get that loctite system as cheap here. They want $25 !!!
                  • inflex
                    • Aug 2012
                    • 545
                    Aaah, I was looking at the wrong number - anyhow, that "activator" they have with the superglue in the Loctite 681925, it's basically the same as what bicarb is doing.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      There's Selleys Plastics Glue which looks similar
                      http://www.selleys.com.au/adhesives/.../plastics-glue
                      IIRC it was around the $8 mark from Bunnings
                      Didn't work well enough for me, that I'd buy it again
                      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                      • inflex
                        • Aug 2012
                        • 545
                        Very interesting - haven't seen that one at the local shops (but this is a small country town). Looks like they're all CA+activator combos, so for now I guess I'll be sticking with my CA+bicarb and then JB-Weld for super-serious situation, or at times I'll fabricate replacement parts out of polybeads.
                        • inflex
                          • Aug 2012
                          • 545
                          Another job I did last night. Not quite sure how the client managed to break the primary mount post on the back-housing of the LCD, but they did.
                          Anyhow, a few layers of CA+bicarb has done the trick again.
                          • lti
                            • May 2011
                            • 2555
                            I have done a lot of plastic repairs with JB Weld. The hinges on my old Gateway laptop are held in with nothing but JB Weld because the piece of plastic that the hinges are attached to (the housing around the display - Gateway calls this the "top lid") is not available. Even if I could get a replacement top lid, there isn't much plastic around the metal inserts.
                            • inflex
                              • Aug 2012
                              • 545
                              Lti, I use JB-Weld if the CA-Bicarb option fails. Mostly because of costs and that it takes a few hours before I can use the repair.
                              I do love JB-Weld, great stuff, at least half a tube holding my car engine together in some places
                              • Kemer
                                Led status indicator light transfer plastic
                                by Kemer
                                Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
                                There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
                                The plastic piece doesn't appear to be broken.
                                1. What are your suggestions for resolving this issue?
                                2. Is the plastic piece made of special ma...
                                08-19-2025, 07:02 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • corrize
                                Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                                by corrize
                                Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                                There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                                I have :
                                - hot air, and a
                                ll stuff around
                                - true kapton tape
                                - 140 and 180 degree soldering paste
                                - bismuth
                                - little hot plate 250 degree max
                                - the new BGA chip with probably
                                05-20-2025, 01:26 AM
                                by momaka
                                03-15-2023, 10:17 PM
                              • corrize
                                Soldering plastic low profile FPC close camera CMOS sensor ?
                                by corrize
                                Hello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
                                CMOS sensor seems resist to high temps.
                                But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
                                I have low melting point solder.
                                I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test
                                07-12-2024, 02:21 PM
