Gateway MA2A power on issue pics included
  • SheDevil
    • Oct 2005
    • 8
    My son got it off craigslist and has worked fine for a few months, then all the sudden it just shut off. I have 19v on the pos center pin on back of the dc jack, checked continuity on grd points and pos to pos of the jack while wiggling it and all says good there. It was running for a while on just the ac adapter and battery or HDD but quit again. With some finessing I can get it to power on again, but I don't know where to test from here.
    It kind of looks like the pos pin has been reflowed, but not the other pins. Considering I found a small screw had magnetized itself to the HDD, and they did not put the HS backing plate on the otherside of the MB when they re-assembled it, I'm not sure if it is a heat issue or power issue. I'm trying to find one of those triangular things on ebay. This is my first attempt at a laptop MB, but have repaired many lcd and desk top boards.
    But until then could someone mark up the photos of what needs to be tested?
    I have attached these pics as they look different than the ones posted in the MA7 thread. https://www.badcaps.net/forum/showthread.php?t=8305 If you need other(better) pics let me know.
    The number on the board says DAMA2AMB8C3 REV:C
    Not sure if that is suppose to be touching each other?
    TIA
    Angel
    Re: Gateway MA2A power on issue pics included
    That is solder bridge, looks like someone trying to re-solder the center pin and bridge over to the pad next to it.
    By the way, what do you use to add text to the pictures, nice pictures taking too.
    • Spitz
      • Oct 2010
      • 95
      [QUOTE=SheDevil;With some finessing I can get it to power on again, but I don't know where to test from here.
      It may have the same issue that the ma3 and ma7 boards do. On the top side make sure that the center pin is making contact with the track and the components. The picture of the bottom of the board looks good, but the top looks like the track is eaten away around the center pin. You may have to run wires between the center pin and the components on the top side.
      • SheDevil
        • Oct 2005
        • 8
        That was my first thought also, but after getting some better closeups it is not burnt or bridged. They must have spilt pop on it.
        This is what it looks like now
        I used Fastones draw board feature http://www.faststone.org/FSViewerDetail.htm
        • b700029
          Banned
          • Sep 2010
          • 640
          You can see if a schematic can help with your troubleshooting.
            Boy b700029, where did you find all these service manuals for laptops? May be you should upload them to Tom's website.
            • Spitz
              • Oct 2010
              • 95
              Originally posted by SheDevil
              That was my first thought also, but after getting some better closeups it is not burnt or bridged. They must have spilt pop on it. [/URL]
              I would still recommend adding the jumpers even if it looks okay. Have you checked with a meter for voltage on the components and not just the center pin?
              • techboyBG
                • Aug 2012
                SheDevil, this PL5 component should be coil and soldered in this way its your ground. Its definitely shouldnt touch positive/center pin of the power connector.
                You should separate them with soldering iron or (if you dont have) you can use sharp tool to cut and remove exceed solder between central point and pl5 coil.
                Sometimes solder gets expanded by itself caused by quick temperature changes. Thats why it makes contact with Ground and doesn't alows notebook to power on, making short to the power supply.
                • b700029
                  Banned
                  • Sep 2010
                  • 640
                  Google.
                  • SheDevil
                    • Oct 2005
                    • 8
                    Just these points so far.
                    On the last 2 battery pins I get .7v, on the 3rd from the bottom I get 3.4v.
                    I'm just not sure what to test next. Don't want to make it worse.
                    Off to manage my friends kids new school NB, wifi not on the approved list.
                    Now that the whoopla of first day of school is over I can look at that PDF and see how greek to me it will be.
                    thanks for finding it.
                    And attempt to solder top to bottom a piece of wire and see what I get.
                    TIA
                    Angel
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                      🛠 Original Issue
                      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • ugamazing
                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                      by ugamazing
                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                      12-17-2024, 07:05 PM
                    • wattage
                      by wattage
                      Hello Badcaps Community,
                      07-13-2025, 04:41 PM
                    • elmark
                      HP 15-cw1002ua strange keyboard issue
                      by elmark
                      HP Pavilion 15-CW1002UA
                      S/N 5CD0251CBC
                      P/N 7KE54EA
                      Hello guys!
                      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                      It powers on OK and has no other issues except the following:
                      • CAPS LOCK does not work at all
                      • Fn button toggles Flight Mode
                      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                      • (with SHIFT pressed: 't%' and 'y^' respectively)
                      I initially thought it was a keyboard malfunction (internal short, etc.),
                      but when I press and hold...
                      06-27-2025, 01:10 AM
                    • Simone Vergani
                      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                      by Simone Vergani
                      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                      To assist with troubleshooting, I'm attaching two power circuit schematics:
                      • Power
                      03-05-2025, 02:25 PM
