HP cq61 not starting
  • riget
    • Sep 2011
    • 66
    Re: HP cq61 not starting
    Ok so is 28v correct?
    I can get the ISL6251 of ebay for £5,
    one problem I've got is I can't flash the bios, no matter what I do a usb stick is not accessed, I don't know if this is because I can't boot with just the adapter, I have to have the battery in, should I get the ISL6251 and give it a try?
    Thanks.
    • Sparks88
      • Sep 2011
      • 110
      I can add the diagram if you like, there is a seller from holland who does pre flashed bios chips but if you cannot get to boot to bios then you will not be able to flash anything, unless you are absolutely sure the bios chip is causing the problem!!
      • riget
        • Sep 2011
        • 66
        I can get a bios chip from ebay, about £12, from what I could find out it should flash the bios from a usb stick, holding winkey+b, but I couldn't get the usb stick to be reconised.
        • Sparks88
          • Sep 2011
          • 110
          if your bios cannot boot then you cannot flash something which technically isn't there, you need access to the bios system and chip to be able to program the flash chip and because the system does not start then you cannot do anything to flash the chip, only alternative is to buy the chip and fit it but i think its a waste of time and money until you find the true fault.
          • riget
            • Sep 2011
            • 66
            Yes you can m8, I've done a couple, both were acer's but I think most newer motherboards can be flashed, look up crisis bios recovery.
            Thanks.
            • Sparks88
              • Sep 2011
              • 110
              #26
              Best of luck
              • riget
                • Sep 2011
                • 66
                Update: Replaced the ISL6251, also replaced the bios chip, still the same.
                With the battery it powers up but get 2 flashes from caplock led, same with battery and adapter, battery also charges, but with just adapter nothing.
                Thanks.
                • tomodachi
                  • Apr 2012
                  • 610
                  • Turkey
                  #28
                  you ever tried clear cmos ?
                  • riget
                    • Sep 2011
                    • 66
                    Not sure how to, I shorted the bios battery connections when the battery was removed.
                    I've found 3 shorting points named G1, G2, G3, not sure what they do though, I had similar on an acer that when shorted it cleared a bios password.
                    • riget
                      • Sep 2011
                      • 66
                      I've found the schematics here
                      this is an amd board marked as 16" op8
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        #31
                        i can definitely say that your board is HS. got new one .
                        • riget
                          • Sep 2011
                          • 66
                          Update, I'm still working on it when I get a chance, had a set back though, shorted the keyboard on the mobo, burnt a chip, will have to find what it is and solder another in.
                          • riget
                            • Sep 2011
                            • 66
                            Well I stuck at it and got it to boot hooray,
                            After repairing the damage with the keyboard shorting, I went over the board with my soldering iron, somehow I got power with the charger, after many many attempts of flashing the bios, I put every combination on a usb stick and when I saw the light flashing I could hardly believe it, after a few beeps it restarted and I had boot screen.
                            Now the bad news, after turning it off and restarting, I get the 2 flashing lights code again, I reflash and it works untill I turn it off and on again.
                            Any one any ideas on why it looses the bios each time I turn it off?
                            Thanks.
                            • speedypro
                              • Feb 2013
                              • 561
                              #34
                              Originally posted by dycc
                              hi
                              p2805mf ao seems to be the problem. you have to get 19v at pin 1 (vin) and approximately 9 v at pin 8 (vout) . this IC drive the mosfet that give the necessary voltage to all other chip of the board
                              sorry for english i speak french
                              Hi. Im working on a Compaq CQ62. PU4 is named as "M314 Q5933" or the "Q" could be a "G". Pin 1 gives me 19.17v but pin 8, no voltage. Does it means that this IC is damaged? Also I could not find any reference to the markings above. Can I replace it with "p2805mf ao"?
                              Regards
                              Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
                              • Francisco.s
                                • 686
                                • Spain
                                #35
                                Regards
                                http://laptoprepairegypt.com/blog/2012/11/27/test/
                                Here you can identify your motherboard. It's very useful.
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1489
                                  • portugal
                                  #36
                                  got pratically same issue , when it entered my store , was with the ddc jack led issue , that was shuting down the dc jack led after 3 seconds , (usually bios problem) after reflashing bios , the dc jack led is not always on , also machine turn on , but shutdown 1 second after , , making some test with a battery shows me is trying to charge but the power charger led on the front panel of the machine stay blinking , but with battery and dc outlet machine turn on , just dc not turning on , jut with bat no power enough on bat , notice that this IC DYCC mentioned pu4 is the same for me , cheked and have 28 volts on pin 8 , but even after replacing it with another , still 28 volts . the resistor attacvhed to the vin of the charger ic is 22ohm , really not finding the outher resistor mentioned , altough my machine the system charger is a RT8206B , so pinout is diferent , but cheking this infos , here , seems a system charger problem .
                                  • highpulse
                                    i hate HP
                                    • May 2013
                                    • 1489
                                    • portugal
                                    #37
                                    not finding alltough the correct schematic , all the schametic i got for this are with the ISL , mine is a RichTek
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1489
                                      • portugal
                                      #38
                                      also cheking schematic notice that pu4 pin 8 should be 29 , since its a +VH28 so no error on this .
                                      also not a problem from system charger, since i replaced it , both resistor are ok as well , 22ohm and 11.9 ohm
                                      starting to think about something wrong on the circuit or charging , but must chek were is the fault , pain in the ass HP
                                      • mon2
                                        • 14662
                                        What are the markings to identify the logic board?
                                        28 volts seems very high for the boosted voltage but maybe normal as you have noted.
                                        • zatara10
                                          • Nov 2016
                                          • 25
                                          • sweden
                                          #40
                                          hi everyone
                                          I struggled a lot with this problem
                                          3 times flashing problem is definitely bios related
                                          I downloaded the bios file from somewhere, the problem continued, so I changed the ISL6251 IC, the problem was not solved, then I found the bios file from another place, write it to the bios and the problem was solved
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • esqmooo
                                            HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                            by esqmooo
                                            I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                            03-07-2025, 05:55 AM
                                          • CraigR
                                            Hp x360 15-u499nr power light flashes continuously.
                                            by CraigR
                                            I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                            09-16-2024, 06:12 PM
                                          • stevenallauca
                                            HP laptop does not charge the battery, the light turns amber and then changes to white.
                                            by stevenallauca
                                            Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                            - ACN (BQACN) 19.6v
                                            - ACP (BQACP) 19.6v
                                            - CMSRC (BQCMSRC) 19.6v
                                            - ACDRV...
                                            09-23-2024, 11:30 AM
                                          • russpall
                                            LG 39ln540v - red light flashes twice, no power to LED driver?
                                            by russpall
                                            Hi there,
                                            I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                            The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                            08-27-2024, 01:07 PM
