HP cq61 not starting
  • riget
    • Sep 2011
    • 66
    Got a hp cq61, when I connect the charger the battery charge light flashes 3 times then 1 longer flash then nothing, when I press the power button the charge light flashes quickly but nothing else happens.
    Been checking around the motherboard and found 28v in a few places, is this correct, never had a laptop with more than the adapter voltage before.
    Thanks.
  • pctek
    • Apr 2012
    • 53
    • Greece
    Re: HP cq61 not starting
    Check this
    http://h20000.www2.hp.com/bizsupport...ctID=c01443366
    • riget
      • Sep 2011
      • 66
      Yes I've seen that but it doesn't show what I'm getting.
      The battery power led comes on and stays on as normal.
      The caps/num lock leds do not light.
      It's the battery charge light that flashes(the lightning bolt symbol).
      If I remove the battery the power led still comes on but nothing happens pressing the power button.
      And I get 28v at a couple of ic's, mosfet.
      • pctek
        • Apr 2012
        • 53
        • Greece
        28V is too much indeed . what is the voltage at the power jack or right after it ?
        • riget
          • Sep 2011
          • 66
          Power jack and most other areas seem correct 19v, I've got 5v and 3.3v and some smaller voltages, the 28v is on the gate of the 2nd mosfet after the jack, I unsoldered the leg and the 28v is on the board not the mosfet, on the other side of the board on a 8 leg mosfet I found the same, 28v on the gate leg, not had time yet to look further, but I don't know what is making the 28v.
          • riget
            • Sep 2011
            • 66
            Checked over the motherboard and found 3 chips with 28v,
            First is 85u03gh a mosfet?
            2nd p1003evg mosfet?
            3rd p2805fao not sure what this is, could it be the 28v source?
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              when you charge battery on another cq61 and put it in your own : is it working????
              if so check pu4 (p2805MF AO) :probably a shortcut between pin 1 and the ground .
              also check pr199 (22 ohm) resistor : if the value is more than 22 ohm so this is not good
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                also check pr183 resistor near the memory slot.
                • riget
                  • Sep 2011
                  • 66
                  Update, seems the battery was shot, with a new battery it now starts but I get the caps-lock flashing twice indicating the bios is corrupt, I've tried to flash but it's not seeing the usb stick, I have to have the battery connected though as with just the adapter the laptop doesn't boot.
                  With the battery in and adapter connected the battery charges.
                  With just the battery the laptop starts(to flashing lights)
                  With the battery and adapter the laptop starts(to flashing lights)
                  With just the adapter I get nothing.
                  I've downloaded what is said to be the schematics for this laptop but I'm not sure it's correct, it suggests a 16 or 17.3" when mine is 15.6"
                  dycc: I've looked at your suggestions, PU4 is not p2805mf AO, on this that's PU6, and it has the 28v and pin 1 does not short, it has 19v,
                  pr199 has 2.2ohm, and pr183(that's not that near to the ram) has 3,220 ohm
                  Does anyone know if 28v on this board is correct or not, the ic PQ6 has 28v on the gate, 19v(dc adapter) on the 3 source, and 11.5v(battery) on the 4 drain, so seems correct for charging the battery.
                  So I need to know why the laptop doesn't boot with just the adapter connected.
                  dycc, you seemed to suspect it would be ok with a good battery, and apart from the corrupt bios it seems your correct, could it be that the resistors you said to check could have different numbers on this motherboard.
                  Thanks.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Hi - so does nothing come on the screen at all.
                    Is there any sound - beep code? or is it just the leds.
                    Have you tried removing any extra ram modules.
                    Please can you update your profile with your country.
                    • riget
                      • Sep 2011
                      • 66
                      Hi, nothing on screen, no beeps, just flashing led's, yes tried different ram, I'm in the UK.
                      Thanks.
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        hi
                        p2805mf ao seems to be the problem. you have to get 19v at pin 1 (vin) and approximately 9 v at pin 8 (vout) . this IC drive the mosfet that give the necessary voltage to all other chip of the board
                        sorry for english i speak french
                        • dycc
                          Vision
                          • Nov 2011
                          • 625
                          • Côte d'Ivoire
                          if you read 28v at the multimeter on pin8 of p2805mf ao ; so you found the issue of your board. you must replace this IC
                          • riget
                            • Sep 2011
                            • 66
                            Hi dycc, yes I get 19v on pin 1, and 28v on pin 8, I wondered if this ic was the problem, it's strange that the battery charge voltage is correct though.
                            I've just got to find the ic now, looks like china is the only stock, unless anyone knows any other suppliers.
                            Thanks.
                            • dycc
                              Vision
                              • Nov 2011
                              • 625
                              • Côte d'Ivoire
                              i want to know something :
                              do you get 11.5v on the for drain of pq6 when baterry is in and adapter connected ???
                              secondary i want you to check voltage on pin 2(acin) an 24(dcin) of ISL6251 (battery charger) do this test without battery in ; only adapter connected .
                              • dycc
                                Vision
                                • Nov 2011
                                • 625
                                • Côte d'Ivoire
                                sorry four drain
                                • dycc
                                  Vision
                                  • Nov 2011
                                  • 625
                                  • Côte d'Ivoire
                                  also pin 8 (vref) of ISL6251 you must get 2.39v if all is ok
                                  • riget
                                    • Sep 2011
                                    • 66
                                    Hi, yes 11.5v on all four drain of pq6, battery in adapter connected.
                                    ISL6251 pin 2 2.1v with and without battery and adapter connected
                                    pin 8 2.4v
                                    • dycc
                                      Vision
                                      • Nov 2011
                                      • 625
                                      • Côte d'Ivoire
                                      if laptop boot on battery and does not on adapter : replace ISL6251 . get it from another board.
                                      One day i did the same to solve this issue on TOSHIBA L500 .
                                      • Sparks88
                                        • Sep 2011
                                        • 110
                                        I have the same board with a similar problem, dead with the power led going out after about 10 seconds, i have the schematic and p2805mf ao has 28v on pin 8 according to page 31 of the service manual, there are several board versions and even the manual which says its for my board there are differences, my board is a quanta op6/op7 version revision a.
                                        This board also suffers from the dreaded graphics chip failure so dont rule that out either.
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • esqmooo
                                          HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                          by esqmooo
                                          I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                          03-07-2025, 05:55 AM
                                        • CraigR
                                          Hp x360 15-u499nr power light flashes continuously.
                                          by CraigR
                                          I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                          09-16-2024, 06:12 PM
                                        • stevenallauca
                                          HP laptop does not charge the battery, the light turns amber and then changes to white.
                                          by stevenallauca
                                          Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
                                          - ACN (BQACN) 19.6v
                                          - ACP (BQACP) 19.6v
                                          - CMSRC (BQCMSRC) 19.6v
                                          - ACDRV...
                                          09-23-2024, 11:30 AM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
