Asus a9t charge battery but wont power up
  • nucleus
    • May 2012
    • 64
    • Montenegro
    Hi there,
    I have this lap top and as I said it charge battery (turn on the lamp and on battery conector there is 3.3v and 4.5v if I remember good) but when I press power button nothing happens. I found that on cpu supply coil is 0v. 5v and 3.3v are present.
    If someone have similar experiences please help me. Also I can't find schematics for it.
  • nucleus
    • May 2012
    • 64
    • Montenegro
    Re: Asus a9t charge battery but wont power up
    can someone tell me how to test max1987 chip?
    thank you
    • mattbrad2
      • Jan 2011
      • 122
      You'll drive yourself batty testing that. My best advice would be to outright replace it if you suspect that as the problem. Usually these are about $6. In your case, it certainly could be the culprit.
      • nucleus
        • May 2012
        • 64
        • Montenegro
        thank you mattbrad2,
        I suspect on that chip. Only problem is I must order it from china and it cost about 40 - 50$ when it comes to me, so if it is not to that chip I am in loss and still have fault motherboard
        • mattbrad2
          • Jan 2011
          • 122
          http://www.ebay.com/itm/1x-MAXIM-MAX...ht_2882wt_1163
          Sure about that?
          • nucleus
            • May 2012
            • 64
            • Montenegro
            yes I know that, BUT I can't make payment. Pay Pal does not accept cards from my country so I can't order it. Chips that I order are even cheaper than on ebay, but shipping is very expensive.
            anyway thank you for your help
            • xose_maria
              • Sep 2010
              • Spain
              thank you
              http://igorx.irk.ru/datasheet/1295575671.pdf
              Page 15.
              Asus motherboards have no silkscreen. It's crazy if you do not have boardview.
              • nucleus
                • May 2012
                • 64
                • Montenegro
                I found max1987 on some old board and replaced it on asus board. It fixed problem, and it works now.
                after that I measured voltage when it is powered off on adapter and it again had 0v. It seems that it got voltage only when it is powered and I was lucky to fix it straith
