Asus Vivobook M3502Q, no power through USB-C, works on battery.
  • Gregoriy Kim
    • Mar 2024
    • Республика Корея
    Hello everyone!
    Need help with Asus Vivobook M3502Q, Ryzen 5.
    First time working with failed power supply via USB-C ports. no schematics available.
    Symptoms:
    suddenly turned off and does not turn on,
    Upon first observation, turned out both CSD87501 mosfets had unsoldered due to overheating.
    Manually charged battery and laptop works on battery
    Soldered 2 new CSD87501 on board, but it didn't solve the issue.
    there is 3.3V and 1.6V from TPS65994. and it talks to charger, so charger sends 20V, but no load. There is 20V present on supply side of CSD87501, but either 9V or 0V on gate.
    No 5V
    No shorts detected.
    As I mentioned before this is my first time working with this type of power delivery system.
    If anyone had same problem, could you please help?
  • Ariu
    Asus Vivobook F712E, no power, no charging, works only with battery, help!
    by Ariu
    Hello, i have a asus notebook, that doesnt power on at all or charge.
    it works only with battery plugged in without charger.(no schematic available)
    BQ24780S ic already replaced with a good one but same issue, 0V on the source and gate of 1. mosfet.
    No short on 1. and 2. mosfet.
    i am able to measure only 3.2V on the CSR.
    BQ24780S voltages:
    1. ACN ->3.2V
    2.ACP ->3.2V
    3.CMSRC ->0V
    4.ACDRV->0V
    5.ACOK->0V
    6.ACDET->0.66V
    24.REGN->6V
    when i inject 19.5V on the CSR the notebook...
    07-04-2024, 01:57 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • bykanovm
    Thinkpad W541 Works from the mains and charges the battery only when it is turned off
    by bykanovm
    Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
    If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
    If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
    even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
    Also, the laptop does not turn on without...
    04-02-2025, 02:45 AM
  • rob777
    Asus TUF won’t run off battery
    by rob777
    I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
    I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
    Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
    Thanks....
    05-27-2025, 07:07 PM
  • ivangserrano
    ASUS UX303UB REV2.2 WORKS ONLY BATTERY
    by ivangserrano
    Hello
    I have an ASUS UX303UB that only turns on with the battery connected, it doesn't turn on only with the charger connected.
    With the battery and charger connected, the computer turns on but does not charge and I can see some consumption at the source, it seems to me that the charger is taking over.
    In the work environment I can see that the battery is at 24% and does not charge or discharge.
    I checked the 24780s load ic and I have the following voltages.
    24780s
    vcc - 18.85
    24v acdriver
    acok 1.3v
    acdet 2.6v...
    06-29-2024, 06:35 AM
